Home » Eclipse Projects » Eclipse Titan » There is no local or imported definition with name(LTE, TTCN3, TITAN, RRC)
There is no local or imported definition with name [message #1769300] Fri, 28 July 2017 15:32 Go to next message
Dear Experts,
I am also new TTCN and TITAN. I have followed the example given in [https://www.eclipse.org/forums/index.php/m/1769027/#msg_1769027] but cannot compile the source code used in that example. I have attached that code with few changes.
I made following changes to Makefile.am.sample" within EUTRA_EncDec folder.
CFLAGS += -I.
$(TARGET): ${OBJS}
$(CC) $(CFLAGS) -DPDU=DL-CCCH-Message -o $(TARGET) ${OBJS} $(LDFLAGS) $(LIBS)
.c.o:
$(CC) $(CFLAGS) -DPDU=DL-CCCH-Message -o $@ -c $<
and then run "make -f Makefile.am.sample" within EUTRA_EncDec folder. The code compiled successfully (no errors).
But when I run "make" within /bin folder, i get following errors:
error: Cannot recognize file `RRC_ConnEst.ttcn' as an ASN.1 or TTCN-3 module. Use the command-line switch `-A' or `-T' to set its type.
error: Cannot recognize file `RRC_ConnRel_C2K.ttcn' as an ASN.1 or TTCN-3 module. Use the command-line switch `-A' or `-T' to set its type.
... and so on.
To resolve this I commented default COMPILER_FLAGS and used -T instead in Makefil at /bin folder.
#COMPILER_FLAGS = -L -l -d -M
COMPILER_FLAGS = -T
Note that I am only compiling one TTCN module
TTCN3_MODULES = RRC_ConnEst.ttcn
and also commented ASN.1 modules to suppress -A errors.
However, I get following errors
can you please let me know where did I make mistake.
RRC_ConnEst.ttcn:1176.5-70: error: There is no local or imported definition with name `f_EUTRA_PreliminaryPass'
and so on ...
Can you please guide me how to resolve these errors and compile basic TTCN3 functionality (using TITAN)
thank you.
taqi
Re: There is no local or imported definition with name [message #1769315 is a reply to message #1769300] Sat, 29 July 2017 05:26 Go to previous message
Hi taqi,
to start with, your Makefile is inconsistent: it should contain all ASN.1, TTCN-3 and C/C++ files to be used in compilation;
to achieve this , you should for instance create symlinks to all files in the bin directory and then run
makefilegen *.ttcn *.asn *.cc *.hh *.c  *.h
This will generate the appropriate Makefile.
For your compilation to be consistent you will need all the external code written in C/C++ such as codecs, test ports, external functions.
If any of these is missing, compilation will fail.
Please read this post:
About compiling 3GPP and ETSI test suites
https://www.eclipse.org/forums/index.php/t/1087046/
for more info.
Assembling an LTE test suite and writing the test ports, codecs etc. is rather complex, it's long hours of work and requires a degree of familiarity with ASN.1 , TTCN-3 , C/C++, Titan itself and so on,
hence is definitely not something I'd recommend for a beginner.
Best regards
Elemer
Previous Topic:Eclipse Titan and the dilemma of PER-encoding
Next Topic:Support for MongoDB
Current Time: Sun Jul 27 02:28:26 EDT 2025
Powered by FUDForum. Page generated in 0.04805 seconds
