Home » Eclipse Projects » Kura » Problem in setting up the Kura Development Environment
Problem in setting up the Kura Development Environment [message #1770006] Mon, 07 August 2017 09:26 Go to next message
Hi, I have some trouble following the getting started guide [1]. When using Eclipse IDE (Oxygen) to import Kura user workspace, I cannot click the link "Set as target platform", the file "kura-equinox.target" just appear as a text file like following when I double click on it:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.8"?>
<target name="Kura Target Platform Equinox 3.11.1" sequenceNumber="43">
  <locations>
    <location path="${workspace_loc}/target-definition/equinox_3.11.1/repository/plugins" type="Profile"/>
	<location path="${workspace_loc}/target-definition/common/repository/plugins" type="Profile"/>
  </locations>
</target>]
I also tried using Oomph installer, but when Eclipse IDE startup and begins to check out the code I received alot of errors related to Auth Failed like this (I am using Linux, not Windows):
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/kura.git: Auth fail
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:881)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3324)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3267)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4494)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4488)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4486)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3258)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3233)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3133)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:567)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:693)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
Caused by: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/kura.git: Auth fail
  at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:245)
  at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:293)
  at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:190)
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.cloneRepository(GitCloneTaskImpl.java:942)
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:805)
  ... 1 more
[1]: https://eclipse.github.io/kura/dev/kura-setup.html
Re: Problem in setting up the Kura Development Environment [message #1770008 is a reply to message #1770006] Mon, 07 August 2017 09:48 Go to previous messageGo to next message
I changed the IDE to Eclipse EE and it worked :)
Re: Problem in setting up the Kura Development Environment [message #1770009 is a reply to message #1770006] Mon, 07 August 2017 09:49 Go to previous messageGo to next message
in the Oomph setup, I would suggest you to change the ssh reference to the HTTPS one: https://github.com/eclipse/kura.git
Matteo
Re: Problem in setting up the Kura Development Environment [message #1770034 is a reply to message #1770009] Mon, 07 August 2017 12:04 Go to previous messageGo to next message
I am following the getting started guide with kura version 2.0. When trying to run the emulator I got these messages in the console:
!SESSION 2017-08-07 17:58:53.957 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_131
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments:  -dev file:/home/cloud/kura-workspace/.metadata/.plugins/org.eclipse.pde.core/Kura_Emulator_Linux/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog -console
!ENTRY org.eclipse.kura.demo.heater 4 0 2017-08-07 17:58:54.807
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.demo.heater_1.0.2.qualifier [1]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.kura.cloud; version="[1.0.0,2.0.0)"
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.kura.example.beacon 4 0 2017-08-07 17:58:54.988
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.example.beacon_1.0.1 [21]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.kura.bluetooth; version="[1.0.0,2.0.0)"
!ENTRY org.eclipse.kura.example.publisher 4 0 2017-08-07 17:58:54.989
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.example.publisher_1.0.2.qualifier [24]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.kura; version="[1.0.0,2.0.0)"
osgi> 17:58:55,116 [Component Resolve Thread] INFO  HelloOsgi:15  - Bundle org.eclipse.kura.example.hello_osgi has started!
!ENTRY org.eclipse.kura.example.ble.tisensortag 4 0 2017-08-07 17:58:55.141
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.example.ble.tisensortag_1.0.2 [44]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.kura; version="[1.0.0,2.0.0)"
17:58:55,194 [Start Level Event Dispatcher] INFO  Server:253  - jetty-8.1.3.v20120522
17:58:55,254 [Start Level Event Dispatcher] WARN  AbstractLifeCycle:199  - FAILED SelectChannelConnector@0.0.0.0:8080: java.net.BindException: Address already in use
	at sun.nio.ch.Net.bind0(Native Method)
	at sun.nio.ch.Net.bind(Net.java:433)
	at sun.nio.ch.Net.bind(Net.java:425)
	at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
	at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
	at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182)
	at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311)
	at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260)
	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)
	at org.eclipse.jetty.server.Server.doStart(Server.java:273)
	at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:113)
	at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:62)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
17:58:55,256 [Start Level Event Dispatcher] WARN  AbstractLifeCycle:199  - FAILED org.eclipse.jetty.server.Server@1681e420: java.net.BindException: Address already in use
!ENTRY org.eclipse.equinox.http.jetty 4 0 2017-08-07 17:58:55.256
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.http.jetty.internal.Activator.start() of bundle org.eclipse.equinox.http.jetty.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: org.osgi.service.cm.ConfigurationException: default : Address already in use
	at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:115)
	... 12 more
Caused by: java.net.BindException: Address already in use
	... 16 more
Root exception:
	... 16 more
!ENTRY org.eclipse.osgi 4 0 2017-08-07 17:58:55.259
!MESSAGE Bundle initial@reference:file:../../../../org.eclipse.kura.demo.heater/ was not resolved.
!MESSAGE Bundle initial@reference:file:../../../../org.eclipse.kura.example.beacon/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2017-08-07 17:58:55.260
!MESSAGE Bundle initial@reference:file:../../../../org.eclipse.kura.example.publisher/ was not resolved.
!MESSAGE Bundle initial@reference:file:../../../../org.eclipse.kura.example.ble.tisensortag/ was not resolved.
!MESSAGE Bundle org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841 [47] is not active.
!ENTRY org.eclipse.osgi 2 0 2017-08-07 17:58:55.285
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.285
!SUBENTRY 2 org.eclipse.kura.demo.heater 2 0 2017-08-07 17:58:55.285
!MESSAGE Missing imported package org.eclipse.kura.cloud_[1.0.0,2.0.0).
!MESSAGE Missing imported package org.eclipse.kura.configuration_[1.0.0,2.0.0).
!MESSAGE Missing imported package org.eclipse.kura.message_[1.0.0,2.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.286
!SUBENTRY 2 org.eclipse.kura.example.ble.tisensortag 2 0 2017-08-07 17:58:55.286
!MESSAGE Missing imported package org.eclipse.kura_[1.0.0,2.0.0).
!SUBENTRY 2 org.eclipse.kura.example.ble.tisensortag 2 0 2017-08-07 17:58:55.287
!MESSAGE Missing imported package org.eclipse.kura.bluetooth_[1.1.0,2.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.287
!SUBENTRY 2 org.eclipse.kura.example.publisher 2 0 2017-08-07 17:58:55.287
!SUBENTRY 2 org.eclipse.kura.example.publisher 2 0 2017-08-07 17:58:55.288
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.288
!SUBENTRY 2 org.eclipse.kura.example.beacon 2 0 2017-08-07 17:58:55.288
!MESSAGE Missing imported package org.eclipse.kura.bluetooth_[1.0.0,2.0.0).
!ENTRY org.eclipse.osgi 2 0 2017-08-07 17:58:55.297
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.297
!MESSAGE Bundle org.eclipse.kura.demo.heater_1.0.2.qualifier [1] was not resolved.
!SUBENTRY 2 org.eclipse.kura.demo.heater 2 0 2017-08-07 17:58:55.297
!SUBENTRY 2 org.eclipse.kura.demo.heater 2 0 2017-08-07 17:58:55.298
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.298
!MESSAGE Bundle org.eclipse.kura.example.beacon_1.0.1 [21] was not resolved.
!SUBENTRY 2 org.eclipse.kura.example.beacon 2 0 2017-08-07 17:58:55.298
!MESSAGE Bundle org.eclipse.kura.example.publisher_1.0.2.qualifier [24] was not resolved.
!SUBENTRY 2 org.eclipse.kura.example.publisher 2 0 2017-08-07 17:58:55.298
!MESSAGE Bundle org.eclipse.kura.example.ble.tisensortag_1.0.2 [44] was not resolved.
!SUBENTRY 2 org.eclipse.kura.example.ble.tisensortag 2 0 2017-08-07 17:58:55.299
Any idea on how to resolve these messages ? Thank you alot.
Re: Problem in setting up the Kura Development Environment [message #1770041 is a reply to message #1770034] Mon, 07 August 2017 13:16 Go to previous message
I see few problems here: first of all, it seems that the launch configuration has some dependencies not selected.
Other than that, it seems that the port 8080 is already in use. Is it possible that you have multiple emulator instances running at the same time?
Best regards
Previous Topic:Metatype configuration supported data types - tables/lists?
Next Topic:ClouddeploymentHandlerV2 in unsatisfied state
Current Time: Sat Jul 26 08:50:05 EDT 2025
Powered by FUDForum. Page generated in 0.08715 seconds
