| Ambiguous grammar [message #1767135] |
Sat, 01 July 2017 15:52  |
I have a problem with an ambiguous Xtext grammar, and can't seem to find the right solution to solve it.
I have tried using syntactic predicates, but wasn't able to disambiguate this way.
An alternative solution could be to use the backtrack option which actually prevents errors when generating xtext artifacts. However, my understanding is that some Antlr warnings will be suppressed when using this option and therefore I am reluctant to use it. I would prefer a solution with some kind of refactoring in stead. Any recommendations/suggestions would be appreciated.
The problem is related to this rule:
Reuse:
{Reuse} ('edit' ref=DotExpression | 'add' add=ReUseAble)
And the parser gives these errors:
Decision can match input such as "'edit'" using multiple alternatives: 1, 2
Decision can match input such as "'add'" using multiple alternatives: 1, 2
The whole xtext grammar file is shown below, but only the first 5 rules are relevant for this problem.
grammar org.xtext.example.mydsl4.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl4/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Robot:
'Robot' name=ID
(links += Link | joint+=Joint)*
ReUseAble:
Link | Visual | Inertial | Collision
Link:
{Link} 'Link' name=ID
(('def' (inertial=Inertial | visual+=Visual | collision+=Collision)*)
| ('reuse' link=[Link] reuse+=Reuse*)
Reuse:
DotExpression returns Ref:
ReUsableRef ({DotExpression.ref=current} "." tail=[ReUseAble])*
ReUsableRef returns Ref:
{ReUsableRef} reuseable=[ReUseAble]
Inertial:
{Inertial} 'Inertial' (name=ID)?
inertia=Inertia
mass=Mass
(origin=Origin)?
Inertia:
{Inertia} 'Inertia' (name=ID)?
'ixx' ixx=URDFAttrSignedNumeric
'ixy' ixy=URDFAttrSignedNumeric
'ixz' ixz=URDFAttrSignedNumeric
'iyy' iyy=URDFAttrSignedNumeric
'iyz' iyz=URDFAttrSignedNumeric
'izz' izz=URDFAttrSignedNumeric
Visual:
{Visual} 'Visual' (name=ID)?
'Geometry' geometry+=Geometry*
(origin=Origin)?
('Material' material=Material)?
Origin:
{Origin} 'Origin' (name=ID)?
'x' x=URDFAttrSignedNumeric
'y' y=URDFAttrSignedNumeric
'z' z=URDFAttrSignedNumeric
('roll' roll=URDFAttrSignedNumeric)?
('pitch' pitch=URDFAttrSignedNumeric)?
('yaw' yaw=URDFAttrSignedNumeric)?
Mass:
{Mass} 'Mass' (name=ID)?
'massKilogram' massKilogram=URDFAttrSignedNumeric
Collision:
'Collision' name=ID
(origin=Origin)?
Geometry:
Box | Cylinder | Mesh | Sphere
Box:
'Box' (name=ID)?
'height' height=URDFAttrNumeric
'length' length=URDFAttrNumeric
'width' width=URDFAttrNumeric
Cylinder:
'Cylinder' (name=ID)?
'radius' radius=URDFAttrNumeric
Mesh:
'Mesh' (name=ID)?
'pathToFile' pathToFile=URDFAttrSTRING
//('scale' dimension=Box)?
Sphere:
'Sphere' (name=ID)?
Material:
Texture | Color
Texture:
'Texture' (name=ID)?
// RGBA values must be floats between 0 and 1 incl
Color:
'Color' (name=ID)?
'red' red=URDFAttrFloat
'green' green=URDFAttrFloat
'blue' blue=URDFAttrFloat
'alpha' alpha=URDFAttrFloat
Joint:
'Joint' name=ID
//'ChildOf' childOf=[Link]
//'ParentOf' parentOf=[Link]
//'Type' type=JointType
(('def' 'ChildOf' childOf=[Link]
'Type' type=JointType)
( origin=Origin | axis=Axis | limit=Limit | calibration=Calibration | dynamics=Dynamics | safetycontroller=SafetyController)* |
//HOW TO REUSE: CHANGE PARENT AND CHILD LINKS??
('reuse' isReuseOf=[Joint]
reuse=Reuse
enum JointType:
fixed = 'fixed' |revolute = 'revolute' | prismatic = 'prismatic' | continuous = 'continuous'
/* Binary values must be 0 or 1 - digitsum must be 1, WHY NEED TO DEFINE ALL THREE?? */
//keyword aliases: 'xyz' or 'x', 'y', 'z'
Axis:
'Axis' (name=ID)?
'x' x=URDFAttrINT
'y' y=URDFAttrINT
'z' z=URDFAttrINT
Limit:
'Limit' (name=ID)?
'effort' effort=URDFAttrSignedNumeric
'velocity' velocity=URDFAttrSignedNumeric
'lower' lower=(URDFAttrSignedNumeric)?
'upper' upper=(URDFAttrSignedNumeric)?
Calibration:
{Calibration} 'Calibration' (name=ID)?
('rising' rising=URDFAttrSignedNumeric)?
('falling' falling=URDFAttrSignedNumeric)?
Dynamics:
{Dynamics} 'Dynamics' (name=ID)?
('friction' friction=URDFAttrSignedNumeric)?
('damping' damping=URDFAttrSignedNumeric)?
SafetyController:
'SafetyController' (name=ID)?
'k_velocity' k_velocity=URDFAttrSignedNumeric
('k_position' k_position=URDFAttrSignedNumeric)?
('softLowerLimit' softLowerLimit=URDFAttrSignedNumeric)?
('softUpperLimit' softUpperLimit=URDFAttrSignedNumeric)?
//Should we cut Mimic from the spec - NEED TO GET INTERPRETATION OF ATTRS??
/*Mimic:
'Mimic' (name=ID)?
'mimics' mimics=[Joint]
('multiplier' multiplier=URDFAttrSignedNumeric)?
('offSet' offSet=URDFAttrSignedNumeric)?
/*Constant:
URDFAttrSignedNumeric:
{URDFAttrSignedNumeric}
(name=ID)?
value = SIGNED_NUMERIC
URDFAttrFloat:
value = FLOAT
URDFAttrINT:
value = INT
URDFAttrNumeric:
value = NUMERIC
URDFAttrSTRING:
value = STRING
FLOAT returns ecore::EFloat:
INT '.' INT
SCIENTIFIC returns ecore::EBigDecimal:
FLOAT 'e' ('+' | '-')? INT
SIGNED_NUMERIC:
('-')? (INT | FLOAT | SCIENTIFIC)
NUMERIC:
Carsten
| Re: Ambiguous grammar [message #1767342 is a reply to message #1767172] |
Tue, 04 July 2017 15:03  |
Thanks Ed.
Agree. I have tried to solve the problem using predicates but haven't found a good solution, so I'll have to re-design the grammar a bit. Thanks for the Google search reference.
Carsten
FUDForum. Page generated in 0.08846 seconds
