Home » Eclipse Projects » e(fx)clipse » JavaFX E4 Application is stuck in MacApplication._runloop() when launched from developer Eclipse
JavaFX E4 Application is stuck in MacApplication._runloop() when launched from developer Eclipse [message #1769979] Mon, 07 August 2017 05:34 Go to next message
we are developing an E4 application with pure JavaFX (without SWT) and
efxclipse.
Everything is running fine on Linux and Windows. We build the product with
Tycho (User Build) or launch it from inside our developer Eclipse (Developer
Build).
Unfortunately, MacOSX gives us some headaches: launching the user build from
a terminal succeeds as expected. However, when using a run configuration and
launching the product from the developer Eclipse no stage is created and the
JavaFX thread is stuck in MacApplication._runloop() native code.
Additionally, the examples provided by efxclipse work even in the developer setting, but we weren't able to find any differences to our application launch setup.
Has anyone run across this problem or can even provide a solution?
Thanks in advance,
Florian
Re: JavaFX E4 Application is stuck in MacApplication._runloop() when launched from developer Eclipse [message #1770172 is a reply to message #1769979] Tue, 08 August 2017 16:02 Go to previous messageGo to next message
Can you provide a screenshot of your launch configuration with the arguments tab - Eclipse unfortunately is extra smart it is really important that eg your "Program arguments" look like this "-nl ${target.nl} -consoleLog -nosplash", no os and ws parameter
Re: JavaFX E4 Application is stuck in MacApplication._runloop() when launched from developer Eclipse [message #1771670 is a reply to message #1770172] Tue, 29 August 2017 08:07 Go to previous message
SOLVED:
Removing the os, ws, and arch argument solved the problem.
Thanks for the hint.
Previous Topic:Has anyone tried the maven repositories for e(fx)clipse?
Next Topic:Recommended way to add Persistence to an e(fx)clipse application?
Current Time: Fri Jul 18 09:10:27 EDT 2025
Powered by FUDForum. Page generated in 0.04300 seconds
