Show About Dialog in RCP 4 Application [message #1767652] |
Sat, 08 July 2017 09:35  |
Hi everybody,
I'm new in the eclipse rcp 4 develop, and I'm in throuble when I want to create a custom dialog. I don't know how I can handle that dialog.
My intension is to create a command whit method execute and open that dialog created in te Windows and Dialogs menu in the Application.e4xmi.
Somebody can help me?!
Re: Show About Dialog in RCP 4 Application [message #1775135 is a reply to message #1767652] |
Wed, 25 October 2017 04:10  |
Just write a simple handler and open the dialog in the execute method.
Handler:
public class AboutHandler {
@Inject
private IEclipseContext context;
@Execute
public void execute(@Named(IServiceConstants.ACTIVE_SHELL) Shell shell) {
AboutDialog dialog = new AboutDialog(shell);
ContextInjectionFactory.inject(dialog, context);
dialog.open();
Dialog code:
import java.io.IOException;
import java.io.InputStream;
import javax.inject.Inject;
import org.eclipse.e4.core.services.translation.TranslationService;
import org.eclipse.jface.dialogs.Dialog;
import org.eclipse.jface.dialogs.IDialogConstants;
import org.eclipse.jface.util.Geometry;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Monitor;
import org.eclipse.swt.widgets.Shell;
import org.osgi.framework.FrameworkUtil;
public class AboutDialog extends Dialog {
private final String PLUGIN_URI = "platform:/plugin/my.plugin";
@Inject
private TranslationService translations;
public AboutDialog(Shell shell) {
super(shell);
setShellStyle(SWT.TITLE | SWT.RESIZE);
protected void configureShell(Shell newShell) {
super.configureShell(newShell);
newShell.setText(translations.translate("%about.dialog.title", PLUGIN_URI));
protected Control createDialogArea(Composite parent) {
parent.setLayout(new GridLayout(2, false));
InputStream in = null;
try {
in = FrameworkUtil.getBundle(this.getClass()).getResource("/images/about-side.jpg")
.openStream();
catch (IOException e) {
e.printStackTrace();
Image image = new Image(Display.getCurrent(), in);
Label sideImage = new Label(parent, SWT.BORDER);
sideImage.setImage(image);
GridData layoutData = new GridData(SWT.FILL, SWT.FILL, true, true);
Label text = new Label(parent, SWT.WRAP);
text.setText(getDialogText());
text.setLayoutData(layoutData);
parent.pack();
return super.createDialogArea(parent);
protected void createButtonsForButtonBar(Composite parent) {
createButton(parent, IDialogConstants.OK_ID,
translations.translate("%common.close", PLUGIN_URI), true);
private String getDialogText() {
String text = translations.translate("%about.dialog.text", PLUGIN_URI);
return text;
protected Control createContents(Composite parent) {
Control content = super.createContents(parent);
parent.pack();
return content;
protected void initializeBounds() {
super.initializeBounds();
Rectangle bounds = getShell().getBounds();
Point location = getInitialLocation(new Point(bounds.width, bounds.height));
getShell().setBounds(location.x, location.y, bounds.width, bounds.height);
* Returns the initial location to use for the shell. The default
* implementation centers the shell horizontally (1/2 of the difference to
* the left and 1/2 to the right) and vertically (1/3 above and 2/3 below)
* relative to the parent shell, or display bounds if there is no parent
* shell.
* @param initialSize
* the initial size of the shell, as returned by
* <code>getInitialSize</code>.
* @return the initial location of the shell
protected Point getInitialLocation(Point initialSize) {
Composite parent = getShell().getParent();
Monitor monitor = getShell().getDisplay().getPrimaryMonitor();
if (parent != null) {
monitor = parent.getMonitor();
Rectangle monitorBounds = monitor.getClientArea();
Point centerPoint;
centerPoint = Geometry.centerPoint(parent.getBounds());
} else {
centerPoint = Geometry.centerPoint(monitorBounds);
return new Point(centerPoint.x - (initialSize.x / 2), Math.max(
monitorBounds.y, Math.min(centerPoint.y
- (initialSize.y * 2 / 3), monitorBounds.y
+ monitorBounds.height - initialSize.y)));
protected boolean isResizable() {
return true;
FUDForum. Page generated in 0.03373 seconds
