Home » Modeling » TMF (Xtext) » Efficient way of loading an EMF resource at start-up?
Efficient way of loading an EMF resource at start-up? [message #1769187] Thu, 27 July 2017 07:23 Go to next message
I want to extend the AST of my DSL with dynamically calculated content. This additional code realize some sort of "build-in" library which is created at start-up time and is used during scoping. I have found information about attaching a resource in standalone-applications but the "build-in" lib should also be loaded in the Eclipse plugin. Loading a static DSL source code file is also not an option because I want to create the lib dynamically.
Here is what I have done so far....
class Lib {
    @Inject Provider<XtextResourceSet> resourceSetProvider
    @Inject IResourceScopeCache cache
    def Resource load() {
        val XtextResourceSet resourceSet = resourceSetProvider.get
        val resource = resourceSet.createResource(URI.createURI("dummy:/lib.mydsl"))
        cache.get("load", resource, [
                val InputStream in = new ByteArrayInputStream(" /* 'dynamic' DSL code ('build-in lib') */".getBytes("UTF8"))
                resource.load(in, resourceSet.getLoadOptions())
                return resource
    // called by scope provider
    def calc() {
        val resource = load()
        cache.get("calc", resource, [ /* calculations based on the loaded resource */ ]
- Is this the correct way of loading an EMF resource at runtime?
- The cache is useless. I have measured the time executing calc() with and without cache and there has been no difference. How can I cache the resource loading and the calculation?
Re: Efficient way of loading an EMF resource at start-up? [message #1769189 is a reply to message #1769187] Thu, 27 July 2017 07:30 Go to previous messageGo to next message
can you elaborate on when and how this transformation can be done.
does it need any information from the ast or not?
what is the actual performance problem you face?
why not doing in the constructor / static initializer of the scope provider
or have a singleton eager binding in your module
why do you need to "load" at all if you create it programmatically?
[Updated on: Thu, 27 July 2017 07:43] by Moderator
Re: Efficient way of loading an EMF resource at start-up? [message #1769192 is a reply to message #1769189] Thu, 27 July 2017 08:58 Go to previous messageGo to next message
My application creates a library for the DSL user. Due to performance issues in the Eclipse plugin (typing gets terrible slow for huge files) I want to speed-up things by putting some stuff in a build-in library for which I can pre-calculate some things. The build-in library doesn't depend on other resources (no imports) which (as I understand it correctly) makes it a perfect candidate for caching.
> Do you have examples for your suggestions? I have my own scope provider and overloaded the getScope() method. If I put things in the constructor I have the problem that resourceSetProvider gets injected and injected members are null in the constructor.
I want to "load" the build-in lib because so I can handle the build-in library like any other DSL source code and I do not need to re-implement algorithms.
Re: Efficient way of loading an EMF resource at start-up? [message #1769194 is a reply to message #1769192] Thu, 27 July 2017 09:34 Go to previous messageGo to next message
i think simply annotation a util with @Singleton should do the trick
Re: Efficient way of loading an EMF resource at start-up? [message #1769196 is a reply to message #1769194] Thu, 27 July 2017 09:36 Go to previous messageGo to next message
adding the libary as a jar to the classapth is not an option?
Re: Efficient way of loading an EMF resource at start-up? [message #1769256 is a reply to message #1769196] Fri, 28 July 2017 06:08 Go to previous messageGo to next message
Thanks Christian, @Singleton was a good tip... I now try to integrate the lib-loading in the Activator class. I have derived from the generated MyDslActivator class and extend the start() method by calling my load() method to load the build-in resource. I inject the library by
@Inject extension Lib lib
but this is the problem. The injection mechanism seams to run later and lib is null. How can I solve this problem?
Re: Efficient way of loading an EMF resource at start-up? [message #1769260 is a reply to message #1769256] Fri, 28 July 2017 06:47 Go to previous messageGo to next message
no that approach would not involve the activator
in the lib you would simply do the loading on first access or on a method annoted with @Inject.
still my question: why not put a jar with lib files on the classpath?
[Updated on: Fri, 28 July 2017 06:48] by Moderator
Re: Efficient way of loading an EMF resource at start-up? [message #1769304 is a reply to message #1769260] Fri, 28 July 2017 18:26 Go to previous messageGo to next message
OK, I understand. It works if I use the cache and always call load() in my calc() function but it should not be necessary. The load() function should be called once by Guice so I have rewritten my code. The problem is that the "resourceSet.createResource(..)" call triggers the load() method again and again (if the createResource() call is missing load() is executed once as expected). Do you know why is this the case and how I can circumvent this?
Regarding your question... Yes, creating the library as an external resource would be possible but I think it is cleaner to don't go the extra detour around an external file. It is also makes unit testing easier....
@Singleton
class Lib {
    var Resource resource
    @Inject
    def void load() {
Re: Efficient way of loading an EMF resource at start-up? [message #1769307 is a reply to message #1769304] Sat, 29 July 2017 01:15 Go to previous messageGo to next message
Other Utils that do that manage a loaded / is loading state
Re: Efficient way of loading an EMF resource at start-up? [message #1769308 is a reply to message #1769307] Sat, 29 July 2017 01:17 Go to previous messageGo to next message
And maybe you should no load on startup but on first use.
And use a loaded / is loading state
Re: Efficient way of loading an EMF resource at start-up? [message #1769314 is a reply to message #1769308] Sat, 29 July 2017 05:18 Go to previous messageGo to next message
just gave it a try and something like this could work
@Singleton
class Lib {
    def void load() {
        val InputStream in = new ByteArrayInputStream("Hello World!".getBytes("UTF8"))
    def getAllGreetings() {
    	return (resource.contents.head as Model).greetings
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
	static class LibTypeListener implements TypeListener {
		override <I> void hear(TypeLiteral<I> typeLiteral, TypeEncounter<I> typeEncounter) {
			typeEncounter.register(([Object i|var Lib m = (i as Lib) m.load()] as InjectionListener<I>))
	def void configurePostConstructListener(Binder binder) {
		binder.bindListener(new AbstractMatcher<TypeLiteral<?>>() {
			override boolean matches(TypeLiteral<?> typeLiteral) {
				return typeof(Lib).isAssignableFrom(typeLiteral.getRawType())
		}, new LibTypeListener())
Re: Efficient way of loading an EMF resource at start-up? [message #1769328 is a reply to message #1769187] Sat, 29 July 2017 12:06 Go to previous messageGo to next message
This does not work... :( The load() method is called mysteriously again and again. Do you have any idea what is happening behind the curtain. Yes, I could manage a state but I would have a better feeling to know what is going on.
Re: Efficient way of loading an EMF resource at start-up? [message #1769333 is a reply to message #1769328] Sat, 29 July 2017 15:46 Go to previous messageGo to next message
Can you give a complete example of what you are doing
Re: Efficient way of loading an EMF resource at start-up? [message #1769612 is a reply to message #1769333] Wed, 02 August 2017 04:17 Go to previous messageGo to next message
I have tried your example above but the load() method gets called, which calls the createResource() and this seams to trigger the load() method again...
Re: Efficient way of loading an EMF resource at start-up? [message #1769613 is a reply to message #1769612] Wed, 02 August 2017 04:19 Go to previous message
as i said i would need a complete example and a step by step guide
Previous Topic:Defining subtypes without unsigned rule calls
Next Topic:Dependency error while upgrading to 2.12
Current Time: Sat Sep 20 14:25:46 EDT 2025
Powered by FUDForum. Page generated in 0.24909 seconds
