Home » Eclipse Projects » Eclipse Platform » Branding not upgraded(Branding not upgraded when migrating from Neon to Oxygen)
Branding not upgraded [message #1768128] Thu, 13 July 2017 15:25 Go to next message
Recently did a full upgrade from Neon.3 to Oxygen, and everything seems fine so far.
However, the splash screen is still Neon.3 and Help->About Eclipse still shows Neon.3.
It would be nice if Eclipse could recognize that it has been upgraded past a new release version and update the branding.
Is there a way to achieve this without downloading the entire Oxygen package?
EDIT: Until this is addressed, here is an inspirational temporary splash.
Download the attached splash.bmp and copy to eclipse/plugins/eclipse-platform-xx/splash.bmp
http://standard3d.com/assets/img/splash.bmp
  • Attachment: splash.bmp
    (Size: 394.22KB, Downloaded 186 times)
[Updated on: Fri, 14 July 2017 15:20] by Moderator
Re: Branding not upgraded [message #1768197 is a reply to message #1768128] Fri, 14 July 2017 10:02 Go to previous message
I observe similar behavior. I still see the Neon.3 splash screen and icon after upgrading to Oxygen. Help -> About Eclipse does say I am on Oxygen, however.
I have filed a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=519697
Previous Topic:adding a new VM to installed JRE workbench
Next Topic:JDK installed to ram drive causing build errors
Current Time: Mon Jul 21 07:21:24 EDT 2025
Powered by FUDForum. Page generated in 0.03098 seconds
