Subversion issue('s) [message #1770182] |
Tue, 08 August 2017 18:11  |
So I have inherited a Hudson server running ver. 1.347 and have recently been told users cannot build a project due to a subversion error.
Under Configure for the project and then under Source Code Management I see an error next to "Subversion Modules" stating...
Unable to access https://svn.*HOST-AND-FULL-PATH-REMOVED*: svn: Received fatal alert: handshake_failure
svn: OPTIONS request failed on '/svn/.*HOST-AND-FULL-PATH-REMOVED*: (show details)
(Maybe you need to enter credential?)
Under show details it states:
org.tmatesoft.svn.core.SVNException: svn: Received fatal alert: handshake_failure
svn: OPTIONS request failed on '/svn/*HOST-AND-FULL-PATH-REMOVED*'
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:103)
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:87)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:616)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:273)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:261)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.exchangeCapabilities(DAVConnection.java:516)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.open(DAVConnection.java:98)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.openConnection(DAVRepository.java:1001)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.testConnection(DAVRepository.java:97)
at hudson.scm.SubversionSCM$DescriptorImpl.checkRepositoryPath(SubversionSCM.java:1703)
at hudson.scm.SubversionSCM$DescriptorImpl.doCheckRemote(SubversionSCM.java:1644)
at org.kohsuke.stapler.Function$InstanceFunction.invoke(Function.java:169)
at org.kohsuke.stapler.Function.bindAndInvoke(Function.java:101)
at org.kohsuke.stapler.Function.bindAndInvokeAndServeResponse(Function.java:54)
at org.kohsuke.stapler.MetaClass$1.doDispatch(MetaClass.java:74)
at org.kohsuke.stapler.NameBasedDispatcher.dispatch(NameBasedDispatcher.java:30)
at org.kohsuke.stapler.Stapler.invoke(Stapler.java:519)
at org.kohsuke.stapler.MetaClass$6.doDispatch(MetaClass.java:180)
at org.kohsuke.stapler.Stapler.invoke(Stapler.java:435)
at org.kohsuke.stapler.Stapler.service(Stapler.java:123)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:45)
at winstone.ServletConfiguration.execute(ServletConfiguration.java:249)
at winstone.RequestDispatcher.forward(RequestDispatcher.java:335)
at winstone.RequestDispatcher.doFilter(RequestDispatcher.java:378)
at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:94)
at hudson.plugins.audit_trail.AuditTrailFilter.doFilter(AuditTrailFilter.java:64)
at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:97)
at hudson.util.PluginServletFilter.doFilter(PluginServletFilter.java:86)
at winstone.FilterConfiguration.execute(FilterConfiguration.java:195)
at winstone.RequestDispatcher.doFilter(RequestDispatcher.java:368)
at hudson.security.csrf.CrumbFilter.doFilter(CrumbFilter.java:47)
at hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:84)
at hudson.security.ChainedServletFilter.doFilter(ChainedServletFilter.java:76)
at hudson.security.HudsonFilter.doFilter(HudsonFilter.java:164)
at winstone.RequestDispatcher.forward(RequestDispatcher.java:333)
at winstone.RequestHandlerThread.processRequest(RequestHandlerThread.java:244)
at winstone.RequestHandlerThread.run(RequestHandlerThread.java:150)
Caused by: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
at com.sun.net.ssl.internal.ssl.Alerts.getSSLException(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.recvAlert(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.writeRecord(Unknown Source)
at com.sun.net.ssl.internal.ssl.AppOutputStream.write(Unknown Source)
at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
at java.io.BufferedOutputStream.flush(Unknown Source)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.sendData(HTTPConnection.java:226)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPRequest.dispatch(HTTPRequest.java:166)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:345)
... 48 more
So I see it is moaning about the SSL handshake... But how do I fix this? Is it the SSL on the svn server? - Is it needed can I turn that off in Hudson (if so how?)
I have tried reverting to non ssl (so just http) but get the following error:
Unable to access http://svn.*HOST-AND-FULL-PATH-REMOVED* : svn: Repository moved permanently to '/svn/*HOST-AND-FULL-PATH-REMOVED*'; please relocate
org.tmatesoft.svn.core.SVNException: svn: Repository moved permanently to '/svn/*HOST-AND-FULL-PATH-REMOVED*'; please relocate
It is telling me the repository has moved but tells me the same location again?
any help appreciated.
FUDForum. Page generated in 0.04236 seconds
