RAP GEF endless redraw, no UI Access.. [message #1766638] |
Fri, 23 June 2017 14:07  |
i am working currently on a Diagram/Graph viewer on RAP with GEF and Draw2D. The same code works on RCP Application, it's just a port to be able to show up things in a Webbrowser.
In the RAP variant the Canvas is redrawing endless, so i have no UI Access and nothing is visible. The EditParts doesn't have any changes, so there shouldn't be a demand to redraw the whole graph again. Is there any interval or is it possible to trigger the redrawing manually? What's the cause for the redrawing of the canvas?
I'm using the following versions:
org.eclipse.rap.gef_01.0.20151228-339
org.eclipse.rap.draw2d_01.0.20151228-339
and RAP in version 3.1.2
Thanks in advance.
Best Regards
Mehmet Karaman
[Updated on: Fri, 23 June 2017 14:13] by Moderator
Re: RAP GEF endless redraw, no UI Access.. [message #1818334 is a reply to message #1818141] |
Thu, 12 December 2019 11:48  |
Hi Michael,
Thanks a lot for your help. Now i can easly visualize a graph in my application.
But, i cannot create a GraphicalEditor in my application using the Part created from Application.e4xmi because the plugin or.eclipse.ui is missing!!!
Have you an idea how to do this.
Best regards
Antonio
FUDForum. Page generated in 0.05368 seconds
