Design question: searching for things (getThingByUID) [message #1768281] |
Sun, 16 July 2017 16:20  |
Hallo,
In the new binding I am writing for OH2, devices are identified as:
mybinding:deviceType:bridgeID:deviceID
where deviceID is the unique ID used to identify devices in the network protocol I am integrating, while deviceType is set during Thing discovery phase.
Then when a new device event arrives from the network protocol I need to associate the event to the Thing/ThingHandler, so I need to use getThingByUID() in the bridge handler.
However, I cannot search for the Thing as the network protocol event does not bring any info on the device type, only the deviceID.
So I cannot associate network protocol events coming from a specific deviceID with the corresponding Thing in ESH.
What is the right design approach to be used?
OPTIONS:
1) I could avoid using deviceType in the ThingUID:
mybinding:bridgeID:deviceID
but this way the UI/user will miss the info that this device is of that specific deviceType.
2) Another option would be to have a more flexible method getThingByUID capable of finding Things also with "*" search, for example:
getThingByUID("mybinding:*:bridgeID:deviceID")
to find the Thing with ID=deviceID, regardless of its specific type.
Any other suggestion?
Thanks a lot,
Massi
Re: Design question: searching for things (getThingByUID) [message #1773804 is a reply to message #1768512] |
Wed, 04 October 2017 16:07  |
Thanks Stefan, I implemented the suggested behaviour and it works.
While I was coding, I was thinking that since this "deviceID -> thing handler" mapping is possibly common to many bindings, it should be already supported by the ESH core.
In addition I see that there is a 'representation-property' that I probably should use to make sure the same device is not discovered twice.
Is this the expected usage of this type of properties?
thanks
Massi
FUDForum. Page generated in 0.06263 seconds
