Home » Archived » Jubula » Jubula & Eclipse BPMN2 Modeler (Jubula is unable to map objects from Eclipse BPMN2 Modeler panes)
Jubula & Eclipse BPMN2 Modeler [message #1765886] Wed, 14 June 2017 05:24 Go to next message
Hi everyone!
I'm trying to create automating GIU tests for eclipse based application.
I added jubula rcp plugin and can easily to map objects from it.
But big part of my application is using Eclipse BPMN2 Modeler UI for workflow and Jubula is unable to map any object from it.
Please help!
is there any possibility to automate this Eclipse BPMN2 Modeler UI part with Jubula at all?
Re: Jubula & Eclipse BPMN2 Modeler [message #1765923 is a reply to message #1765886] Wed, 14 June 2017 09:35 Go to previous messageGo to next message
Hello Peter,
I am assuming it is using GEF to display everything. If this is the case and it is the GEF 3 version, it is already possible to test it[1]. But to have better support for it you might need to write a extension.[2]
Hope this helps
with regards
Marvin Mueller
[1] https://help.eclipse.org/neon/topic/org.eclipse.jubula.client.ua.help/content/html/userManual/toolkit/gefTest/geftest.html
[2] https://help.eclipse.org/neon/topic/org.eclipse.jubula.client.ua.help/content/html/developerManual/gefToolkitExtension/creating-gef-toolkit-extensions.html
Re: Jubula & Eclipse BPMN2 Modeler [message #1765943 is a reply to message #1765923] Wed, 14 June 2017 10:27 Go to previous messageGo to next message
Thanks for tip!
I'm using 8.4.1 Jubula Standalone package. Description says that it contains GEF toolkit, but I don't know how to activate it. I can't see any options for it in AUT properties. :(
UPDATE: I found how to start GEF Inspector, but it can not inspect any objects from my app :(
[Updated on: Wed, 14 June 2017 10:40] by Moderator
Re: Jubula & Eclipse BPMN2 Modeler [message #1766796 is a reply to message #1765943] Tue, 27 June 2017 07:18 Go to previous message
Hi Peter,
is it possible that you are using GEF 3 in an Eclipse RCP 4 application without compatibility layer? If that is the case, we unfortunately do not support that with Jubula.
Kevin
Previous Topic:AUT Start Error
Next Topic:Can't launch other processes from AUT
Current Time: Fri Jul 25 00:51:09 EDT 2025
Powered by FUDForum. Page generated in 0.06069 seconds
