Home » Eclipse Projects » Lyo » A javax.ws.rs.ext.MessageBodyReader implementation was not found for class org.eclipse.lyo.oslc4j.co(A javax.ws.rs.ext.MessageBodyReader implementation was not found for class org.eclipse.lyo.oslc4j.core.model.ServiceProviderCatalog type)
A javax.ws.rs.ext.MessageBodyReader implementation was not found for class org.eclipse.lyo.oslc4j.co [message #1768843] Mon, 24 July 2017 06:08 Go to next message
I have followed the wiki page {https://wiki.eclipse.org/Lyo/BuildClient} and setup the
Eclipse Lyo project in my workspace. I have run the Maven clean install.
I have modified the RRCFormSample.java for my requirement and able to run in the
Eclipse environment successfully with you any problem.
Now I want to make the sources to run in command line. I have created the
runnable Jar (org.eclipse.lyo.client.java.sample) by adding the following
in pom.xml of org.eclipse.lyo.client.java.sample.
<plugin>
<artifactId>maven-assembly-plugin</artifactId>
<version>2.6</version>
<configuration>
<archive>
<manifest>
<mainClass>org.eclipse.lyo.client.oslc.samples.RRCFormSample</mainClass>
</manifest>
</archive>
<descriptorRefs>
<descriptorRef>jar-with-dependencies</descriptorRef>
</descriptorRefs>
</configuration>
<executions>
<execution>
<id>make-assembly</id> <!-- this is used for inheritance merges -->
<phase>package</phase> <!-- bind to the packaging phase -->
<goals>
<goal>single</goal>
</goals>
</execution>
</executions>
</plugin>
<plugin>
<!-- <groupId>org.apache.maven.plugins</groupId>-->
<artifactId>maven-dependency-plugin</artifactId>
<executions>
<execution>
<id>copy-dependencies</id>
<phase>install</phase>
<goals>
<goal>copy-dependencies</goal>
</goals>
<configuration>
<outputDirectory>${project.build.directory}\lib</outputDirectory>
<overWriteReleases>false</overWriteReleases>
<overWriteSnapshots>false</overWriteSnapshots>
<overWriteIfNewer>true</overWriteIfNewer>
</configuration>
</execution>
</executions>
</plugin>
<plugin>
<artifactId>maven-jar-plugin</artifactId>
<configuration>
<archive>
<manifest>
<addClasspath>true</addClasspath>
<classpathPrefix>lib/</classpathPrefix>
</manifest>
</archive>
</configuration>
</plugin>
The required libraries are copied and unpacked as class files. Please have a look on
the attachment (lib.zip, oslc-java-samples-2.1.2-jar-with-dependencies.jar).
Later when I run in command line mode (Batch script) get the
following Exception
and text/html; charset=UTF-8 media type. Verify that all entity providers are correctly registered. Add a custom javax.ws.rs.ext.MessageBodyRea
der provider to handle the type and media type if a JAX-RS entity provider does not currently exist.
java.lang.RuntimeException: A javax.ws.rs.ext.MessageBodyReader implementation was not found for class org.eclipse.lyo.oslc4j.core.model.ServiceP
roviderCatalog type and text/html; charset=UTF-8 media type. Verify that all entity providers are correctly registered. Add a custom javax.ws.r
s.ext.MessageBodyReader provider to handle the type and media type if a JAX-RS entity provider does not currently exist.
at org.apache.wink.client.internal.handlers.ClientResponseImpl.readEntity(ClientResponseImpl.java:122)
at org.apache.wink.client.internal.handlers.ClientResponseImpl.getEntity(ClientResponseImpl.java:65)
at org.apache.wink.client.internal.handlers.ClientResponseImpl.getEntity(ClientResponseImpl.java:52)
at org.eclipse.lyo.client.oslc.OslcClient.lookupServiceProviderUrl(OslcClient.java:470)
at org.eclipse.lyo.client.oslc.samples.RRCFormSample.main(RRCFormSample.java:124)
#1 Is this Bug in Ecliplse Lyo 2.1.2 ?
#2) Do we have somewhere list of jars required for particular Eclipse Lyo version to run in command line ?
For example where I can download list of Jars for
Eclipse Lyo 2.1.0 release or Eclipse Lyo 2.2.0 release ?
#3 Did I miss some libraries to include to run org.eclipse.lyo.client.oslc.samples.RRCFormSample.java ?
Best Regards,
Rajkumar
[Updated on: Mon, 24 July 2017 07:05] by Moderator
Re: A javax.ws.rs.ext.MessageBodyReader implementation was not found for class org.eclipse.lyo.oslc4 [message #1768854 is a reply to message #1768843] Mon, 24 July 2017 07:06 Go to previous messageGo to next message
Attached lib.zip
Re: A javax.ws.rs.ext.MessageBodyReader implementation was not found for class org.eclipse.lyo.oslc4 [message #1768859 is a reply to message #1768854] Mon, 24 July 2017 08:30 Go to previous messageGo to next message
Hi Rajkumar,
I think the problem is that your response for the ServiceProviderCatalog resource is not in RDF (application/rdf+xml) but in HTML (text/html, as indicated in your response). So the error is that there is no such class registered that can parse html AND create an instance of the ServiceProviderCatalog class for you. Please note this is NOT a ClassNotFoundException.
If it works in the IDE, though, that might be because you have environment/system variables set in your launch config etc.?
/Andrew
P.S. I think you are messing too much with the libraries folder etc. Try following https://www.mkyong.com/maven/create-a-fat-jar-file-maven-assembly-plugin/
Re: A javax.ws.rs.ext.MessageBodyReader implementation was not found for class org.eclipse.lyo.oslc4 [message #1768928 is a reply to message #1768859] Tue, 25 July 2017 01:07 Go to previous message
Hi Andrew,
Many thanks for your hint and your hint solved my problem :)
Yes you are right the response in the command line client doesn't returns RDF
(application/rdf+xml) content type . After debugging command line client the server
responses text/html response due to authentication was failed since I have not
provided the valid password in the command line client.
Thank you for you support. Have a nice day!
Best Regards,
Rajkumar
Previous Topic:Issue with Lyo Code Generator & Toolchain installation
Next Topic:[Polarion] Connection between OSLC-Server and Consumer
Current Time: Sun Jul 20 20:37:35 EDT 2025
Powered by FUDForum. Page generated in 0.25779 seconds
