Home » Eclipse Projects » Virgo » Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error(Deploy multiples bundles in on plan generates resolution error)
Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1746738] Thu, 03 November 2016 18:03 Go to next message
Guys,
I have a plan with some bundles that fail during deploy.
I'm using virgo 3.7.0.M01 because my app uses Spring 3.1.0. During the tests I realized that virgo hangs to resolve dependencies during deploy and after that genereates a dump file and process is stopped. Due to this, I removed some bundles from plan and tried deploy again. After some tries, I realized that when I add a new bundle the virgo generates a error dump, but after restart the server the error no happens.
The error happens after this process:
o.e.virgo.kernel.userregion.internal.quasi.DependencyCalculator   Calculating missing dependencies of bundle
org.eclipse.virgo.medic.eventlog.default                         ME0003I Dump 'serviceability/dump/2016-11-03-20-16-436' generated
At summary.txt I can see:
Cause: resolutionFailure
Exception: None
How can I explore more the dump?
This is the header of my plan:
<plan name="multiple.plan" version="2.0.0" scoped="false" atomic="false"
    xmlns="http://www.eclipse.org/virgo/schema/plan"
    xsi:schemaLocation="http://www.eclipse.org/virgo/schema/plan http://www.eclipse.org/virgo/schema/plan/eclipse-virgo-plan.xsd">
</plan>
[Updated on: Thu, 03 November 2016 18:17] by Moderator
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1746799 is a reply to message #1746738] Fri, 04 November 2016 13:03 Go to previous messageGo to next message
I have no figure out the issue, but today I let the virgo running after generating of dump and after 20 minutos virgo throws the conflict error, but I didn't understand why this is happening and I why we have the same libraries of spring in plugins folder and repository/ext folder.
What is the difference between this two folders?
org.springframework.aop_3.1.0.RELEASE.jar
org.springframework.asm_3.1.0.RELEASE.jar
org.springframework.beans_3.1.0.RELEASE.jar
org.springframework.context_3.1.0.RELEASE.jar
org.springframework.core_3.1.0.RELEASE.jar
org.springframework.expression_3.1.0.RELEASE.jar
Uses violation: <Import-Package: org.springframework.beans; version="[3.0.0,3.2.0)"> in bundle
            Found conflicts:
                package        'org.springframework.asm_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[58]' used by 'org.springframework.beans_3.1.0.RELEASE' in bundle 'org.springframework.beans_3.1.0.RELEASE[59]'
                conflicts with 'org.springframework.asm_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[117]' used by 'org.springframework.jdbc.core_3.1.0.RELEASE' in bundle 'org.springframework.jdbc_3.1.0.RELEASE[122]'
                conflicts with 'org.springframework.asm_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[117]' used by 'org.springframework.core.type.classreading_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[120]'
                package        'org.springframework.asm.commons_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[58]' used by 'org.springframework.beans_3.1.0.RELEASE' in bundle 'org.springframework.beans_3.1.0.RELEASE[59]'
                conflicts with 'org.springframework.asm.commons_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[117]' used by 'org.springframework.jdbc.core_3.1.0.RELEASE' in bundle 'org.springframework.jdbc_3.1.0.RELEASE[122]'
                package        'org.springframework.core_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[61]' used by 'org.springframework.beans_3.1.0.RELEASE' in bundle 'org.springframework.beans_3.1.0.RELEASE[59]'
                conflicts with 'org.springframework.core_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[120]' used by 'org.springframework.jdbc.core_3.1.0.RELEASE' in bundle 'org.springframework.jdbc_3.1.0.RELEASE[122]'
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1748677 is a reply to message #1746799] Sat, 26 November 2016 10:48 Go to previous messageGo to next message
You should really read the documentation carefully to understand how Virgo works and is built:, especially the Virgo Concepts section will be helpful to answer your question: https://www.eclipse.org/virgo/documentation/virgo-documentation-3.6.4.RELEASE/docs/virgo-user-guide/htmlsingle/virgo-user-guide.html#concepts.virgo
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1767524 is a reply to message #1748677] Thu, 06 July 2017 15:27 Go to previous messageGo to next message
I am seeing exact same symptom with 3.7.1. In my case, Virgo generates a dump and waits more than 10 minutes before printing the errors (unresolved dependencies). During this period, the Virgo process takes up 100% of the CPU. It would be nice if there is a way to get Virgo to spit out the errors immediately.
Raghu
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1767575 is a reply to message #1767524] Fri, 07 July 2017 04:37 Go to previous messageGo to next message
Hi Raghu
If you think you find a Bug in Virgo or you would like to request an Enhancement please file a Bug and we will have a look as soon as possible.
Dani
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1767603 is a reply to message #1767575] Fri, 07 July 2017 09:14 Go to previous messageGo to next message
Sure. Let me see if I can find a minimal test case.
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1767606 is a reply to message #1767603] Fri, 07 July 2017 10:16 Go to previous messageGo to next message
Actually, the problem of taking long time before resolution errors are reported doesn't seem to happen with JDK 8. My earlier testing was with JDK 7. With JDK 8, Virgo's CPU usage does spike up to 100% but only for a few seconds. So I guess we are ok here.
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1768005 is a reply to message #1767606] Wed, 12 July 2017 14:58 Go to previous messageGo to next message
Is the resolution error message the same for JDK 7 and JDK 8?
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1768006 is a reply to message #1768005] Wed, 12 July 2017 15:03 Go to previous messageGo to next message
Yes, it is.
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1768008 is a reply to message #1768006] Wed, 12 July 2017 15:11 Go to previous messageGo to next message
Can you please upload the log file so I can have a look?
Re: Virgo 3.7.0.M01 - multiple bundles into same plan generates a dump error [message #1768081 is a reply to message #1768008] Thu, 13 July 2017 09:18 Go to previous message
I don't have the log file any more as the I fixed the resolution errors and moved on. If I see it again, I will save the log. Sorry.
Previous Topic:Plan for Virgo 3.7.2?
Next Topic:Can't make per application log file work
Current Time: Mon Jul 21 11:16:15 EDT 2025
Powered by FUDForum. Page generated in 0.11531 seconds
