Home » Modeling » TMF (Xtext) » IncrementalBuild loop in XText 2.11(IncrementalBuild loop in XText 2.11)
IncrementalBuild loop in XText 2.11 [message #1766711] |
Mon, 26 June 2017 09:01  |
I have the problem in a much bigger and customized project, but it also happens in a small default project
grammar org.xtext.example.mydsl1.BuildLoop with org.eclipse.xtext.common.Terminals
generate buildLoop "http://www.xtext.org/example/mydsl1/BuildLoop"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Loop: name=ID statements+=Statement+;
Statement: LoopRef | SimpleStatement | OtherName;
LoopRef: 'LOOP' ref=[Loop];
SimpleStatement: val=ID;
OtherName: 'OTHERNAME' name=ID;
Create a sample project and create the file src\test\LOOP1.loop
Create a Java class to generate files with references to LOOP1
for (int i = 1; i < 200; i++) {
StringBuffer sb = new StringBuffer();
sb.append("LOOPGEN").append(i).append("\n")
.append("LOOP LOOP1\n")
.append("\n");
for (int j = 0 ; j < 500; j++) {
sb.append("lkjdaskljdklasdj askldj askldj askldj askldj askldj a\n");
Files.write(Paths.get("C:\\workspaces\\runtime-New_configuration\\testCycle4\\src\\gen\\LOOPGEN"+i+".loop"), sb.toString().getBytes());
The generated files will be something like this:
LOOPGEN1
LOOP LOOP1
Follow the steps:
* Clean: it works ok
* Change 'OTHERNAME other' for 'OTHERNAME other2'. Incremental build recompiles all dependencies ok
* Modify 'LOOP1' and change it to 'LOOP2'. Incremental build starts but it cancels, start again, etc. It doesn't never end
* Change LOOP2 to LOOP1. Incremental build starts but it cancels, start again, etc. It doesn't end never end
* Change 'OTHERNAME other' for 'OTHERNAME other2'. Incremental build recompiles all dependencies ok (if LOOP1 is the ID, if it's not nothing references the file)
Almost always it loops, but if it doesn't, closing and opening the project usually makes it happend again (after changing LOOP1).
It doen't happen if there's only a few files or if the files are shorter and compile faster.
I've debugged the XText code and i can see that the progress associated is canceled and it triggers a restart, but i cannot see why.
Any ideas?
Re: IncrementalBuild loop in XText 2.11 [message #1766756 is a reply to message #1766714] |
Mon, 26 June 2017 18:01   |
I tried to debug in my work but i couldn't download eclipse source files because of proxy problems ...
The environment was Eclipse 4.6.3 Xtext 2.11 Windows
I've tested in home with Eclipse 4.6.3 Xtext 2.12 Linux and it also happens
Following the advice to debug around:
org.eclipse.xtext.builder.impl.XtextBuilder.handleCanceled(Throwable)
org.eclipse.core.resources.IncrementalProjectBuilder.forgetLastBuiltState()
org.eclipse.core.internal.events.AutoBuildJob.setInterrupted(boolean)
I've found that XTextBuilder detects that is blocking a previous Job "JPA Project Change Event Handler(1044)" with more priority and decides to cancel.
This job is from "Dali Java Persistence Tools -JPA Support".
It seems to be the problem to some other plugins like Spring STS and others: https://jira.spring.io/browse/STS-4416
Some people say that disabling JPA validation is enough, but the project does not have the facet and also disabling al validation does not solve it.
Uninstalling the plugin does solve it though, but i'm not sure if i will miss anything necessary ...
Do you think it's more an inherent problem of Xtext build system or a bad behaviour of "Dali JPA"?
Is there anything to do other than removing the plugin?
I'll test tomorow with the real project.
Sergio
JobManager.isBlocking(InternalJob) line: 824
while (previous != null) {
// ignore jobs of lower priority (higher priority value means lower priority)
if (previous.getPriority() < runningJob.getPriority()) {
if (!previous.isSystem())
return true;
runningJob=Building workspace(4)
.priority=40
.previous=JPA Project Change Event Handler(1044)
.previous=null
.priority=30
Thread [Worker-20] (Suspended (breakpoint at line 824 in JobManager)) (out of synch)
owns: Object (id=655)
owns: AutoBuildJob (id=136)
owns: ClusteringBuilderState (id=262)
AutoBuildJob(InternalJob).isBlocking() line: 316
AutoBuildJob(Job).isBlocking() line: 443
AutoBuildJob.isInterrupted() line: 203 (out of synch)
XtextBuilder(InternalBuilder).isInterrupted() line: 171 (out of synch)
XtextBuilder(IncrementalProjectBuilder).isInterrupted() line: 333 (out of synch)
XtextBuilder.shouldCancelBuild(int) line: 189
XtextBuilder.access$1(XtextBuilder, int) line: 188
XtextBuilder$2.isCanceled() line: 146
SubMonitor$RootInfo.isCanceled() line: 280
SubMonitor.isCanceled() line: 616
DefaultResourceUIValidatorExtension$1.isCanceled() line: 86
OperationCanceledManager.xtend line: 76
LazyLinkingResource.resolveLazyCrossReferences(CancelIndicator) line: 127
EcoreUtil2.resolveLazyCrossReferences(Resource, CancelIndicator) line: 498
ResourceValidatorImpl.resolveProxies(Resource, CancelIndicator) line: 161
ResourceValidatorImpl.validate(Resource, CheckMode, CancelIndicator) line: 74
DefaultResourceUIValidatorExtension.addMarkers(IFile, Resource, CheckMode, IProgressMonitor) line: 60
DefaultResourceUIValidatorExtension.updateValidationMarkers(IFile, Resource, CheckMode, IProgressMonitor) line: 46
MarkerUpdaterImpl.processDelta(IResourceDescription$Delta, ResourceSet, IProgressMonitor) line: 93
MarkerUpdaterImpl.updateMarkers(IResourceDescription$Delta, ResourceSet, IProgressMonitor) line: 63
ClusteringBuilderState(AbstractBuilderState).updateMarkers(IResourceDescription$Delta, ResourceSet, IProgressMonitor) line: 82
ClusteringBuilderState.doUpdate(BuildData, ResourceDescriptionsData, IProgressMonitor) line: 283
ClusteringBuilderState(AbstractBuilderState).update(BuildData, IProgressMonitor) line: 116
XtextBuilder.doBuild(ToBeBuilt, IProgressMonitor, IXtextBuilderParticipant$BuildType) line: 287
XtextBuilder.incrementalBuild(IResourceDelta, IProgressMonitor) line: 267
XtextBuilder.build(int, Map, IProgressMonitor) line: 161
BuildManager$2.run() line: 735 (out of synch)
SafeRunner.run(ISafeRunnable) line: 42
BuildManager.basicBuild(int, IncrementalProjectBuilder, Map<String,String>, MultiStatus, IProgressMonitor) line: 206 (out of synch)
BuildManager.basicBuild(IBuildConfiguration, int, IBuildContext, ICommand[], MultiStatus, IProgressMonitor) line: 246 (out of synch)
BuildManager$1.run() line: 301 (out of synch)
BuildManager.basicBuild(IBuildConfiguration, int, IBuildContext, MultiStatus, IProgressMonitor) line: 304 (out of synch)
BuildManager.basicBuildLoop(IBuildConfiguration[], IBuildConfiguration[], int, MultiStatus, IProgressMonitor) line: 360 (out of synch)
BuildManager.build(IBuildConfiguration[], IBuildConfiguration[], int, IProgressMonitor) line: 383 (out of synch)
AutoBuildJob.doBuild(IProgressMonitor) line: 144 (out of synch)
AutoBuildJob.run(IProgressMonitor) line: 235 (out of synch)
<obsolete method in<unknown declaring type>>
Thread [Worker-17] (Suspended (breakpoint at line 251 in AutoBuildJob))
AutoBuildJob.setInterrupted(boolean) line: 251
AutoBuildJob.isInterrupted() line: 204
MarkerUpdaterImpl.updateMarkers(IResourceDescription$Delta, ResourceSet, IProgressMonitor) line: 60
Worker.run() line: 55
Thread [Worker-20] (Suspended) (out of synch)
XtextBuilder.handleCanceled(Throwable) line: 198
XtextBuilder.build(int, Map, IProgressMonitor) line: 168
Re: IncrementalBuild loop in XText 2.11 [message #1766769 is a reply to message #1766763] |
Tue, 27 June 2017 03:02  |
Yes, it seems XtextBuilder is only asking for "isInterrupted", which is implemented in "InternalBuilder" as "return buildManager.autoBuildJob.isInterrupted();"
"AutoBuildJob.isInterrupted" does "if (isBlocking()) setInterrupted(true);"
And "isBlocking" is the function i posted before looking for previous jobs with more priority
Current Time: Sat Jul 26 13:24:14 EDT 2025
Powered by FUDForum. Page generated in 0.42122 seconds
