Home » Eclipse Projects » Kura » Eclipse Smart GreenHouse Package not working
Eclipse Smart GreenHouse Package not working [message #1767022] Thu, 29 June 2017 11:09 Go to next message
I am trying to make eclipse smarthome, usinng a Raspberry pi as given on the following page " https://iot.eclipse.org/java/tutorial/ " . Now when I try to install an application form Kura web UI, a message is shown that download is sucessful but nothing appers in the packages folder. Application name is Greenhouse Publisher.
Re: Eclipse Smart GreenHouse Package not working [message #1767044 is a reply to message #1767022] Thu, 29 June 2017 18:55 Go to previous messageGo to next message
It is likely that the bundles are failing to resolve. If you check /var/log/kura.log and /var/log/kura-console.log you will likely see errors. You can also check the 'ss' and 'ls' commands in OSGi console for unresolved bundles/components.
What version of Kura are you using? The Greenhouse Publisher demo was created based on Kura v1.3.0. It is likely not compatible with newer versions of Kura. We need to update this project to make sure it remains compatible.
--Dave
Re: Eclipse Smart GreenHouse Package not working [message #1767377 is a reply to message #1767044] Wed, 05 July 2017 08:27 Go to previous message
Hi, I have met this problem too. I am using Kura 3.0 and Raspberry Pi 3 Mode B,
and the green house example had used Kura 2.0.
is there anyone who can resolve this problem? Thank you!
Previous Topic:Help: Extends Cloudlet
Next Topic:Failed to install deployment package of GreenHOuse!
Current Time: Thu Jul 31 02:41:15 EDT 2025
Powered by FUDForum. Page generated in 0.04123 seconds
