Home » Modeling » TMF (Xtext) » mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"'(error mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"')
mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767890] Wed, 12 July 2017 00:21 Go to next message
index.php/fa/29933/0/
This is the text editor
This is my grammar.
index.php/fa/29934/0/
I get an error of
Is there any way to define double quote in terminal id ?
Please help me with this.
Thanks.
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767891 is a reply to message #1767890] Wed, 12 July 2017 00:39 Go to previous messageGo to next message
do you inherit from terminals? that defines string. and that might conflict with your ID
since lexing is done first and context free
if yes why not reusing that e.g.
IDORSTRING: STRING | ID;
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767893 is a reply to message #1767891] Wed, 12 July 2017 00:54 Go to previous messageGo to next message
Yes, I inherit from terminal.
But is it possible to write the grammar as below:
NamespaceStatement:
'namespace'
'"' uri=STRINGARG4 '"'
//(prefix+=PrefixStatement);
PrefixStatement:
'prefix' name=STRINGARG';' ;
and delete it from the terminal ID.
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767894 is a reply to message #1767893] Wed, 12 July 2017 00:57 Go to previous messageGo to next message
can you please share a complete but minimal reproducing grammar and a bunch of unit tests?
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767896 is a reply to message #1767894] Wed, 12 July 2017 01:13 Go to previous messageGo to next message
This is new grammar.
index.php/fa/29937/0/
This is the text editor.
index.php/fa/29938/0/
index.php/fa/29939/0/
I want this output in my xtext editor.
I havent done any unit testing.
I am new in xtext/ xtend grammar developmnt.
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767897 is a reply to message #1767896] Wed, 12 July 2017 01:15 Go to previous messageGo to next message
screenshots are not useable
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767898 is a reply to message #1767897] Wed, 12 July 2017 01:18 Go to previous messageGo to next message
Xtext Grammar:
grammar org.xtext.yang.samplemib.SampleMib with org.eclipse.xtext.common.Terminals
generate sampleMib "http://www.xtext.org/yang/samplemib/SampleMib"
Model:
	Module;
Module:
	'module' name=STRINGARG
	(statements += Statement)*
Statement:
	( NamespaceStatement
	| PrefixStatement
		//| ImportStatement
NamespaceStatement:
	'namespace'
PrefixStatement:
//ImportStatement:
	//'import' importURI =STRINGARG '{'
		//(prefix += PrefixStatement)
STRINGARG:
	(ID | CUSTOMSTRING | 'default')+;
STRINGARG4:
	(((ID+':'ID) + (':' +ID)+)| (':'+KEY_IDENTIFIER)+);
CUSTOMSTRING:
	(STRING (';' STRING));
terminal ID:
    ('^')?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'-'|'0'..'9')*;
KEY_IDENTIFIER:
	(=>'value' | =>'status' | =>'namespace' | =>'notification' |=> 'path'  |=> 'description' |=> 'string' |
		 =>'error-message' | =>'config' |=>'range' | =>'revision' | =>'type' | =>'boolean' | =>'prefix' |
		 =>'range' | => 'key' | =>'fraction-digits')+;
Xtext Editor:
module SNMPv2-MIB {
	namespace "urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB";
This is my code.
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767902 is a reply to message #1767898] Wed, 12 July 2017 01:41 Go to previous messageGo to next message
hi,
there a a problem. as i said lexers are context free.
=> if something can be parsed as a STRING, it will be parsed as a STRING
you would have to write a custom lexer for that and this is not a trivial task
what you could do instead:
- using STRING and write a check in the MyDslValidator that checks the format
- using a datatype rule on STRING and a custom Value converter that checks the format
maybe you can try to rearrange your grammar as well,
but you need to check how this conflicts with the places you exect a string
NamespaceStatement:
'namespace'
uri=STRINGARG4
terminal STRINGARG4:
'"' (((ID+':'ID) + (':' +ID)+)| (':'+KEY_IDENTIFIER)+) '"';
terminal KEY_IDENTIFIER:
('value' | 'status' | 'namespace' | 'notification' | 'path' | 'description' | 'string' |
'error-message' | 'config' |'range' | 'revision' | 'type' | 'boolean' | 'prefix' |
'key' | 'fraction-digits')+;
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767909 is a reply to message #1767902] Wed, 12 July 2017 02:40 Go to previous messageGo to next message
Can i use below import statement in my code for DSL modeling?
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767914 is a reply to message #1767909] Wed, 12 July 2017 02:56 Go to previous messageGo to next message
NamespaceStatement:
	'namespace' uri=(STRINGARG | STRINGARG4)
	|'{' (namespaceunknownstatements+=UnknownStatement)* '}');
This one works using below import statement,
Thanks Christian.
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767915 is a reply to message #1767909] Wed, 12 July 2017 02:56 Go to previous messageGo to next message
NamespaceStatement:
Thanks Christian.
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1767917 is a reply to message #1767915] Wed, 12 July 2017 03:04 Go to previous messageGo to next message
something like
uri=STRINGARGORSTRINGARG4 ...
STRINGARGORSTRINGARG4 returns ecore::EString: STRINGARG | STRINGARG4;
is what i have thought of
Re: mismatched input '"urn:ietf:params:xml:ns:yang:smiv2:SNMPv2-MIB"' expecting '"' [message #1768019 is a reply to message #1767917] Thu, 13 July 2017 00:02 Go to previous message
EMF - The core EMF framework includes a meta model (Ecore) for describing models and runtime support for the models including change notification, persistence support with default XMI serialization, and a very efficient reflective API for manipulating EMF objects generically.
https://www.eclipse.org/modeling/emf
Previous Topic:Accessing DSL statement in generator class
Next Topic:Grammar Mixins/Library vs. Tycho/Maven build
Current Time: Sun Jul 27 02:27:54 EDT 2025
Powered by FUDForum. Page generated in 0.30455 seconds
