Home » Modeling » TMF (Xtext) » How to maka a rule LL(*) while preserving semantics?
How to maka a rule LL(*) while preserving semantics? [message #1767318] Tue, 04 July 2017 11:49 Go to next message
whenever I have a rule like this:
A -> cA | cAB | "a"
XText asks me for applying left-refactoring. On paper, I'd do it like this:
A -> cC | "a"
C -> A | AB
But in XText you don't have "null" rules, I believe. So I do it by mixing in regular expressions:
A -> cA (B)? | "a"
And XText seems to swallow it as a "left refactorization".
The problem is that in my parsed model I want cA and cAB to mean different things and to be mapped into different ECore classes, and as I understand, my "regular expression" impedes that.
Let's show it on a real XText snippet. How can I make the following rule LL(*) and at the same time get different and meaningful ECore classes for alternatives 2 and 3?
terminal TYPE:
	ID |
	('(' TYPE ')') |
	('(' TYPE ')' 'throws')
I've tried this hoping that it would guide XText throughout choices, but it did not work:
terminal TYPE:
	ID |
	COMPLICATED_TYPE
terminal fragment COMPLICATED_TYPE:
	('(' TYPE ')') |
	COMPLICATED_TYPE_WITH_THROWS
terminal fragment COMPLICATED_TYPE_WITH_THROWS:
Cheers, David.
[Updated on: Tue, 04 July 2017 11:50] by Moderator
Re: How to maka a rule LL(*) while preserving semantics? [message #1767321 is a reply to message #1767318] Tue, 04 July 2017 11:56 Go to previous messageGo to next message
i cannot follow you.
terminals give you no eclasses at all.
so can you give us a real real world example to look at
Re: How to maka a rule LL(*) while preserving semantics? [message #1767323 is a reply to message #1767321] Tue, 04 July 2017 12:11 Go to previous messageGo to next message
OK, my mistake.
I wish to rewrite a rule so that
1) Get's converted into LL(*), because XText complains that the rules it's not LL(*)
2) Ensures that I will have different generated classes for these two parsed lines:
(mytype)
and
(mytype) throws
The rule I want to fix is this one, TYPE:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	greetings+=Greeting*;
Greeting:
	name=TYPE;
terminal TYPE:
	ID |
	('(' TYPE ')') |
[Updated on: Tue, 04 July 2017 12:14] by Moderator
Re: How to maka a rule LL(*) while preserving semantics? [message #1767324 is a reply to message #1767323] Tue, 04 July 2017 12:18 Go to previous messageGo to next message
but why terminals?
Type:
	{TypeWithId}name=ID | Rest
Rest returns Type:
	=>({TypeWithThrows}'(' type=Type ')' 'throws') |
	{TypeWithOutThrows}'(' type=Type ')'
Re: How to maka a rule LL(*) while preserving semantics? [message #1767327 is a reply to message #1767324] Tue, 04 July 2017 12:28 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 04 July 2017 16:18
but why terminals?
Ok, they do not have to be terminals.
[Updated on: Tue, 04 July 2017 12:29] by Moderator
Re: How to maka a rule LL(*) while preserving semantics? [message #1767329 is a reply to message #1767324] Tue, 04 July 2017 12:32 Go to previous messageGo to next message
Thanks for the solution!
Hmm, those are actions, aren't they? I'm afraid I still can't understand them well. I wasn't able to make much from the official documentation.
Anyway, that '=>' symbol... so that's the solution, right? I read in the official docs that it "tells" XText which option to choose on ambiguous cases. However I did not look at it as an alternative because I still don't understand how to use it in most of the cases.
Anyway, I will use it in this case ;)
Thanks again!
[Updated on: Tue, 04 July 2017 12:34] by Moderator
Re: How to maka a rule LL(*) while preserving semantics? [message #1767330 is a reply to message #1767329] Tue, 04 July 2017 12:38 Go to previous message
yes with the actions you can tell xtext to create the different types you want to have
{TypeWithId}name=ID
e.g. creates a eclass TypeWithId
Previous Topic:A couple of rules and recursion overflow - help appreciated
Next Topic:Ambiguous grammar
Current Time: Mon Jul 21 00:46:00 EDT 2025
Powered by FUDForum. Page generated in 0.03894 seconds
