Home » Eclipse Projects » Kura » Kura on Raspberry PI - Remote management is not working(Deploy-V2 is in unsatisfied state)
Kura on Raspberry PI - Remote management is not working [message #1770235] Wed, 09 August 2017 05:54 Go to next message
Hi All,
I installed Kura 3.0 in Raspberry PI device and trying remote management using Deploy-V2.
In that process it is observed that, org.eclipse.kura.core.deployment.ClouddeploymentHandlerV2 is in 'Unsatisfied state'
I checked 'ls', 'ss' and comp on OSGi console.
It is giving error on cloud.CloudService and data.transport.mqtt.MqttDataTransport even, those services are installed and active.
Appreciate your thoughts in resolving this.
Logs are:
All Components:
ID State Component Name Located in bundle
1 Active org.eclipse.equinox.event org.eclipse.equinox.event(bid=8)
2 Active org.eclipse.kura.data.DataService org.eclipse.kura.core(bid=53)
3 Active org.eclipse.kura.db.DbService org.eclipse.kura.core(bid=53)
4 Active org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport org.eclipse.kura.core(bid=53)
5 Active org.eclipse.kura.ssl.SslManagerService org.eclipse.kura.core(bid=53)
6 Active org.eclipse.kura.system.SystemService org.eclipse.kura.core(bid=53)
7 Active org.eclipse.kura.system.SystemAdminService org.eclipse.kura.core(bid=53)
8 Active org.eclipse.kura.certificate.CertificatesService org.eclipse.kura.core.certificates(bid=54)
9 Active org.eclipse.kura.cloud.CloudService org.eclipse.kura.core.cloud(bid=55)
10 Registered org.eclipse.kura.cloud.CloudCallService org.eclipse.kura.core.cloud(bid=55)
11 Active org.eclipse.kura.core.cloud.factory.DefaultCloudServiceFactory org.eclipse.kura.core.cloud(bid=55)
12 Unsatisfied org.eclipse.kura.cloud.app.command.CommandCloudApp org.eclipse.kura.core.cloud(bid=55)
13 Active org.eclipse.kura.core.comm.CommConnectionFactory org.eclipse.kura.core.comm(bid=56)
14 Active org.eclipse.kura.core.configuration.CloudConfigurationHandler org.eclipse.kura.core.configuration(bid=57)
15 Active org.eclipse.kura.configuration.ConfigurationService org.eclipse.kura.core.configuration(bid=57)
16 Active org.eclipse.kura.crypto.CryptoService org.eclipse.kura.core.crypto(bid=58)
17 Unsatisfied org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2 org.eclipse.kura.core.deployment(bid=59)
18 Active org.eclipse.kura.log.LoggerService org.eclipse.kura.core.log(bid=60)
19 Active org.eclipse.kura.status.CloudConnectionStatusService org.eclipse.kura.core.status(bid=62)
20 Active org.eclipse.kura.deployment.agent org.eclipse.kura.deployment.agent(bid=63)
Dynamic information :
*The component is NOT satisfied
The following references are not satisfied:
Reference[name = CloudService, interface = org.eclipse.kura.cloud.CloudService, policy = static, cardinality = 1..1, target = (kura.service.pid=org.eclipse.kura.cloud.CloudService), bind = setCloudService, unbind = unsetCloudService]
Reference[name = DataTransportService, interface = org.eclipse.kura.data.DataTransportService, policy = static, cardinality = 1..1, target = (kura.service.pid=org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport), bind = setDataTransportService, unbind = unsetDataTransportService]
Component configurations :
Configuration properties:
CloudService.target = (kura.service.pid=org.eclipse.kura.cloud.CloudService)
component.name = org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
DataTransportService.target = (kura.service.pid=org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport)
component.id = 34
Instances:
Thank you.
With Best Regards,
Praveen.B
Re: Kura on Raspberry PI - Remote management is not working [message #1770236 is a reply to message #1770235] Wed, 09 August 2017 05:56 Go to previous messageGo to next message
could you post a screenshot of the current cloud service instances you have?
Matteo
Re: Kura on Raspberry PI - Remote management is not working [message #1770288 is a reply to message #1770236] Wed, 09 August 2017 12:25 Go to previous messageGo to next message
Hi Matteo,
I configured two cloud services. One with Azure IoT Hub and another with IoT.Eclipse. Both connections are established properly.
Please find attached screenshot.
WIth Best Regards,
Praveen.B
  • Attachment: kuraerror.png
    (Size: 167.11KB, Downloaded 123 times)
Re: Kura on Raspberry PI - Remote management is not working [message #1770299 is a reply to message #1770288] Wed, 09 August 2017 14:26 Go to previous messageGo to next message
that's the point: the deployV2 is strictly related to the default cloud service.
Here the reference that should be matched: CloudService.target = (kura.service.pid=org.eclipse.kura.cloud.CloudService)
Best regards
Re: Kura on Raspberry PI - Remote management is not working [message #1770328 is a reply to message #1770236] Thu, 10 August 2017 00:14 Go to previous message
Hi Matteo,
Thank you for the hint, I could solve the problem.
With Best Regards,
Praveen.B
[Updated on: Thu, 10 August 2017 14:27] by Moderator
Previous Topic:Kura Services OsGI-Inf Metatype xml Editing
Next Topic:Kura with Kapua
Current Time: Wed Jul 23 23:34:50 EDT 2025
Powered by FUDForum. Page generated in 0.05860 seconds
