Home » Modeling » Papyrus » Load a Papyrus ModelSet programmatically
Load a Papyrus ModelSet programmatically [message #1767721] Mon, 10 July 2017 06:21 Go to next message
Hi guys,
I am currently trying to write some smoke tests for transformations as JUnit Plugin tests. Therfore I need to load a Papyrus model programmatically in the same way (as if it would have been started via the UI.
The transformation is based on EMF transaction, so a transactional editing domain is required. However, even if I load all the three resources (.di, .notation. uml) into a resource set, there is no transactional editing domain set.
I am pretty sure I once found a loading facility in the Papyrus code base, that allowed me to simply add a URI and the properly loaded resource set with transactional rediting domain.
Would somebody please adivse me how to properly load the entire Papyrus ModelSet programmatically?!
Thanks a lot in advance,
Marc-Florian
Re: Load a Papyrus ModelSet programmatically [message #1767728 is a reply to message #1767721] Mon, 10 July 2017 08:01 Go to previous message
Hi Marc-Florian,
In JUnit tests, you can use the @Rules provided in the Papyrus JUnit Utils plug-in, e.g.:
	@Rule
	public final ModelSetFixture modelSet = new ModelSetFixture();
	@Test
	@PluginResource("/resources/model/model.uml")
	public void test() {
		ModelSet ms = modelSet.getModelSet();
Check the Javadoc of org.eclipse.papyrus.junit.utils.rules.AbstractModelFixture<T> for more details.
If you don't want to reuse the complete rule, you can reuse the implementation from these methods:
org.eclipse.papyrus.junit.utils.rules.ModelSetFixture.createEditingDomain()
org.eclipse.papyrus.junit.utils.rules.ModelSetFixture.didLoadResourceSet()
Camille
Previous Topic:<<Trace>> Realization in Palette
Next Topic:Registering a Generated Static Profile
Current Time: Thu Jul 24 23:31:11 EDT 2025
Powered by FUDForum. Page generated in 0.04132 seconds
