Home » Eclipse Projects » Remote Application Platform (RAP) » BundleException after switching from RAP 3.2 M4 to RAP 3.2 M5
BundleException after switching from RAP 3.2 M4 to RAP 3.2 M5 [message #1769385] Mon, 31 July 2017 05:01 Go to next message
Hi experts,
recently I "won" the task of setting up a new development environment with a new Eclipse and a new RAP version. Unfortunately, our RAP expert is currently enjoying his well-deserved vacation.
Eclipse old: Mars
RAP old: Version 3.0.2
Eclipse new: Oxygen
RAP new: 3.2.0
Using Oxygen, everything works hunky dory up to and including RAP 3.2 M4. As of RAP 3.2 M5 our application won't start due to a BundleException.
I have (of course) checked the "New and notworthy" page of RAP 3.2 M5, but I haven't seen anything there to make me believe I need to change anything in addition to changing the Eclipse target version if I want to use M5.
I am not a huge fan of posting stacktraces, but since I do not feel confident enough to figure out what exactly I could ask without looking dumb, please allow me to do so anyway. Any pointers and hints will be much appreciated.
Thanks a lot in advance
Frank
org.osgi.framework.BundleException: Could not resolve module: com.heidelberg.st.console.webserver [24]
Unresolved requirement: Require-Bundle: com.heidelberg.st.console.common; bundle-version="1.0.0"
-> Bundle-SymbolicName: com.heidelberg.st.console.common; bundle-version="1.0.0.qualifier"
com.heidelberg.st.console.common [42]
Unresolved requirement: Import-Package: org.eclipse.ui.plugin
-> Export-Package: org.eclipse.ui.plugin; bundle-symbolic-name="org.eclipse.rap.ui.workbench"; bundle-version="3.2.0.20170410-1123"; version="0.0.0"
org.eclipse.rap.ui.workbench [33]
Unresolved requirement: Require-Bundle: org.eclipse.equinox.http.registry
-> Bundle-SymbolicName: org.eclipse.equinox.http.registry; bundle-version="1.1.400.v20150715-1528"; singleton:="true"
org.eclipse.equinox.http.registry [59]
Unresolved requirement: Import-Package: org.osgi.service.http; version="1.2.0"
-> Export-Package: org.osgi.service.http; bundle-symbolic-name="org.eclipse.osgi.services"; bundle-version="3.6.0.v20170228-1906"; version="1.2.1"; uses:="javax.servlet,javax.servlet.http"
org.eclipse.osgi.services [61]
Unresolved requirement: Import-Package: org.osgi.util.function; version="[1.0.0,2.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.osgi.services
-> Bundle-SymbolicName: org.eclipse.osgi.services; bundle-version="3.6.0.v20170228-1906"
Unresolved requirement: Import-Package: org.eclipse.rap.rwt.osgi; version="[3.2.0,4.0.0)"
-> Export-Package: org.eclipse.rap.rwt.osgi; bundle-symbolic-name="org.eclipse.rap.rwt.osgi"; bundle-version="3.2.0.20160811-0840"; version="3.2.0"
org.eclipse.rap.rwt.osgi [50]
Unresolved requirement: Import-Package: org.osgi.service.http; version="[1.2.0,2.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.equinox.http.servlet; bundle-version="1.0.100"
-> Bundle-SymbolicName: org.eclipse.equinox.http.servlet; bundle-version="1.4.0.v20170524-1452"
org.eclipse.equinox.http.servlet [64]
Unresolved requirement: Import-Package: org.apache.commons.fileupload; version="[1.2.2,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.apache.commons.fileupload.disk; version="[1.2.2,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.apache.commons.fileupload.servlet; version="[1.2.2,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.osgi.service.http; version="[1.2.0,1.3.0)"
Unresolved requirement: Require-Bundle: com.heidelberg.st.console.lispreferences; bundle-version="1.0.0"
-> Bundle-SymbolicName: com.heidelberg.st.console.lispreferences; bundle-version="1.0.0.qualifier"; singleton:="true"
com.heidelberg.st.console.lispreferences [30]
Unresolved requirement: Require-Bundle: com.heidelberg.st.console.repository; bundle-version="1.0.0"
-> Bundle-SymbolicName: com.heidelberg.st.console.repository; bundle-version="1.0.0.qualifier"; singleton:="true"
com.heidelberg.st.console.repository [28]
Unresolved requirement: Require-Bundle: com.heidelberg.st.console.model.workflow; bundle-version="1.0.0"
-> Bundle-SymbolicName: com.heidelberg.st.console.model.workflow; bundle-version="1.0.0.qualifier"
com.heidelberg.st.console.model.workflow [7]
Unresolved requirement: Require-Bundle: org.eclipse.equinox.http.registry; bundle-version="1.0.100"
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1628)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1608)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1579)
at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:264)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:188)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402)
at org.eclipse.osgi.launch.Equinox.start(Equinox.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:326)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:239)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
[Updated on: Mon, 31 July 2017 10:26] by Moderator
Re: BundleException after switching from RAP 3.2 M4 to RAP 3.2 M5 [message #1769470 is a reply to message #1769385] Mon, 31 July 2017 17:12 Go to previous message
Have you done an "ss" on the osgi console to make sure all the bundles you expect to be active are in fact active?
You might get a more informative error if you manually try and restart your bundle via the console with "start <bundle-id>"
Previous Topic:Persisted State with new RAP e4 3.2
Next Topic:Rap e4 movable parts
Current Time: Sat Jul 26 11:34:36 EDT 2025
Powered by FUDForum. Page generated in 0.04611 seconds
