Home » Eclipse Projects » GEF » Why GEF uses its own GEFMessages, not the WorkbenchMessage?
Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #176685] Mon, 11 April 2005 14:40 Go to next message
Originally posted by: kevinlouisnospam.hotmail.com
WorkbenchMessages and GEFMessages have some common message, e.g.
"Workbench.copyToolTip" and "GEFMessages.CopyAction_Tooltip".
I want to see if there is any special reason why GEF does not use the
Workbench on and create its own set. I am going to use the
WorkbenchMessages only as GEF does not have cut action.
Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #176762 is a reply to message #176685] Mon, 11 April 2005 17:34 Go to previous messageGo to next message
Because WorkbenchMessages is internal.
"Kevin" <kevinlouisnospam@hotmail.com> wrote in message
news:d3eglt$mm3$1@news.eclipse.org...
> Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #176770 is a reply to message #176685] Mon, 11 April 2005 17:43 Go to previous messageGo to next message
Also, I think all the constants defined in there are new. I don't think
they were there for 3.0. I could be mistaken. Anyway, this is certainly
something GEF could look into. The only problem is that it's internal, but
maybe translations (and related bugs) are a good enough reason to make use
of internal API.
> Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #176794 is a reply to message #176762] Mon, 11 April 2005 20:44 Go to previous messageGo to next message
GEFMessages is in the org.eclipse.gef.internal too. I don't see it is a
good reason why GEFMessage is used, instead of the
org.eclipse.ui.internal.WorkbenchMessages.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d3eqr2$6a2$1@news.eclipse.org...
> > Hi,
> > Thanks,
> > Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #177096 is a reply to message #176794] Tue, 12 April 2005 15:28 Go to previous messageGo to next message
That's our internal package vs. someone else's over which we have no
control.
news:d3f60d$ihi$1@news.eclipse.org...
>> > Hi,
>> > Thanks,
>> > Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #177187 is a reply to message #177096] Tue, 12 April 2005 18:28 Go to previous messageGo to next message
Hi Randy,
In that case, why don't you provide a complete set of actions strings then?
For example, I need to implement the Cut Action, but GEFMessages only has
copy and paste. I need to use the WorkbenchMessages one.
Actually, why is the WorkbenchMessages from someone else? Is it from
Eclipse too?
Kevin
"Randy Hudson" <none@us.ibm.com> wrote in message
news:d3h7rs$d6v$1@news.eclipse.org...
> control.
> >> > Hi,
> >> > Thanks,
> >> > Kevin.
Re: Why GEF uses its own GEFMessages, not the WorkbenchMessage? [message #177257 is a reply to message #177187] Wed, 13 April 2005 09:21 Go to previous message
We only provide strings that we need. Otherswise, where would it end?
news:d3hidn$rd0$1@news.eclipse.org...
> Hi Randy,
> then?
> Eclipse too?
> Kevin
Previous Topic:Problem with some event notification...
Next Topic:Connections disappear after the refreshChildren()
Current Time: Thu Jul 24 04:59:53 EDT 2025
Powered by FUDForum. Page generated in 0.05747 seconds
