Home » Newcomers » Newcomers » Eclipse Clean build removing hidden files
Eclipse Clean build removing hidden files [message #176675] Thu, 26 October 2006 05:49 Go to next message
Originally posted by: rydtoft.hotmail.com
Hi group,
I use Eclipse and svn. Eclipse builds into a /classes folder which is also
in the svn repository and as such has a .svn sub folder in /classes/.svn
When I use the Clean build option in Eclipse (i.e. Project -> Clean) it
COMPLETELY wipes my /classes folder INCLUDING removing the .svn folder.
This is a problem as the .svn folder should never be deleted.
Is there a way to tell Eclipse to ignore certain folders and/or files when
using the Project -> Clean command?
Cheers Michael
Re: Eclipse Clean build removing hidden files [message #176964 is a reply to message #176675] Fri, 27 October 2006 07:38 Go to previous messageGo to next message
Hi Michael
Michael Rydtoft wrote:
> Hi group,
If it's by coincidence this clashes, I'd move the output folder in the
Eclipse project.
If it's intentional the you plan to store the compiled classes in your
repository, i have no answer, (aprat from rethinking your strategy)
I don't see any reason to store the compiled classes in the repo.
If other persons (users) need access the compiled classes, then you could
consider to let eclipse generate a jar (rightclick project and shoose
export) and deploy it on a shared drive instead.
Other developer would IMO not get access, as their project update would
clean and update the class files instantly :-)
If that did'nt happen, it would be highly possible that the class files
were inconsistent with their source and other class files a assume.
Yup, IMO highly intentional and should not be changed. :-)
> Cheers Michael
Re: Eclipse Clean build removing hidden files [message #177410 is a reply to message #176675] Mon, 30 October 2006 10:02 Go to previous message
> Hi group,
> also in the svn repository and as such has a .svn sub folder in
> /classes/.svn
> when using the Project -> Clean command?
I agree with the earlier response that it is not generally a good idea
to include derived content (such as .class files) in the repository. It
goes against what is a widely accepted "best practice" of the
Configuration Management/SCM world.
Having said that, you can probably get things set up to leave the files
alone. There is a Preference setting (under Java > Compiler > Building)
to disable the cleaning of the output directory, which you could use.
The ramification of doing so is that a "clean" build is no longer such -
it will leave behind old files.
You could also set up Eclipse to build into a different directory and
then use a small Ant script to copy the .class files into the directory
that is checked in to SVN.
Still, I would re-think the idea of having the compile output location
be checked in, unless there is some peculiar, specific reason your
project needs it that way.
Hope this helps,
Eric
Previous Topic:Entering Code
Next Topic:Can't unzip eclipse-SDK-3.2.1-win32.zip!
Current Time: Tue Jul 22 08:43:11 EDT 2025
Powered by FUDForum. Page generated in 0.07895 seconds
