Home » Modeling » TMF (Xtext) » Using CompilationTestHelper with a custom classloader
Using CompilationTestHelper with a custom classloader [message #1769925] Sat, 05 August 2017 22:52
I have an xbase DSL and run into troubles when trying to use a custom class loader in combination with the CompilationTestHelper.
I managed to reproduce the issue on a minimalistic project:
grammar com.septentrio.infrastructure.juggle.Juggle with org.eclipse.xtext.xbase.annotations.XbaseWithAnnotations
generate juggle "http://www.septentrio.com/infrastructure/juggle/Juggle"
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as types
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
Model:
    package=Package?
    importSection=XImportSection?
    variables+=Variable*;
Package:
    'package' name=QualifiedName;
Variable:
    'variable' type=JvmTypeReference name=ID;
The test uses Janino to compile the "Doer" class on-the-fly and inject the resulting classloader into the instance of CompilationTestHelper:
class JuggleGeneratorTest {
    private Logger logger = LoggerFactory.getLogger(JuggleGeneratorTest)
    private Server server
    @Inject private Provider<CompilationTestHelper> compilationTestHelperProvider
    @Test def void testGeneratedCode() {
        val clazz = '''
        package com.example;
        public class Doer {
            public void doSomething() {}
        '''.load('com.example.Doer')
        Thread.currentThread.contextClassLoader = clazz.classLoader
        package mypackage
        import com.example.Doer
        variable Doer doer
        .compile(clazz.classLoader)[
            System.out.println(generatedCode)
    private def compile(CharSequence string, ClassLoader cl, IAcceptor<Result> result) {
        val cth = compilationTestHelperProvider.get
        cth.javaCompilerClassPath = cl
        cth.compile(string, result)
    private def load(CharSequence string, String className) {
        val compiler = new SimpleCompiler
        compiler.cook(null, new ByteArrayInputStream(string.toString.getBytes))
        compiler.classLoader.loadClass(className)
The inferrer is minimal:
class JuggleJvmModelInferrer extends AbstractModelInferrer {
    @Inject extension JvmTypesBuilder
    def dispatch void infer(Model model, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
        acceptor.accept(model.toClass(model.getJavaClassName)) [
            for(variable: model.variables) {
                members += variable.toField(variable.name, variable.type)
    def getJavaClassName(Model it) {
        getPackageName+'.'+eResource.URI.trimFileExtension.lastSegment
    def getPackageName(Model it) {
        eResource.allContents.filter(Package).head.name
The resulting java code seems to not be able to resolve the "com.example.Doer" class:
public class MyFile {
  private /* Doer */Object doer;
If the "Doer" class is defined as a regular java file, instead of being compiled on-the-fly, everything is OK.
Are there any restriction on the type of class loader I can use?
Is this the right way to use a custom class loader?
Previous Topic:Changing the Qualified name based on reference
Next Topic:Content Assistant in a Xtext custom language
Current Time: Sat Jul 19 01:25:43 EDT 2025
Powered by FUDForum. Page generated in 0.03041 seconds
