Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and mobile hiding keyboard does not reappear when entering text widget
RAP and mobile hiding keyboard does not reappear when entering text widget [message #1766433] Wed, 21 June 2017 09:12 Go to next message
on ipad:
We notice that if you focus on a text field the keyboard of ipad appears.
Then you can hide the keyboard.
When you want to add some text, we click on the textfield, but the keyboard is not showing anymore.
We have to give the focus to another widget and then back to the original text field to add text.
Is anyone having the same issues?
FYI : I was trying to reproduce it on any demo sites. But appearantly they are down.
Kind regards,
Wim
Re: RAP and mobile hiding keyboard does not reappear when entering text widget [message #1766770 is a reply to message #1766433] Tue, 27 June 2017 03:13 Go to previous messageGo to next message
is the focus still on the Text widget when the keyboard is closed? Are the focusin/out listeners on the Text widget notified on show/hide of the keyboard?
Ivan
Re: RAP and mobile hiding keyboard does not reappear when entering text widget [message #1768161 is a reply to message #1766770] Fri, 14 July 2017 04:54 Go to previous message
Hi Ivan,
the focus is still on the text widget.
We were able to reproduce it on ipad 2 with iOS version 9.3 on the demo site : http://rap.eclipsesource.com/demo/release/rapdemo/
also reproduced on ipad pro (don't know exact version right now)
couldn't reproduce it on ipad 2 with iOS version 8.1
steps to reproduce :
1. select a text widget under "Multiline texts" (it actually doesn't mather which text widget)
2. ipad shows keyboard dialog.
3. hide ipad keyboard
4. touch the text widget again => no keyboard is appearing
when switched to another text widget the keyboard is appearing.
By adding a touchlistener to the text widget we received touch events.
We tried calling textwidget.forceFocus / setFocus, but in those methods, the method isFocusControl was called and this returned true.
regards,
Wim
[edit typos]
[Updated on: Fri, 14 July 2017 09:47] by Moderator
Previous Topic:Window Builder and Nebula Widgets
Next Topic:Kill/Shutdown the UIThread from a background thread
Current Time: Sat Jul 26 22:27:23 EDT 2025
Powered by FUDForum. Page generated in 0.03745 seconds
