Importing Ecore Model [message #1767410] |
Wed, 05 July 2017 13:17  |
Hello All,
I am trying to create a DSL using Xbase and Xtext. I am also planning to support IDEA plugin for this DSL. I have some constrain however around organizing the code for this DSL. Specifically
1) I am trying to create one project (this does not mean an 'eclipse project') which contains the DSL file, validation code, model inferring code, generator code, scoping code etc.
2) I need to crate another project which contains all the ui related stuff. e.g content assist, labeling, quick fix etc.
I am able to complete step 1 and have a jar which contains the xtext file, model files etc. But I am struggling with step 2. Can someone please advice on how should I go about implementing 2. (I have tried importing ecore model and tried searching on this forum but getting into one error or the other).
Thank You,
Re: Importing Ecore Model [message #1767539 is a reply to message #1767410] |
Thu, 06 July 2017 23:06  |
Here is my MWE2 file
module org.example.my.idea.Mydsl
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var grammarURI = "classpath:/org/example/my/Mydsl.xtext"
var file.extensions = "mydsl"
var runtimeProject = "src/main/java/org/example/my"
var rootPath = ".."
Workflow {
bean = StandaloneSetup {
logResourceUriMap = true
projectMapping = {
projectName = 'org.example.my'
path = 'src/main/java/org/example/my'
scanClassPath = true
platformUri = "${runtimeProject}"
uriMap = {
from = "platform:/resource/org.example.my/model/Mydsl.genmodel"
to = "classpath:/model/generated/Mydsl.genmodel"
uriMap = {
from = "platform:/resource/org.example.my/model/Mydsl.ecore"
to = "classpath:/model/generated/Mydsl.ecore"
registerGenModelFile = "platform:/resource/org.example.my/model/Mydsl.genmodel"
registerEcoreFile= "platform:/resource/org.example.my/model/Mydsl.ecore"
registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
registerGenModelFile = "platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel"
registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
registerGeneratedEPackage="org.example.my.dsl.mydsl.MydslPackage"
component = DirectoryCleaner {
directory = "${runtimeProject}/src-gen"
directory = "${runtimeProject}.ui/src-gen"
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "my-dsl-ide"
rootPath = rootPath
runtime = {
enabled = false
runtimeTest = {
enabled = false
genericIde = {
name = "my-dsl-ide"
enabled = true
ideaPlugin = {
name = "my-dsl-ide"
enabled = true
mavenLayout = true
code = {
preferXtendStubs = false
encoding = "UTF-8"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = XtextGeneratorLanguage {
grammarUri = grammarURI
fileExtensions = "mydsl"
fragment = grammarAccess.GrammarAccessFragment2 {}
// generates Java API for the generated EPackages
fragment = ecore.EMFGeneratorFragment2 {
genModel = "platform:/resource/org.example.my/model/Mydsl.genmodel"
fragment = ui.labeling.LabelProviderFragment2 {}
fragment = ui.outline.QuickOutlineFragment2 {}
fragment = ui.outline.OutlineTreeProviderFragment2 {}
fragment = ui.quickfix.QuickfixProviderFragment2 {}
fragment = ui.contentAssist.ContentAssistFragment2 {}
fragment = ui.templates.CodetemplatesGeneratorFragment2 {}
fragment = ui.compare.CompareFragment2 {}
fragment = idea.parser.antlr.XtextAntlrIDEAGeneratorFragment {}
fragment = idea.IdeaPluginGenerator {}
Here is the error I am getting:
Caused by: java.net.MalformedURLException: unknown protocol: classpath
at java.net.URL.<init>(URL.java:593)
at java.net.URL.<init>(URL.java:483)
at java.net.URL.<init>(URL.java:432)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:199)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
I have added the jar from project 1 to class path of porject 2.
FUDForum. Page generated in 0.03125 seconds
