Home » Eclipse Projects » Kura » Problem in setting up the Kura Development Environment
Problem in setting up the Kura Development Environment [message #1770006] |
Mon, 07 August 2017 09:26  |
Hi, I have some trouble following the getting started guide [1]. When using Eclipse IDE (Oxygen) to import Kura user workspace, I cannot click the link "Set as target platform", the file "kura-equinox.target" just appear as a text file like following when I double click on it:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.8"?>
<target name="Kura Target Platform Equinox 3.11.1" sequenceNumber="43">
<locations>
<location path="${workspace_loc}/target-definition/equinox_3.11.1/repository/plugins" type="Profile"/>
<location path="${workspace_loc}/target-definition/common/repository/plugins" type="Profile"/>
</locations>
</target>]
I also tried using Oomph installer, but when Eclipse IDE startup and begins to check out the code I received alot of errors related to Auth Failed like this (I am using Linux, not Windows):
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/kura.git: Auth fail
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:881)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3324)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3267)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4494)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4488)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4486)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3258)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3233)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3133)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:567)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:693)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
Caused by: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/kura.git: Auth fail
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:245)
at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:293)
at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:190)
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.cloneRepository(GitCloneTaskImpl.java:942)
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:805)
... 1 more
[1]: https://eclipse.github.io/kura/dev/kura-setup.html
Re: Problem in setting up the Kura Development Environment [message #1770034 is a reply to message #1770009] |
Mon, 07 August 2017 12:04   |
I am following the getting started guide with kura version 2.0. When trying to run the emulator I got these messages in the console:
!SESSION 2017-08-07 17:58:53.957 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_131
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -dev file:/home/cloud/kura-workspace/.metadata/.plugins/org.eclipse.pde.core/Kura_Emulator_Linux/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog -console
!ENTRY org.eclipse.kura.demo.heater 4 0 2017-08-07 17:58:54.807
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.demo.heater_1.0.2.qualifier [1]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.kura.cloud; version="[1.0.0,2.0.0)"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.kura.example.beacon 4 0 2017-08-07 17:58:54.988
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.example.beacon_1.0.1 [21]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.kura.bluetooth; version="[1.0.0,2.0.0)"
!ENTRY org.eclipse.kura.example.publisher 4 0 2017-08-07 17:58:54.989
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.example.publisher_1.0.2.qualifier [24]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.kura; version="[1.0.0,2.0.0)"
osgi> 17:58:55,116 [Component Resolve Thread] INFO HelloOsgi:15 - Bundle org.eclipse.kura.example.hello_osgi has started!
!ENTRY org.eclipse.kura.example.ble.tisensortag 4 0 2017-08-07 17:58:55.141
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.example.ble.tisensortag_1.0.2 [44]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.kura; version="[1.0.0,2.0.0)"
17:58:55,194 [Start Level Event Dispatcher] INFO Server:253 - jetty-8.1.3.v20120522
17:58:55,254 [Start Level Event Dispatcher] WARN AbstractLifeCycle:199 - FAILED SelectChannelConnector@0.0.0.0:8080: java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:433)
at sun.nio.ch.Net.bind(Net.java:425)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182)
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311)
at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)
at org.eclipse.jetty.server.Server.doStart(Server.java:273)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:113)
at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:62)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
17:58:55,256 [Start Level Event Dispatcher] WARN AbstractLifeCycle:199 - FAILED org.eclipse.jetty.server.Server@1681e420: java.net.BindException: Address already in use
!ENTRY org.eclipse.equinox.http.jetty 4 0 2017-08-07 17:58:55.256
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.http.jetty.internal.Activator.start() of bundle org.eclipse.equinox.http.jetty.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: org.osgi.service.cm.ConfigurationException: default : Address already in use
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:115)
... 12 more
Caused by: java.net.BindException: Address already in use
... 16 more
Root exception:
... 16 more
!ENTRY org.eclipse.osgi 4 0 2017-08-07 17:58:55.259
!MESSAGE Bundle initial@reference:file:../../../../org.eclipse.kura.demo.heater/ was not resolved.
!MESSAGE Bundle initial@reference:file:../../../../org.eclipse.kura.example.beacon/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2017-08-07 17:58:55.260
!MESSAGE Bundle initial@reference:file:../../../../org.eclipse.kura.example.publisher/ was not resolved.
!MESSAGE Bundle initial@reference:file:../../../../org.eclipse.kura.example.ble.tisensortag/ was not resolved.
!MESSAGE Bundle org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841 [47] is not active.
!ENTRY org.eclipse.osgi 2 0 2017-08-07 17:58:55.285
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.285
!SUBENTRY 2 org.eclipse.kura.demo.heater 2 0 2017-08-07 17:58:55.285
!MESSAGE Missing imported package org.eclipse.kura.cloud_[1.0.0,2.0.0).
!MESSAGE Missing imported package org.eclipse.kura.configuration_[1.0.0,2.0.0).
!MESSAGE Missing imported package org.eclipse.kura.message_[1.0.0,2.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.286
!SUBENTRY 2 org.eclipse.kura.example.ble.tisensortag 2 0 2017-08-07 17:58:55.286
!MESSAGE Missing imported package org.eclipse.kura_[1.0.0,2.0.0).
!SUBENTRY 2 org.eclipse.kura.example.ble.tisensortag 2 0 2017-08-07 17:58:55.287
!MESSAGE Missing imported package org.eclipse.kura.bluetooth_[1.1.0,2.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.287
!SUBENTRY 2 org.eclipse.kura.example.publisher 2 0 2017-08-07 17:58:55.287
!SUBENTRY 2 org.eclipse.kura.example.publisher 2 0 2017-08-07 17:58:55.288
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.288
!SUBENTRY 2 org.eclipse.kura.example.beacon 2 0 2017-08-07 17:58:55.288
!MESSAGE Missing imported package org.eclipse.kura.bluetooth_[1.0.0,2.0.0).
!ENTRY org.eclipse.osgi 2 0 2017-08-07 17:58:55.297
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.297
!MESSAGE Bundle org.eclipse.kura.demo.heater_1.0.2.qualifier [1] was not resolved.
!SUBENTRY 2 org.eclipse.kura.demo.heater 2 0 2017-08-07 17:58:55.297
!SUBENTRY 2 org.eclipse.kura.demo.heater 2 0 2017-08-07 17:58:55.298
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-08-07 17:58:55.298
!MESSAGE Bundle org.eclipse.kura.example.beacon_1.0.1 [21] was not resolved.
!SUBENTRY 2 org.eclipse.kura.example.beacon 2 0 2017-08-07 17:58:55.298
!MESSAGE Bundle org.eclipse.kura.example.publisher_1.0.2.qualifier [24] was not resolved.
!SUBENTRY 2 org.eclipse.kura.example.publisher 2 0 2017-08-07 17:58:55.298
!MESSAGE Bundle org.eclipse.kura.example.ble.tisensortag_1.0.2 [44] was not resolved.
!SUBENTRY 2 org.eclipse.kura.example.ble.tisensortag 2 0 2017-08-07 17:58:55.299
Any idea on how to resolve these messages ? Thank you alot.
Current Time: Sat Jul 26 19:05:58 EDT 2025
Powered by FUDForum. Page generated in 0.06508 seconds
