SWTException: Failed to create Ole Client. result= -2147221164 [message #1744016] |
Wed, 21 September 2016 09:01  |
Hi there,
I'm trying to deploy a Bundle from Eclipse Neon for x64 architectures.
The project comes out from a x86 architecture setup and recall a .NET component via OLE.
I set up all the Environment: Java x64, dlls recompiled and registered for x64, updated osgi and swt libraries....
The problem is that once I run the product (from Eclipse), the main GUI of my application partially loads, but I got the following message:
"org.eclipse.swt.SWTException: Failed to create Ole Client. result= -2147221164
at org.eclipse.swt.ole.win32.OLE.error(OLE.java:302)
at org.eclipse.swt.ole.win32.OleClientSite.<init>(OleClientSite.java:253)
at ....."
It seems the OLE component fails to run. To try solving this, I registered the dll (developed in VS) into ActiveX using RegAsm.exe (\windows\Microsoft.NET\ folder), but this didn't solve the problem.
Every help will be gratefully accepted.
Thank you.
Bane
FUDForum. Page generated in 0.03952 seconds
