Exception thrown by Sirius Sequence Diagram [message #1767777] |
Tue, 11 July 2017 00:57  |
I'm trying to create a very basic Sequence diagram for the XBase model and the Xtend model that builds on it.
The diagram would be created on any XtendFunction element. I would like the XtendFunction to represent the Instance Role and it's children XExpression elements to represent the executions. I've not gotten far enough to even worry about the messages yet.
So far, everything I've tried results in an exception.
I've created the diagram with the following:
Domain Class = XtendFunction
Ends Ordering = aql:self.eAllContents()->filter(xbase::XExpression)->asSequence()
Instance Rolls Ordering = aql:self->asSequence()
In the default layer, I add the following InstanceRoll:
Semantic Candidates = aql:self
and then I add the following Execution under it
Domain Class = XExpression
Starting End Finder = aql:self.eContents()->filter(xbase::XExpression)->first()
Finishing End Finder = aql:self.eContents()->filter(xbase::XExpression)->last()
Semantic Candidates = aql:self.eContents()->filter(xbase::XExpression)
Both the Instance Role and the Execution have styles set.
Here's the exception I get from that:
at org.eclipse.sirius.diagram.sequence.business.internal.layout.AbstractSequenceLayout$1.apply(AbstractSequenceLayout.java:147)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.AbstractSequenceLayout$1.apply(AbstractSequenceLayout.java:1)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:647)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:143)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:138)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:645)
at com.google.common.collect.Iterators.addAll(Iterators.java:356)
at com.google.common.collect.Lists.newArrayList(Lists.java:146)
at com.google.common.collect.Lists.newArrayList(Lists.java:128)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.vertical.SequenceVerticalLayout.getMinTimeBounds(SequenceVerticalLayout.java:906)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.vertical.SequenceVerticalLayout.initTimeBounds(SequenceVerticalLayout.java:811)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.vertical.SequenceVerticalLayout.init(SequenceVerticalLayout.java:224)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.AbstractSequenceLayout.layout(AbstractSequenceLayout.java:76)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.SequenceLayout.verticalLayout(SequenceLayout.java:89)
at org.eclipse.sirius.diagram.sequence.business.internal.operation.SynchronizeGraphicalOrderingOperation.execute(SynchronizeGraphicalOrderingOperation.java:65)
at org.eclipse.sirius.diagram.sequence.business.internal.operation.SynchronizeGraphicalOrderingOperation.execute(SynchronizeGraphicalOrderingOperation.java:1)
at org.eclipse.sirius.diagram.sequence.business.internal.refresh.RefreshLayoutCommand.doExecute(RefreshLayoutCommand.java:110)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:488)
at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.sirius.diagram.sequence.ui.tool.internal.edit.part.SequenceDiagramEditPart.activate(SequenceDiagramEditPart.java:189)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:215)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer.setContents(DiagramGraphicalViewer.java:352)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initializeGraphicalViewerContents(DiagramEditor.java:872)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.initializeGraphicalViewerContents(DDiagramEditorImpl.java:1422)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initializeGraphicalViewer(DiagramEditor.java:865)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.initializeGraphicalViewer(DiagramEditorWithFlyOutPalette.java:116)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.initializeGraphicalViewer(DiagramDocumentEditor.java:174)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.initializeGraphicalViewer(DDiagramEditorImpl.java:1438)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.createOriginalGraphicalViewer(DDiagramEditorImpl.java:1392)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.createMainDiagramSection(DDiagramEditorImpl.java:1318)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.createGraphicalViewer(DDiagramEditorImpl.java:1307)
at org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(GraphicalEditor.java:171)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.createPartControl(DiagramEditor.java:1580)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.createPartControl(DiagramEditorWithFlyOutPalette.java:328)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.createPartControl(DiagramDocumentEditor.java:1514)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.createPartControl(DDiagramEditorImpl.java:509)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:150)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:99)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:340)
at sun.reflect.GeneratedMethodAccessor186.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1324)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4814)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3098)
at org.eclipse.sirius.diagram.ui.business.internal.dialect.DiagramDialectUIServices$1.run(DiagramDialectUIServices.java:208)
at org.eclipse.sirius.common.ui.tools.api.util.EclipseUIUtil.displaySyncExec(EclipseUIUtil.java:336)
at org.eclipse.sirius.diagram.ui.business.internal.dialect.DiagramDialectUIServices.openEditor(DiagramDialectUIServices.java:218)
at org.eclipse.sirius.diagram.ui.business.internal.dialect.DiagramDialectUIServices.openEditor(DiagramDialectUIServices.java:179)
at org.eclipse.sirius.ui.business.internal.dialect.DialectUIManagerImpl.openEditor(DialectUIManagerImpl.java:95)
at org.eclipse.sirius.ui.tools.internal.actions.session.OpenRepresentationsAction.openRepresentations(OpenRepresentationsAction.java:109)
at org.eclipse.sirius.ui.tools.internal.actions.session.OpenRepresentationsAction.access$1(OpenRepresentationsAction.java:96)
at org.eclipse.sirius.ui.tools.internal.actions.session.OpenRepresentationsAction$1.run(OpenRepresentationsAction.java:82)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:481)
at org.eclipse.ui.internal.progress.ProgressManager$RunnableWithStatus.run(ProgressManager.java:1242)
at org.eclipse.ui.internal.progress.ProgressManager$5.run(ProgressManager.java:1092)
at org.eclipse.ui.internal.progress.ProgressManager.runInUI(ProgressManager.java:1089)
at org.eclipse.sirius.ui.tools.internal.actions.session.OpenRepresentationsAction.run(OpenRepresentationsAction.java:85)
at org.eclipse.sirius.ui.tools.internal.views.common.navigator.OpenRepresentationListener.doubleClick(OpenRepresentationListener.java:41)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:833)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:830)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1470)
at org.eclipse.ui.navigator.CommonViewer.handleDoubleSelect(CommonViewer.java:445)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1264)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:252)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:311)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1313)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
I've read in another forum post that this means I added an Instance Role without an Execution, but I definitely have my Execution defined.
So, to troubleshoot, I simplified. I changed my definition such that both my Instance Role and my Execution represent the XtendFunction, as follows:
Diagram
Ends Ordering = aql:self->asSequence()
InstanceRoll:
Execution:
This resulted in the following exception:
java.lang.IllegalArgumentException
at com.google.common.base.Preconditions.checkArgument(Preconditions.java:77)
at org.eclipse.sirius.diagram.sequence.util.Range.<init>(Range.java:46)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.vertical.SequenceVerticalLayout.layoutLifelinesWithoutCreation(SequenceVerticalLayout.java:497)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.vertical.SequenceVerticalLayout.computeLifelineRanges(SequenceVerticalLayout.java:480)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.vertical.SequenceVerticalLayout.computeLayout(SequenceVerticalLayout.java:305)
at org.eclipse.sirius.diagram.sequence.business.internal.layout.AbstractSequenceLayout.layout(AbstractSequenceLayout.java:79)
at org.eclipse.sirius.ui.tools.internal.actions.creation.CreateRepresentationAction$2.run(CreateRepresentationAction.java:170)
at org.eclipse.sirius.ui.tools.internal.actions.creation.CreateRepresentationAction.run(CreateRepresentationAction.java:179)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
I've tried other things as well. It seems no matter what I do, I get one of these two exceptions. Can anyone shed some light on what these exceptions are trying to tell me?
thanks,
Joe
FUDForum. Page generated in 0.04357 seconds
