Packages in Papyrus [message #1767888] |
Tue, 11 July 2017 21:23  |
I'm working with models Product Line Architecture and when I try to create one, I can't. When I click in the diagram appears two times "Create Package" and neither of them works.
I really need some help.
Thanks!
Re: Packages in Papyrus [message #1768358 is a reply to message #1768345] |
Mon, 17 July 2017 16:14   |
To add to what Carsten stated, I've also heard the term in a larger context when determing the "kind" of variability to use with and across product lines, e.g., variability by boundary (e.g., API, Comm protocol, etc.), variability by composition, Dynamic/static, etc. One could argue that some are similar, but their usage may vary.
I've also heard this mentioned in terms of governance, especiallly in industries that have more than one variability "dimension" (e.g., within a product line, across complementary product lines, within a supply chain). In some respect, some of these discussion bordered on enterprise architecture.
And then again, I've heard is used as a synonym for product line management.
Re: Packages in Papyrus [message #1768502 is a reply to message #1768361] |
Wed, 19 July 2017 10:02  |
I am not aware of any exlicit limitations. Furthermore Papyrus features a mechanism to subdivide a model into submodels. This mechanism uses the lazy loading to shorten start-up time and lessen memory usage.
FUDForum. Page generated in 0.04163 seconds
