Home » Eclipse Projects » WindowBuilder » WindowBuilder in Eclipse Java Oxygen
WindowBuilder in Eclipse Java Oxygen [message #1768503] Wed, 19 July 2017 10:08 Go to next message
I'm running Oxygen on a Mac and have added WindowBuilder. The WindowBuilder editor displays in a small font. I would like to increase its font size. But I have not been able to figure out how do so. Any advice would be greatly appreciated. (By the way, I can change the font size on the Java editor that is part of Oxygen.)
Re: WindowBuilder in Eclipse Java Oxygen [message #1768695 is a reply to message #1768503] Fri, 21 July 2017 13:26 Go to previous messageGo to next message
Which "editor" do you mean? Can you provide a screenshot of it?
Re: WindowBuilder in Eclipse Java Oxygen [message #1768777 is a reply to message #1768695] Sun, 23 July 2017 15:35 Go to previous messageGo to next message
I having the problem with the editor that is in WindowBuilder. It's font is tiny and I can't figure out how to change its size. I tried to take a screenshot as you requested, but I'm new to Macs. I couldn't do it. Nevertheless, I assure you the the font size is very small. Many thanks for your help.
Re: WindowBuilder in Eclipse Java Oxygen [message #1768900 is a reply to message #1768777] Mon, 24 July 2017 14:16 Go to previous messageGo to next message
OS X has an utility called Grab. It has instructions in the Help pages.
Re: WindowBuilder in Eclipse Java Oxygen [message #1778002 is a reply to message #1768503] Thu, 07 December 2017 10:15 Go to previous messageGo to next message
Hi there,
the problem is the same on Linux using Oxygen.1 + recent WindowBuilder.
I can change the font size for the regular Java Editor in Prefs / GEneral / Appearance / Colors and Fonts / Basic / Text Font. This works fine for now SWING classes (as well as the common CTRL-+, CTRL-- shortcuts).
The font size in the Source tab of a Window builder file is not affected by the above setting, nor do above shortcuts work.
For teaching my classes, I would highly appreciate the shortcuts to work as well for the WindowBuilder editor (it worked on Neon, I guess).
Bets regards
Sven
Re: WindowBuilder in Eclipse Java Oxygen [message #1778010 is a reply to message #1778002] Thu, 07 December 2017 13:02 Go to previous messageGo to next message
just an affirmation addon: editor fontsize changes work perfectly well in windowbuilder/swing designer 1.9 on eclipse neon.3
Re: WindowBuilder in Eclipse Java Oxygen [message #1783451 is a reply to message #1768503] Tue, 13 March 2018 06:01 Go to previous messageGo to next message
In case anyone still has this issue, the WindowBuilder font size is located at:
Window > Preferences > General > Appearance > Colors & Font > Basic > Text Font.
Re: WindowBuilder in Eclipse Java Oxygen [message #1797257 is a reply to message #1783451] Mon, 29 October 2018 05:53 Go to previous messageGo to next message
[ Window > Preferences > General > Appearance > Colors & Font > Basic > Text Font. ]
[ Window > Preferences > General > Appearance > Colors & Font > Java > Java Editor Text Font. ]
These settings does not work for me.
I mean, I want to change the font of SWT Editor's source tab.
I still don't know how to change the font.
I'm Japanese.
From Photon, default Japanese font has become garbled.
So this is critical issue for me.
Does anyone solve this problem yet?
Thank you very much in advance.
My Environment :
Eclipse Photon 4.8.0
Window Builder (and SWT Designer) 1.9.1
Re: WindowBuilder in Eclipse Java Oxygen [message #1799556 is a reply to message #1797257] Mon, 10 December 2018 03:19 Go to previous messageGo to next message
I am also a Japanese.
I have a similar problem.
Are you solving this problem?
Re: WindowBuilder in Eclipse Java Oxygen [message #1817168 is a reply to message #1799556] Sun, 17 November 2019 10:10 Go to previous messageGo to next message
Please follow the order below,
Window >> Preferences >> General >> Appearance >> Colors and Fonts >> Basic >> Text Fonts
then you can edit the font size. Have a try.
Re: WindowBuilder in Eclipse Java Oxygen [message #1827612 is a reply to message #1817168] Tue, 19 May 2020 06:20 Go to previous messageGo to next message
Any updates on this? I've got the same font for "Text Font" and "Java Editor Text Font" but the WindowBuilder source editor still uses a larger font than regular java editors (see attached screenshot).
Using Eclipse 2020-03 on (sadly) Win10.
Re: WindowBuilder in Eclipse Java Oxygen [message #1831292 is a reply to message #1827612] Sun, 16 August 2020 18:21 Go to previous messageGo to next message
Still a problem in 2020-06.
Nothing seems to affect the font size in the WindowBuilder "source" tab.
Here's a screengrab of a Java editor window with the text font set to Consolas 14
index.php/fa/38778/0/
And here is the same general area in the WindowBuilder "Source" tab
index.php/fa/38779/0/
  • Attachment: eclipse16.png
    (Size: 26.72KB, Downloaded 1453 times)
  • Attachment: eclipse17.png
    (Size: 31.42KB, Downloaded 1512 times)
Re: WindowBuilder in Eclipse Java Oxygen [message #1833939 is a reply to message #1768503] Wed, 28 October 2020 10:14 Go to previous message
2020 October
I also have this problem.
Still no solution or bug fix for this?
Previous Topic:Working example for two way databinding
Next Topic:WB added org.eclipse.wb.swt.SWTResourceManager.java SOURCE to my project?
Current Time: Sun Jul 20 09:09:47 EDT 2025
Powered by FUDForum. Page generated in 0.07260 seconds
