Home » Eclipse Projects » Sirius » Element selection in Open Dialog
Element selection in Open Dialog [message #1769527] Tue, 01 August 2017 06:32 Go to next message
Hi there,
I have implemented an Open Dialog to edit the properties of an object. In my dialogue, I wish to have a way of viewing + selecting model elements within the model, and set properties with the selected model element(s). Is there a way of doing it, please?
William
Re: Element selection in Open Dialog [message #1769543 is a reply to message #1769527] Tue, 01 August 2017 08:50 Go to previous message
You can view and select model elements in the model and modify their properties from a dialog. You could for that use a select widget along with dynamic mappings to view and edit the properties of your model. Or you could just configure the proper widgets directly. It depends on your model elements and their type.
Stephane Begaudeau
Previous Topic:NPE in EdgeLabelQuery when moving node
Next Topic:[RESOLVED] Label AQL statement problem
Current Time: Sat Jul 26 12:06:10 EDT 2025
Powered by FUDForum. Page generated in 0.26112 seconds
