Home » Modeling » Papyrus » Custom Diagram Implementation(How to transform a GMF-based diagram into a Papyrus-diagram)
Custom Diagram Implementation [message #1767317] |
Tue, 04 July 2017 11:46  |
Hello guys,
I'm new to the whole Eclipse and Papyrus world. My goal is to implement a custom diagram into Papyrus as a "3rd party plugin".
I started by learning the GMF-process and successfully generated a custom diagram-editor. The custom diagram is just a simple implementation, there is much room for improvement. But my current point is just to add this custom diagram now into Papyrus regardless of the actual use/functionality yet.
I'm currently following this guide about Papyrus-Diagram-Generation.
1. Problem
Where it says " Add the following developer plugins to your workspace", I can not really follow. What does "add plugins to workspace" mean in the Eclipse world?
I prepared my workspace according to this guide.
So, I have the listed projects as projects "to build myself" in Eclipse, but not actually "installed" or something like that. Is that correct according to the first guide? I also installed the required plugins mentioned in the same guide.
2. Problem
Within this screenshot there are two root-nodes for the gmfgen-file that I do not have:
- Papyrus Extension Root Node...
- Visual ID Override Package...
Is that a problem? If so, where do I get them from?
3. Problem
Within the first guide it says "[...] right click on your gmfgen file and select the menu Generate Papyrus Diagram.".
I do not have this option in the context-menu, did I something wrong?
I'm running the following Eclipse version:
Eclipse Modeling Tools
Version: Oxygen Release (4.7.0)
Build id: 20170620-1800
I used the master-branch of Papyrus for git-checkout.
Maybe you can also suggest me more documentation etc.
Best regards
Jan
Re: Custom Diagram Implementation [message #1769287 is a reply to message #1769285] |
Fri, 28 July 2017 11:43   |
I wouldn't recommend using two different versions of Papyrus for the code generation, as gmfgen models and code generation can change quite a lot between versions, so you should use Oxygen exclusively.
if you want to use Neon exclusively, the developer plug-ins are available here [1] (Oxygen ones are here [2]. The missing "oep.uml.m2m.qvto.common" plug-in is only available in Papyrus Oxygen, so you won't be able to install it on Neon
Regarding Xtend, it is part of the Eclipse Release Train, so you can find it in the update site for your current eclipse release, i.e. [3] or [4] depending on whether you're using Neon or Oxygen. Simply look for "Xtend IDE"
[1] https://hudson.eclipse.org/papyrus/view/Neon/job/Papyrus-Neon-Developer/lastSuccessfulBuild/artifact/repository/
[2] https://hudson.eclipse.org/papyrus/view/Oxygen/job/Papyrus-Oxygen-Developer/lastSuccessfulBuild/artifact/repository/
[3] http://download.eclipse.org/releases/neon
[4] http://download.eclipse.org/releases/oxygen
HTH,
Camille
Re: Custom Diagram Implementation [message #1769535 is a reply to message #1769287] |
Tue, 01 August 2017 07:46   |
Hello everyone,
Thanks Camille, I also want to just use a single version exclusively because of stability and integrity - sure.
But it seems like I can not use Neon, because of the unavailability of the "oep.uml.m2m.qvto.common" plug-in, right?
So I thought I'd start to troubleshoot the Oxygen process again... The thing is more of a GMF problem as a Papyrus problem, I guess:
When I want to transform - within the GMF process - from the *.gmfmap to the *.gmfgen, the transformation fails with the following error:
java.lang.NoSuchMethodError: org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.compile(Lorg/eclipse/m2m/internal/qvt/oml/compiler/UnitProxy;Lorg/eclipse/m2m/internal/qvt/oml/compiler/QvtCompilerOptions;Lorg/eclipse/emf/common/util/Monitor;)Lorg/eclipse/m2m/internal/qvt/oml/compiler/CompiledUnit;
at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.doLoadQvtResource(ResourceManagerImpl.java:80)
at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.loadQvtResourceThroughCache(ResourceManagerImpl.java:64)
at org.eclipse.gmf.internal.xpand.util.ResourceManagerImpl.loadQvtResource(ResourceManagerImpl.java:47)
at org.eclipse.gmf.internal.xpand.model.Scope.findExtension(Scope.java:148)
at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.getImportedModules(ExecutionContextImpl.java:293)
at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.getOCLEnvironment(ExecutionContextImpl.java:254)
at org.eclipse.gmf.internal.xpand.ocl.TypeHelper.getTypeForName(TypeHelper.java:35)
at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.findDefinition(ExecutionContextImpl.java:231)
at org.eclipse.gmf.internal.xpand.model.ExecutionContextImpl.findDefinition(ExecutionContextImpl.java:167)
at org.eclipse.gmf.internal.xpand.XpandFacade.evaluate(XpandFacade.java:54)
at org.eclipse.gmf.graphdef.codegen.FigureGenerator.fqnSwitch(FigureGenerator.java:85)
at org.eclipse.gmf.internal.bridge.genmodel.InnerClassViewmapProducer.createViewmap(InnerClassViewmapProducer.java:123)
at org.eclipse.gmf.internal.bridge.genmodel.InnerClassViewmapProducer.create(InnerClassViewmapProducer.java:76)
at org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTransformer.process(DiagramGenModelTransformer.java:413)
at org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer.transform(MappingTransformer.java:31)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenModelOperation$2.process(TransformToGenModelOperation.java:446)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenModelOperation.executeTransformation(TransformToGenModelOperation.java:272)
at org.eclipse.gmf.internal.bridge.ui.dashboard.actions.TransformMap2GenModelAction.run(TransformMap2GenModelAction.java:65)
at org.eclipse.gmf.internal.bridge.ui.dashboard.HyperlinkFigure$1.mousePressed(HyperlinkFigure.java:63)
at org.eclipse.draw2d.Figure.handleMousePressed(Figure.java:938)
at org.eclipse.draw2d.SWTEventDispatcher.dispatchMousePressed(SWTEventDispatcher.java:242)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown(LightweightSystem.java:523)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:193)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4257)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1502)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1525)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1510)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1314)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4081)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3698)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1044)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Searching the web didn't do the thing. As I can see, the method compile() can't be found (with the given signature). So, it seems like a compatibility problem, right? The calling code of the QVT uses another signature for compile() or so?
Maybe there is a version-conflict or something like that?
I don't know, where or for what to look and search. I didn't install anything of QVT manually, I guess it's a dependency of the GMF stuff and was (hopefully) installed automatically? Or do I need to install something manually?
Maybe someone has a hint, as I'm not getting anywhere with the problem...
Thanks a million.
Update:
These plug-ins related to the term "QVT" are currently installed:
See attachment "qvt-plugins".
(I just installed the QVT operational stuff)
[Updated on: Tue, 01 August 2017 08:43] by Moderator
Re: Custom Diagram Implementation [message #1770226 is a reply to message #1769971] |
Wed, 09 August 2017 04:45  |
I tried several QVTo versions, no change.
But how do you generate GMFGen models directly? The Papyrus-Simple-Diagram-Tutorial advises to use the GMF process to get the final *.gmfgen file.
Is there any chance to get the Papyrus-Dev-Plugin into Neon, so I can stick to Neon and use the "right click -> generate diagram" option that the Dev-Plugin provides?
Or is there a good chance to do what the Dev-Plugin does manually?
Thanks for your help.
Jan
Current Time: Tue Jul 22 04:26:02 EDT 2025
Powered by FUDForum. Page generated in 0.51477 seconds
