Home » Modeling » TMF (Xtext) » IncrementalBuild loop in XText 2.11(IncrementalBuild loop in XText 2.11)
IncrementalBuild loop in XText 2.11 [message #1766711] Mon, 26 June 2017 09:01 Go to next message
I have the problem in a much bigger and customized project, but it also happens in a small default project
grammar org.xtext.example.mydsl1.BuildLoop with org.eclipse.xtext.common.Terminals
generate buildLoop "http://www.xtext.org/example/mydsl1/BuildLoop"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Loop: name=ID statements+=Statement+;
Statement: LoopRef | SimpleStatement | OtherName;
LoopRef: 'LOOP' ref=[Loop];
SimpleStatement: val=ID;
OtherName: 'OTHERNAME' name=ID;
Create a sample project and create the file src\test\LOOP1.loop
LOOP1
OTHERNAME other
Create a Java class to generate files with references to LOOP1
		for (int i = 1; i < 200; i++) {
			StringBuffer sb = new StringBuffer();
			sb.append("LOOPGEN").append(i).append("\n")
				.append("LOOP LOOP1\n")
				.append("\n");
			for (int j = 0 ; j < 500; j++) {
				sb.append("lkjdaskljdklasdj askldj askldj askldj askldj askldj a\n");
			Files.write(Paths.get("C:\\workspaces\\runtime-New_configuration\\testCycle4\\src\\gen\\LOOPGEN"+i+".loop"), sb.toString().getBytes());
The generated files will be something like this:
LOOPGEN1
LOOP LOOP1
Follow the steps:
* Clean: it works ok
* Change 'OTHERNAME other' for 'OTHERNAME other2'. Incremental build recompiles all dependencies ok
* Modify 'LOOP1' and change it to 'LOOP2'. Incremental build starts but it cancels, start again, etc. It doesn't never end
* Change LOOP2 to LOOP1. Incremental build starts but it cancels, start again, etc. It doesn't end never end
* Change 'OTHERNAME other' for 'OTHERNAME other2'. Incremental build recompiles all dependencies ok (if LOOP1 is the ID, if it's not nothing references the file)
Almost always it loops, but if it doesn't, closing and opening the project usually makes it happend again (after changing LOOP1).
It doen't happen if there's only a few files or if the files are shorter and compile faster.
I've debugged the XText code and i can see that the progress associated is canceled and it triggers a restart, but i cannot see why.
Any ideas?
Re: IncrementalBuild loop in XText 2.11 [message #1766712 is a reply to message #1766711] Mon, 26 June 2017 09:05 Go to previous messageGo to next message
do you have polling for external changes enabled in eclipse?
Re: IncrementalBuild loop in XText 2.11 [message #1766713 is a reply to message #1766712] Mon, 26 June 2017 09:09 Go to previous messageGo to next message
No, default preferences: "Build automatically" and "Refresh on access"
Re: IncrementalBuild loop in XText 2.11 [message #1766714 is a reply to message #1766713] Mon, 26 June 2017 09:12 Go to previous messageGo to next message
hmm could have been https://bugs.eclipse.org/bugs/show_bug.cgi?id=486083
so you should debug who interrupts autobuild. one candidate could be e.g. subclipse working on generated resources.
maybe generation files without ifile api might be bad ass well.
since eclipse/xtext call refresh during build and might pick it up
Re: IncrementalBuild loop in XText 2.11 [message #1766756 is a reply to message #1766714] Mon, 26 June 2017 18:01 Go to previous messageGo to next message
I tried to debug in my work but i couldn't download eclipse source files because of proxy problems ...
The environment was Eclipse 4.6.3 Xtext 2.11 Windows
I've tested in home with Eclipse 4.6.3 Xtext 2.12 Linux and it also happens
Following the advice to debug around:
org.eclipse.xtext.builder.impl.XtextBuilder.handleCanceled(Throwable)
org.eclipse.core.resources.IncrementalProjectBuilder.forgetLastBuiltState()
org.eclipse.core.internal.events.AutoBuildJob.setInterrupted(boolean)
I've found that XTextBuilder detects that is blocking a previous Job "JPA Project Change Event Handler(1044)" with more priority and decides to cancel.
This job is from "Dali Java Persistence Tools -JPA Support".
It seems to be the problem to some other plugins like Spring STS and others: https://jira.spring.io/browse/STS-4416
Some people say that disabling JPA validation is enough, but the project does not have the facet and also disabling al validation does not solve it.
Uninstalling the plugin does solve it though, but i'm not sure if i will miss anything necessary ...
Do you think it's more an inherent problem of Xtext build system or a bad behaviour of "Dali JPA"?
Is there anything to do other than removing the plugin?
I'll test tomorow with the real project.
Sergio
	JobManager.isBlocking(InternalJob) line: 824
		while (previous != null) {
			// ignore jobs of lower priority (higher priority value means lower priority)
			if (previous.getPriority() < runningJob.getPriority()) {
				if (!previous.isSystem())
					return true;
		runningJob=Building workspace(4)
		  .priority=40
		  .previous=JPA Project Change Event Handler(1044)
		  .previous=null
		  .priority=30
	Thread [Worker-20] (Suspended (breakpoint at line 824 in JobManager)) (out of synch)
		owns: Object  (id=655)
		owns: AutoBuildJob  (id=136)
		owns: ClusteringBuilderState  (id=262)
		AutoBuildJob(InternalJob).isBlocking() line: 316
		AutoBuildJob(Job).isBlocking() line: 443
		AutoBuildJob.isInterrupted() line: 203 (out of synch)
		XtextBuilder(InternalBuilder).isInterrupted() line: 171 (out of synch)
		XtextBuilder(IncrementalProjectBuilder).isInterrupted() line: 333 (out of synch)
		XtextBuilder.shouldCancelBuild(int) line: 189
		XtextBuilder.access$1(XtextBuilder, int) line: 188
		XtextBuilder$2.isCanceled() line: 146
		SubMonitor$RootInfo.isCanceled() line: 280
		SubMonitor.isCanceled() line: 616
		DefaultResourceUIValidatorExtension$1.isCanceled() line: 86
		OperationCanceledManager.xtend line: 76
		LazyLinkingResource.resolveLazyCrossReferences(CancelIndicator) line: 127
		EcoreUtil2.resolveLazyCrossReferences(Resource, CancelIndicator) line: 498
		ResourceValidatorImpl.resolveProxies(Resource, CancelIndicator) line: 161
		ResourceValidatorImpl.validate(Resource, CheckMode, CancelIndicator) line: 74
		DefaultResourceUIValidatorExtension.addMarkers(IFile, Resource, CheckMode, IProgressMonitor) line: 60
		DefaultResourceUIValidatorExtension.updateValidationMarkers(IFile, Resource, CheckMode, IProgressMonitor) line: 46
		MarkerUpdaterImpl.processDelta(IResourceDescription$Delta, ResourceSet, IProgressMonitor) line: 93
		MarkerUpdaterImpl.updateMarkers(IResourceDescription$Delta, ResourceSet, IProgressMonitor) line: 63
		ClusteringBuilderState(AbstractBuilderState).updateMarkers(IResourceDescription$Delta, ResourceSet, IProgressMonitor) line: 82
		ClusteringBuilderState.doUpdate(BuildData, ResourceDescriptionsData, IProgressMonitor) line: 283
		ClusteringBuilderState(AbstractBuilderState).update(BuildData, IProgressMonitor) line: 116
		XtextBuilder.doBuild(ToBeBuilt, IProgressMonitor, IXtextBuilderParticipant$BuildType) line: 287
		XtextBuilder.incrementalBuild(IResourceDelta, IProgressMonitor) line: 267
		XtextBuilder.build(int, Map, IProgressMonitor) line: 161
		BuildManager$2.run() line: 735 (out of synch)
		SafeRunner.run(ISafeRunnable) line: 42
		BuildManager.basicBuild(int, IncrementalProjectBuilder, Map<String,String>, MultiStatus, IProgressMonitor) line: 206 (out of synch)
		BuildManager.basicBuild(IBuildConfiguration, int, IBuildContext, ICommand[], MultiStatus, IProgressMonitor) line: 246 (out of synch)
		BuildManager$1.run() line: 301 (out of synch)
		BuildManager.basicBuild(IBuildConfiguration, int, IBuildContext, MultiStatus, IProgressMonitor) line: 304 (out of synch)
		BuildManager.basicBuildLoop(IBuildConfiguration[], IBuildConfiguration[], int, MultiStatus, IProgressMonitor) line: 360 (out of synch)
		BuildManager.build(IBuildConfiguration[], IBuildConfiguration[], int, IProgressMonitor) line: 383 (out of synch)
		AutoBuildJob.doBuild(IProgressMonitor) line: 144 (out of synch)
		AutoBuildJob.run(IProgressMonitor) line: 235 (out of synch)
		<obsolete method in<unknown declaring type>>
Thread [Worker-17] (Suspended (breakpoint at line 251 in AutoBuildJob))
		AutoBuildJob.setInterrupted(boolean) line: 251
		AutoBuildJob.isInterrupted() line: 204
		MarkerUpdaterImpl.updateMarkers(IResourceDescription$Delta, ResourceSet, IProgressMonitor) line: 60
		Worker.run() line: 55
	Thread [Worker-20] (Suspended) (out of synch)
		XtextBuilder.handleCanceled(Throwable) line: 198
		XtextBuilder.build(int, Map, IProgressMonitor) line: 168
Re: IncrementalBuild loop in XText 2.11 [message #1766763 is a reply to message #1766756] Mon, 26 June 2017 23:07 Go to previous messageGo to next message
There is this job prio comparison done?
Inside eclipse or inside Xtext?
I assume inside eclipse and Xtext is only a good citizen
And respects the cancellation it receives
Thus I assume it's a problem with the jpa job
Re: IncrementalBuild loop in XText 2.11 [message #1766769 is a reply to message #1766763] Tue, 27 June 2017 03:02 Go to previous message
Yes, it seems XtextBuilder is only asking for "isInterrupted", which is implemented in "InternalBuilder" as "return buildManager.autoBuildJob.isInterrupted();"
"AutoBuildJob.isInterrupted" does "if (isBlocking()) setInterrupted(true);"
And "isBlocking" is the function i posted before looking for previous jobs with more priority
Previous Topic:Question concerning package for IValueConverter
Next Topic:How to exclude resources from build
Current Time: Sat Jul 26 04:01:53 EDT 2025
Powered by FUDForum. Page generated in 0.08855 seconds
