Home » Eclipse Projects » Remote Application Platform (RAP) » invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on(invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on)
invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1766557] Fri, 23 June 2017 01:01 Go to next message
I have a RAP application with a treeviewer, On selecting the widgets on treeviewer
the invalid thread access exception is thrown. The exception is thrown when the same operation is done in multiple sessions at the same time.
Can anybody please help.
Thanks in Advance,
Sumy
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1766567 is a reply to message #1766557] Fri, 23 June 2017 03:01 Go to previous messageGo to next message
Hi, please provide a stack trace.
Ivan
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1766572 is a reply to message #1766567] Fri, 23 June 2017 04:24 Go to previous messageGo to next message
Hi Ivan,
Please find the stacktrace below.
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3546)
at org.eclipse.swt.SWT.error(SWT.java:3469)
at org.eclipse.swt.SWT.error(SWT.java:3440)
at org.eclipse.swt.widgets.Widget.error(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:966)
at org.eclipse.swt.widgets.Control.setEnabled(Control.java:345)
at com.bosch.icteam.editor.ui.adminview.ManageReleaseTab.setAddBtnEnabled(ManageReleaseTab.java:1667)
at com.bosch.icteam.editor.ui.pages.ProjectPage$2.selectionChanged(ProjectPage.java:361)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:166)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:52)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:177)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:164)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2170)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1193)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1223)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:232)
at org.eclipse.jface.util.OpenStrategy.access$3(OpenStrategy.java:226)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:403)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:85)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:696)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:598)
at org.eclipse.swt.widgets.Display.executeNextEvent(Display.java:1172)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1153)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1143)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2733)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:701)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:684)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at com.bosch.icteam.rap.projectdashboard.Application.start(Application.java:37)
at org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:186)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:298)
at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:104)
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1766595 is a reply to message #1766572] Fri, 23 June 2017 07:43 Go to previous messageGo to next message
Are you using RAP JFace bundle - org.eclipse.rap.jface? Is it possible to post the output of OSGi "ss" command?
Is it possible to create a simple snippet that demonstrates the issue?
Ivan
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1766705 is a reply to message #1766595] Mon, 26 June 2017 07:15 Go to previous messageGo to next message
Hi Ivan,
yes the plugin org.eclipse.rap.jface is used.
The exception is thrown while executing the selectionchangedlistener of the
treeviewer.
The output of ss command is as below.
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.9.0.v20130529-1710
Fragments=130, 172
1 ACTIVE org.eclipse.e4.core.commands_0.10.2.v20130515-1857
2 ACTIVE org.eclipse.e4.core.contexts_1.3.0.v20130514-1256
3 ACTIVE org.eclipse.birt.resources_4.2.1.v20120820
4 ACTIVE org.eclipse.birt.chart.device.pdf_4.2.1.v20120820
5 ACTIVE org.eclipse.rap.ui.forms_2.0.0.20130111-1314
6 ACTIVE org.eclipse.birt_4.2.1.v201209061114
7 ACTIVE javax.xml.soap_1.3.0.v201105210645
8 ACTIVE org.eclipse.birt.report.engine.emitter.config.odp_4.2.1.v20120820
9 RESOLVED org.eclipse.osee.framework.core.test_0.16.2.qualifier
Master=95
10 ACTIVE org.eclipse.jdt.launching_3.7.0.v20130515-1451
11 ACTIVE org.apache.commons.dbcp_1.4.0
12 ACTIVE org.objenesis_1.2.0
13 ACTIVE org.eclipse.osee.framework.logging_0.16.2.qualifier
Fragments=262
14 INSTALLED org.eclipse.ui_3.105.0.v20130522-1122
15 ACTIVE net.jini_2.2.2.v201312070133-DEV
16 ACTIVE org.eclipse.equinox.http.jetty_3.0.100.v20130327-1442
17 ACTIVE org.eclipse.equinox.app_1.3.100.v20130327-1442
18 INSTALLED org.eclipse.gef_3.8.1.201208201742
19 ACTIVE com.sun.jersey.multipart_1.18.0.v201312070133-DEV
20 ACTIVE org.eclipse.birt.report.data.oda.jdbc_4.2.1.v20120820
21 ACTIVE org.eclipse.rap.rwt.supplemental.fileupload_2.0.0.201404281234
22 ACTIVE org.eclipse.xtext.ui.codetemplates_2.3.1.v201208210947
23 INSTALLED org.eclipse.ui.win32_3.2.400.v20130516-1056
24 ACTIVE org.eclipse.birt.report.engine.emitter.config_4.2.1.v20120820
25 ACTIVE org.eclipse.e4.core.di_1.3.0.v20130514-1256
26 INSTALLED org.eclipse.e4.ui.workbench.addons.swt_1.0.0.v20130515-1857
27 ACTIVE org.eclipse.equinox.registry_3.5.300.v20130327-1442
Fragments=234
28 INSTALLED org.eclipse.ltk.ui.refactoring_3.7.100.v20130605-1748
30 ACTIVE com.lowagie.text_2.1.7.v201004222200
31 ACTIVE org.slf4j.api_1.6.1.v20100831-0715
Fragments=167
32 ACTIVE org.eclipse.xtext.xbase.lib_2.3.1.v201208210947
33 INSTALLED org.eclipse.xtext.common.types.ui_2.3.1.v201208210947
34 ACTIVE org.eclipse.osee.framework.database_0.16.2.qualifier
Fragments=163
35 ACTIVE org.eclipse.osee.framework.core.model_0.16.2.qualifier
Fragments=189
36 RESOLVED org.eclipse.osee.executor.admin.test_0.16.2.qualifier
Master=306
37 ACTIVE org.eclipse.rap.zest.core_1.5.0.201404281234
38 ACTIVE org.eclipse.datatools.connectivity_1.2.6.v201208210832
39 ACTIVE org.junit_4.11.0.v201303080030
40 ACTIVE org.eclipse.birt.report.engine.emitter.odp_4.2.1.v20120820
41 ACTIVE org.apache.batik.svggen_1.6.0.v201011041432
42 ACTIVE org.eclipse.xtext_2.3.1.v201208210947
43 ACTIVE org.eclipse.osee.orcs.core_0.16.2.qualifier
Fragments=100
44 ACTIVE org.eclipse.birt.report.engine.emitter.config.ppt_4.2.1.v20120820
45 ACTIVE org.hsqldb.hsqldb_2.2.9
46 ACTIVE org.antlr.runtime_3.2.0.v201101311130
47 ACTIVE org.eclipse.e4.ui.workbench_1.0.0.v20130531-1444
48 ACTIVE org.eclipse.equinox.p2.metadata_2.2.0.v20130523-1557
49 ACTIVE org.apache.batik.transcoder_1.6.0.v201011041432
50 RESOLVED org.eclipse.osee.logback.config_0.16.2.qualifier
Master=137
51 ACTIVE com.google.guava_10.0.1.v201203051515
52 INSTALLED org.eclipse.jdt.ui_3.9.0.v20130605-1748
53 ACTIVE org.eclipse.rap.ui.workbench_2.0.0.20130107-1035
54 ACTIVE org.apache.commons.fileupload_1.2.2
55 INSTALLED org.eclipse.zest.layouts_1.1.0.201208200205
56 ACTIVE org.apache.batik.pdf_1.6.0.v201105071520
57 ACTIVE org.eclipse.birt.example_4.2.1.v201209061114
58 ACTIVE org.eclipse.osee.framework.jdk.core_0.16.2.qualifier
Fragments=209
59 INSTALLED org.eclipse.e4.ui.css.swt.theme_0.9.2.v20120523-1955
60 ACTIVE org.eclipse.emf.ecore_2.9.0.v20130528-0742
62 ACTIVE org.eclipse.core.contenttype_3.4.200.v20130326-1255
63 ACTIVE org.eclipse.rap.ui.views_2.0.0.20130111-1314
64 INSTALLED org.eclipse.ui.forms_3.6.0.v20130517-0139
65 ACTIVE org.eclipse.emf.common_2.9.0.v20130528-0742
66 ACTIVE org.eclipse.jdt.core.manipulation_1.5.0.v20130605-1748
67 INSTALLED org.eclipse.e4.ui.workbench.renderers.swt_0.11.0.v20130603-1523
68 INSTALLED org.eclipse.e4.ui.workbench.swt_0.12.0.v20130517-0139
69 ACTIVE org.apache.batik.bridge_1.6.0.v201011041432
70 ACTIVE org.eclipse.birt.report.engine.dataextraction_4.2.1.v20120820
71 INSTALLED org.eclipse.ui.navigator_3.5.300.v20130517-0139
72 ACTIVE org.eclipse.birt.report.engine.emitter.postscript_4.2.1.v20120820
73 ACTIVE org.eclipse.rap.draw2d_1.5.0.201404281234
74 ACTIVE org.apache.commons.codec_1.4.0.v201209201156
75 ACTIVE org.eclipse.equinox.util_1.0.500.v20130404-1337
76 ACTIVE org.eclipse.birt.report.data.bidi.utils_4.2.1.v20120820
78 ACTIVE javax.inject_1.0.0.v20091030
79 ACTIVE org.eclipse.birt.report.engine.emitter.config.pdf_4.2.1.v20120820
80 INSTALLED org.eclipse.debug.ui_3.9.0.v20130516-1713
82 ACTIVE javax.annotation_1.1.0.v201209060031
83 ACTIVE org.eclipse.rap.zest.layouts_1.5.0.201404281234
84 ACTIVE org.eclipse.osee.console.admin_0.16.2.qualifier
Fragments=187
85 ACTIVE org.apache.commons.io_2.0.1.v201105210651
86 ACTIVE org.apache.commons.pool_1.6.0
87 ACTIVE org.eclipse.birt.report.engine.dataextraction.csv_4.2.1.v20120820
89 ACTIVE org.eclipse.birt.chart.device.svg_4.2.1.v20120820
90 ACTIVE org.eclipse.ant.core_3.2.500.v20130402-1746
91 ACTIVE org.objectweb.asm_3.3.1.v201105211655
92 ACTIVE org.eclipse.core.databinding.property_1.4.200.v20130515-1857
93 INSTALLED org.eclipse.xtext.ui_2.3.1.v201208210947
94 ACTIVE org.eclipse.equinox.bidi_0.10.0.v20130327-1442
95 ACTIVE org.eclipse.osee.framework.core_0.16.2.qualifier
Fragments=9
96 ACTIVE com.google.inject_3.0.0.v201203062045
97 ACTIVE org.eclipse.rap.design.example_2.0.0.20130110-2246
98 ACTIVE org.eclipse.equinox.preferences_3.5.100.v20130422-1538
100 RESOLVED org.eclipse.osee.orcs.core.test_0.16.2.qualifier
Master=43
101 ACTIVE org.eclipse.core.databinding_1.4.1.v20130515-1857
102 ACTIVE org.apache.batik.dom.svg_1.6.0.v201011041432
103 ACTIVE org.eclipse.birt.data_4.2.1.v201209121213
104 RESOLVED org.eclipse.jdt.compiler.apt_1.0.600.v20130530-1010
Master=256
105 ACTIVE org.eclipse.jetty.security_8.1.10.v20130312
106 RESOLVED org.eclipse.core.net.win32.x86_1.0.100.v20100505-1614
Master=211
107 INSTALLED org.eclipse.ui.console_3.5.200.v20130514-0954
108 ACTIVE org.eclipse.e4.core.services_1.1.0.v20130515-1343
109 ACTIVE org.codehaus.jackson.mapper_1.9.2.v201312070133-DEV
110 ACTIVE org.eclipse.birt.report.item.crosstab.core_4.2.1.v201208290612
111 ACTIVE org.eclipse.team.core_3.7.0.v20130514-1224
112 ACTIVE org.eclipse.osee.orcs.db.mock_0.16.2.qualifier
115 ACTIVE org.eclipse.birt.chart.device.extension_4.2.1.v20120820
116 INSTALLED org.eclipse.ui.workbench_3.105.0.v20130529-1406
117 INSTALLED org.eclipse.ui.intro_3.4.200.v20130326-1254
118 ACTIVE org.mozilla.javascript_1.7.2.v201005080400
119 INSTALLED org.eclipse.e4.ui.css.swt_0.11.0.v20130515-1857
120 ACTIVE org.eclipse.osee.event_0.16.2.qualifier
121 ACTIVE org.apache.xml.serializer_2.7.1.v201005080400
122 ACTIVE org.jvnet.mimepull_1.9.3.v201312070133-DEV
123 ACTIVE org.apache.commons.lang_2.4.0.v201005080502
124 ACTIVE org.eclipse.e4.ui.css.core_0.10.1.v20120523-1955
125 ACTIVE com.ibm.icu_4.4.2.v20110823
126 ACTIVE javax.activation_1.1.0.v201108011116
127 ACTIVE org.eclipse.rap.rwt.supplemental.filedialog_2.0.0.201404281234
128 ACTIVE org.cyberneko.html_1.9.14.v201105210654
129 ACTIVE org.eclipse.equinox.security_1.2.0.v20130424-1801
Fragments=287
130 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.2.100.v20120522-2049
Master=0
131 ACTIVE org.eclipse.e4.ui.model.workbench_1.0.0.v20130605-1738
133 ACTIVE org.eclipse.rap.ui_2.0.0.20121230-1109
134 INSTALLED org.eclipse.draw2d_3.8.1.201208201742
135 INSTALLED org.eclipse.ui.cheatsheets_3.4.200.v20130326-1254
136 INSTALLED org.eclipse.ui.workbench.texteditor_3.8.100.v20130514-1533
137 ACTIVE ch.qos.logback.classic_0.9.27.v20110224-1110
Fragments=50
138 ACTIVE com.springsource.org.hamcrest.core_1.1.0
139 ACTIVE org.eclipse.birt.data.aggregation_4.2.1.v20120820
140 ACTIVE org.eclipse.ltk.core.refactoring_3.6.100.v20130605-1748
142 ACTIVE net.jini_2.2.2.v201401212153-DEV
143 INSTALLED org.eclipse.ui.ide_3.9.0.v20130517-0139
144 INSTALLED org.eclipse.xtext.builder_2.3.1.v201208210947
146 INSTALLED org.eclipse.xtext.ui.codetemplates.ui_2.3.1.v201208210947
147 ACTIVE org.apache.httpcomponents.httpclient_4.1.3.v201209201135
148 ACTIVE org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354
149 ACTIVE org.eclipse.compare.core_3.5.300.v20130514-1224
150 ACTIVE org.eclipse.jdt.junit.runtime_3.4.400.v20130514-0733
151 ACTIVE org.eclipse.osee.logger_0.16.2.qualifier
152 ACTIVE org.eclipse.jetty.continuation_8.1.10.v20130312
153 INSTALLED org.eclipse.team.ui_3.7.0.v20130514-1224
154 ACTIVE org.eclipse.birt.report.engine.emitter.config.wpml_4.2.1.v20120820
155 ACTIVE org.eclipse.help.base_4.0.0.v20130605-2000
156 ACTIVE javax.wsdl_1.6.2.v201012040545
157 ACTIVE org.eclipse.osee.event.osgi_0.16.2.qualifier
159 INSTALLED org.eclipse.compare_3.5.400.v20130514-1224
160 INSTALLED org.eclipse.jface.databinding_1.6.200.v20130515-1857
161 INSTALLED org.eclipse.ui.views_3.6.100.v20130326-1250
162 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20130515-1857
163 RESOLVED org.eclipse.osee.framework.database.test_0.16.2.qualifier
Master=34
164 ACTIVE org.eclipse.equinox.common_3.6.200.v20130402-1505
165 INSTALLED org.eclipse.ui.views.properties.tabbed_3.6.0.v20130515-1857
166 ACTIVE org.eclipse.birt.report.engine.emitter.wpml_4.2.1.v20120820
167 RESOLVED ch.qos.logback.slf4j_0.9.27.v20110224-1110
Master=31
168 ACTIVE org.apache.derby.core_10.5.1.1_v20120820
169 RESOLVED org.eclipse.osee.framework.resource.management.test_0.16.2.qualifier
Master=282
170 ACTIVE org.eclipse.core.variables_3.2.700.v20130402-1741
171 ACTIVE org.eclipse.equinox.p2.repository_2.3.0.v20130412-2032
172 RESOLVED org.eclipse.birt.jetty.overlay_4.2.1.v201209061119
Master=0
173 INSTALLED org.eclipse.nebula.widgets.xviewer_0.9.9.201212230840
174 INSTALLED org.eclipse.e4.ui.bindings_0.10.100.v20130515-1857
175 ACTIVE org.mockito_1.9.0
176 ACTIVE org.eclipse.jdt.annotation_1.1.0.v20130513-1648
177 ACTIVE org.eclipse.rap.jface.databinding_2.0.0.20121031-1050
178 ACTIVE org.eclipse.rap.jface_2.0.0.20130107-0921
179 ACTIVE org.eclipse.birt.doc_4.2.1.v201209081329
180 ACTIVE org.eclipse.core.filebuffers_3.5.300.v20130225-1821
181 ACTIVE org.eclipse.birt.chart.engine.extension_4.2.1.v20120820
182 ACTIVE org.eclipse.jetty.servlet_8.1.10.v20130312
183 ACTIVE javax.ws.rs_1.1.1.v20101004-1200
184 ACTIVE org.eclipse.core.databinding.beans_1.2.200.v20130515-1857
185 ACTIVE org.eclipse.birt.report.engine.emitter.pdf_4.2.1.v20120820
186 ACTIVE javax.xml.soap_1.2.0.v201005080501
187 RESOLVED org.eclipse.osee.console.admin.test_0.16.2.qualifier
Master=84
188 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
189 RESOLVED org.eclipse.osee.framework.core.model.test_0.16.2.qualifier
Master=35
190 ACTIVE org.eclipse.birt.chart.reportitem_4.2.1.v20120820
191 RESOLVED org.eclipse.osee.orcs.test_0.16.2.qualifier
Master=300
192 RESOLVED org.eclipse.xtext.ui.shared_2.3.1.v201208210947
195 ACTIVE org.eclipse.emf.ecore.change_2.9.0.v20130528-0742
196 ACTIVE org.eclipse.equinox.p2.metadata.repository_1.2.100.v20130327-2119
197 ACTIVE org.eclipse.equinox.event_1.3.0.v20130327-1442
199 ACTIVE org.eclipse.e4.ui.services_1.0.0.v20130515-1857
200 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
201 ACTIVE org.eclipse.jetty.http_8.1.10.v20130312
202 ACTIVE org.eclipse.birt.report.engine.odf_4.2.1.v20120820
203 ACTIVE org.eclipse.osee.framework.core.dsl_0.16.2.qualifier
204 ACTIVE org.apache.batik.parser_1.6.0.v201011041432
206 ACTIVE com.google.gson_2.1.0.v201203072145
207 ACTIVE org.eclipse.birt.report.engine.emitter.config.postscript_4.2.1.v20120820
208 INSTALLED org.eclipse.emf.edit.ui_2.9.0.v20130610-0406
209 RESOLVED org.eclipse.osee.framework.jdk.core.test_0.16.2.qualifier
Master=58
210 ACTIVE org.eclipse.birt.report.engine.emitter.odt_4.2.1.v20120820
211 ACTIVE org.eclipse.core.net_1.2.200.v20130430-1352
Fragments=106
212 RESOLVED org.eclipse.birt.axis.overlay_4.2.1.v201209061119
Master=345
213 ACTIVE org.eclipse.birt.report.engine.emitter.html_4.2.1.v20120820
214 INSTALLED org.eclipse.ui.navigator.resources_3.4.500.v20130516-1049
215 ACTIVE org.eclipse.rap.nebula.widgets.xviewer_0.9.9.201212230840
216 ACTIVE org.eclipse.birt.chart.examples.core_4.2.1.v20120820
217 ACTIVE org.eclipse.rap.rwt_2.0.0.20130205-1612
218 ACTIVE org.eclipse.osee.hsqldb_0.16.2.qualifier
219 ACTIVE org.eclipse.equinox.p2.engine_2.3.0.v20130526-2122
220 ACTIVE org.eclipse.core.filesystem_1.4.0.v20130514-1240
Fragments=229
222 ACTIVE com.google.guava_12.0.0
223 ACTIVE org.eclipse.birt.report.data.adapter_4.2.1.v20120820
224 ACTIVE com.sun.jersey.client.apache_1.18.0.v201312070133-DEV
225 ACTIVE javax.mail.glassfish_1.4.1.v201005082020
227 ACTIVE org.jsoup_1.7.2
229 RESOLVED org.eclipse.core.filesystem.win32.x86_1.4.0.v20121112-0948
Master=220
231 ACTIVE org.eclipse.xtext.common.types_2.3.1.v201208210947
232 ACTIVE org.eclipse.osee.ats.api_0.16.2.qualifier
233 ACTIVE org.eclipse.equinox.p2.core_2.3.0.v20130327-2119
234 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.200.v20130514-1256
Master=27
235 ACTIVE org.w3c.sac_1.3.0.v20120820
236 ACTIVE org.eclipse.rap.draw2d.compatibility_1.5.0.201404281234
237 ACTIVE org.eclipse.birt.chart_4.2.1.v201209061114
238 ACTIVE org.apache.batik.dom_1.6.0.v201011041432
240 ACTIVE org.eclipse.xtext.util_2.3.1.v201208210947
242 ACTIVE org.codehaus.jackson.jaxrs_1.9.2.v201312070133-DEV
243 ACTIVE org.eclipse.equinox.console_1.0.100.v20130429-0953
244 ACTIVE org.eclipse.jdt.debug_3.8.0.v20130514-0841
245 ACTIVE org.eclipse.help_3.6.0.v20130326-1254
246 ACTIVE org.mockito.mockito-all_1.9.0
247 ACTIVE org.apache.commons.httpclient_3.1.0.v201012070820
248 ACTIVE org.eclipse.osee.ats.dsl_0.16.2.qualifier
249 RESOLVED org.eclipse.xtext.logging_1.2.15.v201208210947
Master=293
250 RESOLVED org.eclipse.jdt.compiler.tool_1.0.200.v20130530-1010
Master=256
251 ACTIVE org.eclipse.birt.core_4.2.1.v201209121203
252 ACTIVE org.eclipse.datatools.connectivity.oda.profile_3.2.8.v201209080429
253 ACTIVE org.eclipse.emf.ecore.xmi_2.9.0.v20130528-0742
254 ACTIVE org.eclipse.jetty.io_8.1.10.v20130312
256 ACTIVE org.eclipse.jdt.core_3.9.0.v20130604-1421
Fragments=104, 250
257 ACTIVE org.apache.batik.xml_1.6.0.v201011041432
258 ACTIVE org.codehaus.jackson.core_1.9.2.v201312070133-DEV
259 ACTIVE org.eclipse.birt.report.engine_4.2.1.v20120820
261 ACTIVE org.eclipse.birt.report.engine.emitter.config.html_4.2.1.v20120820
262 RESOLVED org.eclipse.osee.framework.logging.test_0.16.2.qualifier
Master=13
263 ACTIVE org.eclipse.birt.report.model_4.2.1.v201209121206
264 ACTIVE org.eclipse.birt.report.engine.emitter.config.ods_4.2.1.v20120820
265 INSTALLED org.eclipse.emf.common.ui_2.8.0.v20130610-0406
266 ACTIVE org.eclipse.birt.report.engine.emitter.config.excel_4.2.1.v20120820
267 ACTIVE javax.servlet_3.0.0.v201112011016
268 ACTIVE org.eclipse.birt.report.engine.emitter.ppt_4.2.1.v20120820
269 ACTIVE org.eclipse.core.runtime_3.9.0.v20130326-1255
271 ACTIVE org.hamcrest.core_1.3.0.v201303031735
272 ACTIVE org.eclipse.e4.ui.di_1.0.0.v20130515-1857
273 ACTIVE org.eclipse.core.resources_3.8.100.v20130521-2026
Fragments=303
274 ACTIVE org.eclipse.datatools.connectivity.oda_3.3.3.v201110130935
275 ACTIVE org.eclipse.equinox.http.registry_1.1.300.v20130402-1529
276 ACTIVE org.eclipse.core.jobs_3.5.300.v20130429-1813
277 ACTIVE org.eclipse.text_3.5.300.v20130515-1451
278 ACTIVE org.eclipse.core.commands_3.6.100.v20130515-1857
280 ACTIVE org.eclipse.core.expressions_3.4.500.v20130515-1343
281 ACTIVE org.apache.lucene.core_3.5.0.v20120725-1805
282 ACTIVE org.eclipse.osee.framework.resource.management_0.16.2.qualifier
Fragments=169
283 ACTIVE org.eclipse.rap.rwt.osgi_2.0.0.20130110-2216
284 ACTIVE org.eclipse.jetty.util_8.1.10.v20130312
286 ACTIVE ch.qos.logback.core_0.9.27.v20110224-1110
287 RESOLVED org.eclipse.equinox.security.win32.x86_1.0.300.v20130327-1442
Master=129
288 ACTIVE org.mozilla.javascript_1.7.4.v201209142200
289 ACTIVE org.eclipse.osgi.services_3.3.100.v20130513-1956
290 ACTIVE org.eclipse.emf.edit_2.9.0.v20130610-0406
291 ACTIVE org.eclipse.birt.core.script.function_4.2.1.v201209101712
292 ACTIVE org.eclipse.birt.report.engine.script.javascript_4.2.1.v20120820
293 ACTIVE org.apache.log4j_1.2.15.v201005080500
Fragments=249
294 ACTIVE org.eclipse.birt.report.data.oda.excel_4.2.1.v201208281709
295 INSTALLED org.eclipse.search_3.9.0.v20130312-1625
296 ACTIVE org.eclipse.birt.report.engine.emitter.config.odt_4.2.1.v20120820
297 ACTIVE org.eclipse.birt.report.engine.fonts_4.2.1.v20120820
298 ACTIVE org.eclipse.debug.core_3.8.0.v20130514-0954
300 ACTIVE org.eclipse.osee.orcs_0.16.2.qualifier
Fragments=191
301 ACTIVE org.eclipse.birt.chart.engine_4.2.1.v201209041636
303 RESOLVED org.eclipse.core.resources.win32.x86_3.5.100.v20100505-1741
Master=273
304 ACTIVE org.apache.xml.resolver_1.2.0.v201005080400
305 ACTIVE org.eclipse.e4.core.di.extensions_0.11.100.v20130514-1256
306 ACTIVE org.eclipse.osee.executor.admin_0.16.2.qualifier
Fragments=36
307 ACTIVE org.eclipse.equinox.ds_1.4.100.v20130515-2026
308 ACTIVE com.sun.jersey_1.18.0.v201312070133-DEV
309 ACTIVE org.eclipse.jetty.server_8.1.10.v20130312
310 INSTALLED org.eclipse.jface_3.9.0.v20130521-1714
311 ACTIVE org.apache.xerces_2.9.0.v201101211617
312 ACTIVE org.eclipse.datatools.connectivity.oda.consumer_3.2.5.v201109151100
313 INSTALLED org.eclipse.jface.text_3.8.100.v20130515-1957
314 INSTALLED org.eclipse.e4.ui.workbench3_0.12.0.v20130515-1857
315 INSTALLED org.eclipse.e4.ui.widgets_1.0.0.v20130515-1857
316 INSTALLED org.eclipse.ui.trace_1.0.100.v20130508-1926
317 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
318 INSTALLED org.eclipse.ui.editors_3.8.100.v20130513-1637
339 ACTIVE org.apache.batik.ext.awt_1.6.0.v201011041432
340 ACTIVE javax.xml_1.3.4.v201005080400
341 ACTIVE org.apache.batik.css_1.6.0.v201011041432
342 ACTIVE org.apache.httpcomponents.httpcore_4.1.4.v201203221030
343 ACTIVE org.apache.batik.util.gui_1.6.0.v201011041432
344 ACTIVE org.apache.batik.util_1.6.0.v201011041432
345 ACTIVE org.apache.axis_1.4.0.v201005080400
Fragments=212
346 ACTIVE org.apache.lucene.analysis_3.5.0.v20120725-1805
347 ACTIVE org.w3c.dom.svg_1.1.0.v201011041433
348 ACTIVE javax.xml.rpc_1.1.0.v201005080400
349 ACTIVE org.w3c.css.sac_1.3.1.v200903091627
350 ACTIVE org.w3c.dom.smil_1.0.0.v200806040011
351 ACTIVE org.apache.commons.logging_1.1.1.v201101211721
352 ACTIVE org.apache.commons.discovery_0.2.0.v201004190315
353 ACTIVE com.bosch.icteam.images_3.0.0.qualifier
354 ACTIVE com.bosch.icteam.jenkins.connector_3.0.0.qualifier
355 ACTIVE com.bosch.icteam.common.clientserver_3.0.0.qualifier
356 ACTIVE com.bosch.icteam.logging_3.0.0.qualifier
357 ACTIVE com.bosch.icteam.web.client.editor.ui_3.0.0.qualifier
358 ACTIVE com.bosch.icteam.web.calibration_3.0.0.qualifier
359 ACTIVE com.bosch.icteam.web.testmanagement.manager_3.0.0.qualifier
360 ACTIVE com.bosch.icteam.thirdparty_3.0.0.qualifier
361 ACTIVE com.bosch.icteam.rap.buildmanagement_3.0.0.qualifier
362 ACTIVE org.eclipse.osee.authentication.oauth.consumer_3.0.0.qualifier
363 ACTIVE com.bosch.icteam.charts.ui_3.0.0.qualifier
364 ACTIVE com.bosch.icteam.rap.projectdashboard_3.0.0.qualifier
365 ACTIVE com.bosch.icteam.cache.data_3.0.0.qualifier
366 ACTIVE com.bosch.icteam.chartsmodel_3.0.0.qualifier
367 ACTIVE com.bosch.icteam.editor.common_3.0.0.qualifier
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1766710 is a reply to message #1766705] Mon, 26 June 2017 08:31 Go to previous messageGo to next message
you have 367 plugins in your target platform and you have a mixture between RCP and RAP plugins. Some RAP plugins are not ACTIVE, but INSTALLED. My suggestion is to split the RAP target platform from RCP target platform. The RCP bundles are designed for single-user environment (have statics alot) and can not be used in multi-user environment as RAP. I'm sure that once you remove the RCP bundles from the RAP target platform the exception will be gone.
Ivan
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1766800 is a reply to message #1766710] Tue, 27 June 2017 07:37 Go to previous messageGo to next message
All RAP plugins are ACTIVE. But I still get the same Exception.
Output of ss Command is as below:
ss
id State Bundle
Fragments=70, 189
1 ACTIVE org.eclipse.osee.ats.api_0.16.2.qualifier
2 ACTIVE org.eclipse.core.net_1.2.200.v20130430-1352
Fragments=22
4 RESOLVED org.eclipse.osee.framework.core.dsl.integration.test_0.16.2.qualifier
Master=49
5 ACTIVE org.eclipse.core.contenttype_3.4.200.v20130326-1255
6 RESOLVED org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20130521-0416
Master=243
7 RESOLVED org.eclipse.osee.framework.jdk.core.test_0.16.2.qualifier
Master=91
8 ACTIVE org.eclipse.e4.core.di_1.3.0.v20130514-1256
9 ACTIVE com.lowagie.text_2.1.7.v201004222200
10 ACTIVE org.eclipse.osee.display.presenter.mocks_0.16.2.qualifier
11 ACTIVE org.eclipse.osee.mail_0.16.2.qualifier
Fragments=196
12 ACTIVE org.eclipse.emf.ecore.edit_2.8.0.v20130610-0406
13 ACTIVE org.eclipse.core.databinding_1.4.1.v20130515-1857
14 ACTIVE org.eclipse.emf.mapping.ecore2xml.ui_2.6.0.v20130610-0406
15 ACTIVE org.eclipse.jetty.io_8.1.10.v20130312
16 ACTIVE org.eclipse.equinox.bidi_0.10.0.v20130327-1442
17 ACTIVE org.eclipse.jetty.security_8.1.10.v20130312
18 ACTIVE org.eclipse.e4.ui.workbench.addons.swt_1.0.0.v20130515-1857
19 ACTIVE org.eclipse.mylyn.bugzilla.core_3.8.1.v20120725-0100
20 RESOLVED org.eclipse.osee.console.admin.test_0.16.2.qualifier
Master=212
21 ACTIVE javax.xml_1.3.4.v201005080400
22 RESOLVED org.eclipse.core.net.win32.x86_1.0.100.v20100505-1614
Master=2
23 ACTIVE org.eclipse.osee.ats.impl_0.16.2.qualifier
Fragments=214
24 RESOLVED org.eclipse.xtext.logging_1.2.15.v201208210947
Master=123
25 RESOLVED org.eclipse.osee.orcs.db.test_0.16.2.qualifier
Master=302
26 ACTIVE org.eclipse.osee.framework.lifecycle_0.16.2.qualifier
Fragments=109
27 ACTIVE org.eclipse.e4.core.services_1.1.0.v20130515-1343
28 ACTIVE org.eclipse.osee.framework.manager.servlet_0.16.2.qualifier
29 ACTIVE com.google.gson_2.1.0.v201203072145
30 ACTIVE org.eclipse.rap.rwt_2.0.0.20130205-1612
31 ACTIVE org.eclipse.text_3.5.300.v20130515-1451
32 ACTIVE org.junit_4.11.0.v201303080030
33 ACTIVE org.eclipse.swt_3.102.0.v20130605-1539
Fragments=116
34 ACTIVE org.eclipse.ui_3.105.0.v20130522-1122
35 ACTIVE org.eclipse.osee.disposition.rest_0.16.2.qualifier
Fragments=133
36 ACTIVE org.eclipse.e4.ui.model.workbench_1.0.0.v20130605-1738
37 ACTIVE org.eclipse.e4.ui.workbench.swt_0.12.0.v20130517-0139
38 RESOLVED org.eclipse.osee.orcs.test_0.16.2.qualifier
Master=100
39 ACTIVE org.eclipse.equinox.preferences_3.5.100.v20130422-1538
40 ACTIVE com.sun.jersey_1.18.0.v201312070133-DEV
41 ACTIVE com.bosch.icteam.license.scheduler_3.0.0.qualifier
42 ACTIVE org.eclipse.ui.ide_3.9.0.v20130517-0139
Fragments=237
43 ACTIVE org.eclipse.xtext.xbase.lib_2.3.1.v201208210947
44 RESOLVED org.eclipse.equinox.security.win32.x86_1.0.300.v20130327-1442
Master=291
45 ACTIVE org.apache.xml.resolver_1.2.0.v201005080400
46 ACTIVE org.eclipse.mylyn.commons.core_3.8.1.v20120725-0100
47 ACTIVE org.eclipse.persistence.moxy_2.5.1.v20130913-5eaeb06
48 ACTIVE org.eclipse.xtext_2.3.1.v201208210947
49 ACTIVE org.eclipse.osee.framework.core.dsl.integration_0.16.2.qualifier
Fragments=4
50 ACTIVE com.google.guava_12.0.0
51 ACTIVE org.codehaus.jackson.mapper_1.9.2.v201312070133-DEV
52 ACTIVE org.eclipse.e4.ui.widgets_1.0.0.v20130515-1857
53 RESOLVED org.eclipse.osee.ats.presenter.test_0.16.2.qualifier
Master=194
54 ACTIVE org.eclipse.osee.ats.core_0.16.2.qualifier
Fragments=246
55 ACTIVE org.apache.ws.commons.util_1.0.1.v20100518-1140
56 ACTIVE com.bosch.icteam.thirdparty_3.0.0.qualifier
57 ACTIVE org.eclipse.osee.ats.view.web_0.16.2.qualifier
Fragments=265
58 ACTIVE org.eclipse.equinox.p2.metadata_2.2.0.v20130523-1557
59 ACTIVE org.eclipse.e4.core.di.extensions_0.11.100.v20130514-1256
60 RESOLVED ch.qos.logback.slf4j_0.9.27.v20110224-1110
Master=149
61 ACTIVE javax.el_2.2.0.v201303151357
62 ACTIVE org.eclipse.mylyn.commons.repositories.core_1.0.1.v20120725-0100
63 ACTIVE org.eclipse.compare.core_3.5.300.v20130514-1224
64 ACTIVE org.objenesis_1.2.0
65 ACTIVE org.eclipse.osee.display.view.web_0.16.2.qualifier
66 ACTIVE org.eclipse.core.filesystem_1.4.0.v20130514-1240
Fragments=282
67 ACTIVE org.eclipse.osee.database.schema_0.16.2.qualifier
68 ACTIVE org.eclipse.jetty.servlet_8.1.10.v20130312
69 RESOLVED org.eclipse.osee.framework.core.test_0.16.2.qualifier
Master=264
70 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.2.100.v20120522-2049
Master=0
71 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
72 ACTIVE org.eclipse.team.core_3.7.0.v20130514-1224
73 RESOLVED org.eclipse.osee.cache.admin.test_0.16.2.qualifier
Master=168
74 ACTIVE org.eclipse.equinox.p2.repository_2.3.0.v20130412-2032
75 ACTIVE com.bosch.icteam.server.database_3.0.0.qualifier
76 ACTIVE org.eclipse.osee.oauth.server_3.0.0.qualifier
77 ACTIVE org.eclipse.osee.rest.client_0.16.2.qualifier
78 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
79 ACTIVE com.bosch.icteam.calibrationworkflow.ice.dcmparser_3.0.0.qualifier
80 ACTIVE org.aopalliance_1.0.0.v201105210816
81 ACTIVE com.bosch.icteam.myln.connector_3.0.0.qualifier
82 ACTIVE org.apache.httpcomponents.httpcore_4.1.4.v201203221030
83 ACTIVE org.eclipse.equinox.event_1.3.0.v20130327-1442
84 ACTIVE org.eclipse.emf.ecore.change_2.9.0.v20130528-0742
85 ACTIVE org.eclipse.emf.ecore_2.9.0.v20130528-0742
86 ACTIVE org.eclipse.e4.ui.css.swt_0.11.0.v20130515-1857
87 ACTIVE org.eclipse.osee.rest.admin_0.16.2.qualifier
88 ACTIVE com.bosch.icteam.calibrationworkflow.a2lgen.a2lparser_3.0.0.qualifier
89 ACTIVE com.bosch.icteam.server.access_3.0.0.qualifier
90 ACTIVE org.eclipse.equinox.console.ssh_1.0.0.v20130515-2026
91 ACTIVE org.eclipse.osee.framework.jdk.core_0.16.2.qualifier
Fragments=7
92 ACTIVE com.sun.jersey.multipart_1.18.0.v201312070133-DEV
93 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.200.v20130514-1256
Master=231
94 ACTIVE org.hsqldb.hsqldb_2.2.9
95 ACTIVE org.eclipse.rmf.reqif10_0.4.0.qualifier
96 ACTIVE javax.activation_1.1.0.v201108011116
97 ACTIVE com.bosch.icteam.web.rest.layer_3.0.0.qualifier
98 RESOLVED org.eclipse.osee.display.presenter.test_0.16.2.qualifier
Master=248
99 ACTIVE javax.xml.stream_1.0.1.v201004272200
100 ACTIVE org.eclipse.osee.orcs_0.16.2.qualifier
Fragments=38
101 ACTIVE org.eclipse.persistence.core_2.5.1.v20130913-5eaeb06
102 ACTIVE org.eclipse.e4.ui.workbench3_0.12.0.v20130515-1857
103 ACTIVE org.eclipse.emf.importer.ecore_2.7.0.v20130610-0406
104 ACTIVE org.eclipse.emf_2.6.0.v20130610-0406
105 RESOLVED org.eclipse.osee.framework.core.model.test_0.16.2.qualifier
Master=285
106 ACTIVE org.eclipse.osee.ats.dsl_0.16.2.qualifier
107 ACTIVE org.eclipse.ui.workbench_3.105.0.v20130529-1406
108 RESOLVED org.eclipse.jdt.compiler.tool_1.0.200.v20130530-1010
Master=283
109 RESOLVED org.eclipse.osee.framework.lifecycle.test_0.16.2.qualifier
Master=26
110 ACTIVE org.eclipse.emf.edit.ui_2.9.0.v20130610-0406
111 ACTIVE org.eclipse.osee.template.engine_0.16.2.qualifier
Fragments=227
112 RESOLVED org.eclipse.osee.framework.logging.test_0.16.2.qualifier
Master=163
113 ACTIVE javax.servlet.jsp_2.2.0.v201112011158
114 ACTIVE org.eclipse.emf.ecore.editor_2.9.0.v20130610-0406
115 ACTIVE org.eclipse.emf.ecore.xmi_2.9.0.v20130528-0742
116 RESOLVED org.eclipse.swt.win32.win32.x86_3.102.0.v20130605-1544
Master=33
117 ACTIVE org.eclipse.e4.ui.css.swt.theme_0.9.2.v20120523-1955
118 ACTIVE org.eclipse.emf.codegen.ecore.ui_2.9.0.v20130610-0406
119 RESOLVED org.eclipse.osee.executor.admin.test_0.16.2.qualifier
Master=124
120 ACTIVE org.eclipse.e4.ui.workbench_1.0.0.v20130531-1444
121 ACTIVE org.eclipse.mylyn.commons.net_3.8.1.v20120725-0100
122 ACTIVE org.eclipse.mylyn.commons.xmlrpc_3.8.1.v20120725-0100
123 ACTIVE org.apache.log4j_1.2.15.v201005080500
Fragments=24
124 ACTIVE org.eclipse.osee.executor.admin_0.16.2.qualifier
Fragments=119
125 ACTIVE org.codehaus.jackson.core_1.9.2.v201312070133-DEV
126 ACTIVE org.eclipse.emf.ant_2.8.0.v20130610-0406
127 ACTIVE org.postgresql.driver_8.3.0.201001291038
128 ACTIVE org.eclipse.jetty.util_8.1.10.v20130312
129 ACTIVE org.eclipse.osee.logger.slf4j_0.16.2.qualifier
130 ACTIVE com.bosch.icteam.ldap.configuration_3.0.0.qualifier
131 ACTIVE org.apache.commons.httpclient_3.1.0.v201012070820
132 ACTIVE org.eclipse.e4.ui.bindings_0.10.100.v20130515-1857
133 RESOLVED org.eclipse.osee.disposition.rest.test_0.16.2.qualifier
Master=35
134 ACTIVE org.eclipse.equinox.p2.core_2.3.0.v20130327-2119
135 ACTIVE org.eclipse.core.expressions_3.4.500.v20130515-1343
136 RESOLVED org.eclipse.core.resources.win32.x86_3.5.100.v20100505-1741
Master=234
137 ACTIVE org.mockito_1.9.0
138 ACTIVE org.eclipse.emf.mapping.ecore2ecore_2.7.0.v20130610-0406
139 ACTIVE org.eclipse.jdt.debug_3.8.0.v20130514-0841
140 ACTIVE org.eclipse.ui.views_3.6.100.v20130326-1250
141 ACTIVE org.slf4j.jcl_1.6.1.v20100831-0715
142 ACTIVE javax.servlet_3.0.0.v201112011016
143 ACTIVE org.eclipse.osee.disposition.rest.model_0.16.2.qualifier
144 ACTIVE org.eclipse.emf.mapping.ecore2xml_2.7.0.v20130610-0406
145 ACTIVE org.eclipse.emf.importer.rose_2.7.0.v20130610-0406
146 ACTIVE org.eclipse.osee.framework.core.dsl_0.16.2.qualifier
147 ACTIVE org.eclipse.persistence.asm_3.3.1.v201302191223
148 ACTIVE com.bosch.icteam.calibrationworkflow.ice.dcmmodel_3.0.0.qualifier
149 ACTIVE org.slf4j.api_1.6.1.v20100831-0715
Fragments=60
150 ACTIVE com.bosch.icteam.server.license.manager_3.0.0.qualifier
151 ACTIVE org.eclipse.emf.codegen_2.9.0.v20130610-0406
152 ACTIVE org.objectweb.asm_3.3.1.v201105211655
153 ACTIVE com.bosch.artrace.rest.layer_3.0.0.qualifier
154 ACTIVE org.eclipse.ant.core_3.2.500.v20130402-1746
155 ACTIVE org.eclipse.osee.display.api_0.16.2.qualifier
156 ACTIVE org.w3c.css.sac_1.3.1.v200903091627
157 ACTIVE org.eclipse.jetty.continuation_8.1.10.v20130312
158 ACTIVE org.codehaus.jackson.jaxrs_1.9.2.v201312070133-DEV
159 ACTIVE org.eclipse.equinox.ds_1.4.100.v20130515-2026
160 ACTIVE org.eclipse.osee.hsqldb_0.16.2.qualifier
161 ACTIVE org.eclipse.e4.ui.css.core_0.10.1.v20120523-1955
162 ACTIVE com.bosch.icteam.calibrationworkflow.a2lgen.aom_3.0.0.qualifier
163 ACTIVE org.eclipse.osee.framework.logging_0.16.2.qualifier
Fragments=112
164 ACTIVE org.apache.xml.serializer_2.7.1.v201005080400
165 ACTIVE com.sun.jersey.client.apache_1.18.0.v201312070133-DEV
166 ACTIVE org.eclipse.osee.orcs.rest_0.16.2.qualifier
Fragments=266
167 ACTIVE org.eclipse.rap.jface_2.0.0.20130107-0921
168 ACTIVE org.eclipse.osee.cache.admin_0.16.2.qualifier
Fragments=73
169 ACTIVE org.eclipse.osee.framework.core.server_0.16.2.qualifier
Fragments=175
170 ACTIVE org.w3c.dom.svg_1.1.0.v201011041433
171 ACTIVE org.eclipse.osee.ats.ui.api_0.16.2.qualifier
172 ACTIVE org.eclipse.equinox.util_1.0.500.v20130404-1337
173 ACTIVE com.ibm.icu_4.4.2.v20110823
174 ACTIVE org.apache.batik.css_1.6.0.v201011041432
175 RESOLVED org.eclipse.osee.framework.core.server.test_0.16.2.qualifier
Master=169
176 ACTIVE org.eclipse.osee.database_0.16.2.qualifier
177 ACTIVE org.eclipse.equinox.p2.metadata.repository_1.2.100.v20130327-2119
178 ACTIVE org.eclipse.e4.ui.workbench.renderers.swt_0.11.0.v20130603-1523
179 ACTIVE org.apache.httpcomponents.httpclient_4.1.3.v201209201135
180 ACTIVE org.apache.xerces_2.9.0.v201101211617
181 ACTIVE org.eclipse.emf.codegen.ecore_2.9.0.v20130610-0406
182 ACTIVE com.bosch.artrace.server.types_3.0.0.qualifier
183 ACTIVE org.eclipse.jdt.launching_3.7.0.v20130515-1451
184 ACTIVE org.w3c.dom.smil_1.0.0.v200806040011
185 ACTIVE org.eclipse.e4.core.commands_0.10.2.v20130515-1857
186 RESOLVED org.eclipse.osee.orcs.core.test_0.16.2.qualifier
Master=224
187 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20130515-1857
188 ACTIVE org.eclipse.core.jobs_3.5.300.v20130429-1813
189 RESOLVED org.eclipse.birt.jetty.overlay_4.2.1.v201209061119
Master=0
190 ACTIVE org.eclipse.debug.core_3.8.0.v20130514-0954
191 ACTIVE org.eclipse.emf.databinding_1.3.0.v20130610-0406
192 ACTIVE org.eclipse.osee.display.mvp_0.16.2.qualifier
Fragments=197
193 ACTIVE org.eclipse.emf.mapping.ecore2ecore.editor_2.6.0.v20130610-0406
194 ACTIVE org.eclipse.osee.ats.presenter_0.16.2.qualifier
Fragments=53
195 ACTIVE org.eclipse.equinox.app_1.3.100.v20130327-1442
196 RESOLVED org.eclipse.osee.mail.test_0.16.2.qualifier
Master=11
197 RESOLVED org.eclipse.osee.display.mvp.test_0.16.2.qualifier
Master=192
198 ACTIVE org.eclipse.core.variables_3.2.700.v20130402-1741
199 ACTIVE com.bosch.artrace.common_3.0.0.qualifier
200 ACTIVE org.eclipse.emf.importer_2.8.0.v20130610-0406
201 ACTIVE ch.qos.logback.classic_0.9.27.v20110224-1110
Fragments=241
202 RESOLVED org.eclipse.osee.vaadin.themes_0.16.2.qualifier
Master=277
203 ACTIVE org.eclipse.rmf.serialization_0.4.0.qualifier
204 RESOLVED org.eclipse.osee.framework.resource.management.test_0.16.2.qualifier
Master=260
205 ACTIVE com.bosch.icteam.authentication.custom_3.0.0.qualifier
206 ACTIVE com.bosch.icteam.common.clientserver_3.0.0.qualifier
207 ACTIVE org.eclipse.osee.orcs.rest.model_0.16.2.qualifier
208 ACTIVE org.eclipse.help_3.6.0.v20130326-1254
209 ACTIVE org.eclipse.e4.core.contexts_1.3.0.v20130514-1256
210 ACTIVE org.eclipse.osee.orcs.db.mock_0.16.2.qualifier
211 RESOLVED org.eclipse.osee.framework.database.test_0.16.2.qualifier
Master=228
212 ACTIVE org.eclipse.osee.console.admin_0.16.2.qualifier
Fragments=20
213 ACTIVE org.eclipse.core.databinding.property_1.4.200.v20130515-1857
214 RESOLVED org.eclipse.osee.ats.impl.test_0.16.2.qualifier
Master=23
215 ACTIVE org.eclipse.equinox.http.jetty_3.0.100.v20130327-1442
216 ACTIVE org.eclipse.emf.converter_2.6.0.v20130610-0406
217 ACTIVE org.eclipse.jface.text_3.8.100.v20130515-1957
218 ACTIVE org.eclipse.emf.common_2.9.0.v20130528-0742
220 ACTIVE org.apache.xmlrpc_3.0.0.v20100427-1100
221 ACTIVE org.apache.commons.dbcp_1.4.0
222 ACTIVE org.apache.commons.pool_1.6.0
223 ACTIVE org.eclipse.e4.ui.services_1.0.0.v20130515-1857
224 ACTIVE org.eclipse.osee.orcs.core_0.16.2.qualifier
Fragments=186
225 ACTIVE org.eclipse.osee.ats.rest_0.16.2.qualifier
226 ACTIVE org.eclipse.emf.mapping.ui_2.6.0.v20130610-0406
227 RESOLVED org.eclipse.osee.template.engine.test_0.16.2.qualifier
Master=111
228 ACTIVE org.eclipse.osee.framework.database_0.16.2.qualifier
Fragments=211
229 ACTIVE org.eclipse.jetty.server_8.1.10.v20130312
230 ACTIVE org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354
231 ACTIVE org.eclipse.equinox.registry_3.5.300.v20130327-1442
Fragments=93
232 ACTIVE org.json_1.0.0.v201011060100
233 ACTIVE org.antlr.runtime_3.2.0.v201101311130
234 ACTIVE org.eclipse.core.resources_3.8.100.v20130521-2026
Fragments=136
235 ACTIVE org.eclipse.equinox.common_3.6.200.v20130402-1505
236 RESOLVED org.eclipse.jdt.compiler.apt_1.0.600.v20130530-1010
Master=283
237 RESOLVED org.eclipse.ui.win32_3.2.400.v20130516-1056
Master=42
238 ACTIVE org.eclipse.emf.common.ui_2.8.0.v20130610-0406
239 ACTIVE org.eclipse.emf.ecore.change.edit_2.5.0.v20130610-0406
240 ACTIVE com.springsource.org.hamcrest.core_1.1.0
241 RESOLVED org.eclipse.osee.logback.config_0.16.2.qualifier
Master=201
242 ACTIVE org.eclipse.e4.ui.di_1.0.0.v20130515-1857
243 ACTIVE org.eclipse.equinox.launcher_1.3.0.v20130327-1440
Fragments=6
244 ACTIVE org.eclipse.osee.framework.core.message_0.16.2.qualifier
Fragments=261
245 ACTIVE org.eclipse.emf.edit_2.9.0.v20130610-0406
246 RESOLVED org.eclipse.osee.ats.core.test_0.16.2.qualifier
Master=54
247 ACTIVE org.eclipse.osgi.services_3.3.100.v20130513-1956
248 ACTIVE org.eclipse.osee.display.presenter_0.16.2.qualifier
Fragments=98
249 ACTIVE org.eclipse.osee.event_0.16.2.qualifier
250 ACTIVE org.apache.ant_1.8.4.v201303080030
251 ACTIVE org.apache.commons.io_2.0.1.v201105210651
252 ACTIVE org.eclipse.osee.framework.authentication.ldap.core_3.0.0.qualifier
253 ACTIVE org.eclipse.mylyn.tasks.core_3.8.1.v20120725-0100
254 ACTIVE com.bosch.icteam.generate.boschbiz.cache_3.0.0.qualifier
255 ACTIVE org.eclipse.jface_3.9.0.v20130521-1714
256 ACTIVE org.apache.commons.lang_2.4.0.v201005080502
257 ACTIVE org.eclipse.osee.orcs.rest.client_0.16.2.qualifier
258 ACTIVE org.eclipse.xtext.common.types_2.3.1.v201208210947
259 ACTIVE org.eclipse.xtext.util_2.3.1.v201208210947
260 ACTIVE org.eclipse.osee.framework.resource.management_0.16.2.qualifier
Fragments=204
261 RESOLVED org.eclipse.osee.framework.core.message.test_0.16.2.qualifier
Master=244
262 ACTIVE org.apache.batik.util_1.6.0.v201011041432
263 ACTIVE org.eclipse.emf.codegen.ui_2.6.0.v20130610-0406
264 ACTIVE org.eclipse.osee.framework.core_0.16.2.qualifier
Fragments=69
265 RESOLVED org.eclipse.osee.ats.view.web.test_0.16.2.qualifier
Master=57
266 RESOLVED org.eclipse.osee.orcs.rest.test_0.16.2.qualifier
Master=166
267 ACTIVE org.eclipse.osee.event.osgi_0.16.2.qualifier
268 ACTIVE com.bosch.icteam.ldap.server_3.0.0.qualifier
269 ACTIVE com.google.inject_3.0.0.v201203062045
270 ACTIVE org.jvnet.mimepull_1.9.3.v201312070133-DEV
271 ACTIVE org.eclipse.persistence.antlr_3.2.0.v201302191141
272 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
273 ACTIVE org.eclipse.emf.exporter_2.7.0.v20130610-0406
274 ACTIVE org.eclipse.osee.logger_0.16.2.qualifier
275 ACTIVE org.apache.commons.logging_1.1.1.v201101211721
276 ACTIVE org.eclipse.jface.databinding_1.6.200.v20130515-1857
277 ACTIVE com.vaadin_6.7.0.v201203200040-DEV
Fragments=202
278 ACTIVE javax.annotation_1.1.0.v201209060031
279 ACTIVE com.bosch.icteam.ldap.server.support_3.0.0.qualifier
280 ACTIVE org.eclipse.emf.mapping.ecore.editor_2.6.0.v20130610-0406
281 ACTIVE javax.inject_1.0.0.v20091030
282 RESOLVED org.eclipse.core.filesystem.win32.x86_1.4.0.v20121112-0948
Master=66
283 ACTIVE org.eclipse.jdt.core_3.9.0.v20130604-1421
Fragments=108, 236
284 ACTIVE org.eclipse.core.runtime_3.9.0.v20130326-1255
285 ACTIVE org.eclipse.osee.framework.core.model_0.16.2.qualifier
Fragments=105
286 ACTIVE javax.ws.rs_1.1.1.v20101004-1200
287 ACTIVE org.eclipse.equinox.console_1.0.100.v20130429-0953
288 ACTIVE org.eclipse.jetty.http_8.1.10.v20130312
289 ACTIVE org.eclipse.emf.importer.java_2.7.0.v20130610-0406
290 ACTIVE org.hamcrest.core_1.3.0.v201303031735
291 ACTIVE org.eclipse.equinox.security_1.2.0.v20130424-1801
Fragments=44
292 ACTIVE org.apache.commons.codec_1.4.0.v201209201156
293 ACTIVE org.eclipse.osee.vaadin.widgets_0.16.2.qualifier
294 ACTIVE ch.qos.logback.core_0.9.27.v20110224-1110
295 ACTIVE org.eclipse.emf.databinding.edit_1.3.0.v20130610-0406
296 ACTIVE org.eclipse.emf.mapping.ecore_2.6.0.v20130610-0406
297 ACTIVE javax.xml.bind_2.2.0.v201105210648
298 ACTIVE org.eclipse.osee.vaadin_0.16.2.qualifier
299 ACTIVE javax.mail.glassfish_1.4.1.v201005082020
300 ACTIVE org.eclipse.core.commands_3.6.100.v20130515-1857
301 ACTIVE org.eclipse.emf.mapping_2.7.0.v20130610-0406
302 ACTIVE org.eclipse.osee.orcs.db_0.16.2.qualifier
Fragments=25
Please help.
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1766865 is a reply to message #1766800] Wed, 28 June 2017 07:23 Go to previous messageGo to next message
you still have 302 plugins in the target... e4, emf, junit, mylyn... If you are developing a workbench based application (3.x) you don't need e4 bundles. Try to reduce the plugins in the RAP target to what is really needed. Use a latest RAP Runtime target from our download page [1] or the old from the direct link [2].
Also avoid conflicting bundles like RAP workbench, RCP workbench, e4 workbench together.
Is your app workbench-based? I don't see 'org.eclipse.rap.ui.workbench_2.0.0.20130107-1035` in the last list.
And one more hint... RAP bundles used in your application are really old (2.0.0.20130107). Try the latest RAP 3.2, released today.
[1] https://www.eclipse.org/rap/downloads/
[2] http://www.eclipse.org/downloads/download.php?file=/rt/rap/2.0/rap-2.0.0-R-20130205-1849.zip
HTH,
Ivan
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1767058 is a reply to message #1766865] Fri, 30 June 2017 03:42 Go to previous messageGo to next message
Hi Ivan,
The issue is resolved.
Removed all the conflicting plugins and also there was a reference to a static filed in the selectionlistener of treeviewer which was causing the problem on multiple sessions.
Thanks a lot for your support,
Sumy
Re: invalid thread access exception thrown on clicking on treeviewer when multiple sessions are on [message #1767185 is a reply to message #1767058] Mon, 03 July 2017 06:29 Go to previous message
That's great!
Previous Topic:add http-equiv meta in additionalHeaders
Next Topic:Invalid Thread Access exception throws when using ChartJs during multiple sessions
Current Time: Thu Jul 24 23:33:54 EDT 2025
Powered by FUDForum. Page generated in 0.06103 seconds
