Home » Eclipse Projects » Lyo » Nested properties with select(Binding nested properties from select)
Nested properties with select [message #1768519] Wed, 19 July 2017 12:17 Go to next message
I built a client to interface with RTC using OSLC Change Management Version 2. I am able to deserialize the response to a ChangeRequest object using the old 2.1.0 templates.
If I set select to "dcterms:creator{foaf:name}" in the query, I get back the creator rdf:resource URI in the ChangeRequest rdf:Description and the Person type within its own rdf:Description. For example:
<rdf:Description rdf:about="removed for URL posting restrictions">
<rdf:type rdf:resource="removed for URL posting restrictions" />
<foaf:name rdf:datatype="removed for URL posting restrictions">John Smith</foaf:name>
</rdf:Description>
<dcterms:creator rdf:resource="removed for URL posting restrictions" />
</rdf:Description>
I am able to set the creator as that was already included in the ChangeRequest DTO. I have made a Person DTO and set it as the type for a new field called creatorName in the ChangeRequest DTO but I cannot get it to bind.
Any ideas how I might solve this?
Thank you,
Justin
Re: Nested properties with select [message #1773965 is a reply to message #1768519] Sat, 07 October 2017 13:05 Go to previous messageGo to next message
Sorry, Justin, I have no working experience with RTC.
Re: Nested properties with select [message #1774778 is a reply to message #1773965] Thu, 19 October 2017 10:19 Go to previous message
Simply a question. Did I understand it right, that you've created a custom attribute of type creator for the RTC ChangeRequest?
Then I guess the value you got in the ChangeRequest RDF should be the same you get for the built-in attribute creator, which is a link to the person resource.
Previous Topic:[Polarion] Connection between OSLC-Server and Consumer
Next Topic:Local and Global configurations
Current Time: Mon Nov 03 21:22:25 EST 2025
Powered by FUDForum. Page generated in 0.03684 seconds
