Home » Modeling » Epsilon » ETL execution engine
ETL execution engine [message #1765197] Wed, 07 June 2017 08:44 Go to next message
I want to know about execution engine of ETL. Is there any reference to help in this regard?
e.g., In the below code when 'Element' class is created? When we execute 'Statemachine2Petrinet' rule and arrive to 'pn.elements ::= sm.elements' statement or when we execute `ModelElem2Element` rule?
rule Statemachine2Petrinet
	transform sm: Statemachine!Statemachine
 	to pn : Petrinet!Petrinet {
 		pn.elements ::= sm.elements;
rule ModelElem2Element
	transform mElem : Statemachine!ModelElem
	to elem : Petrinet!Element {
		guard : mElem.name <> null
		elem.name := mElem.name;
[Updated on: Wed, 07 June 2017 08:45] by Moderator
Re: ETL execution engine [message #1765200 is a reply to message #1765197] Wed, 07 June 2017 09:16 Go to previous messageGo to next message
1. This is the declarative side of ETL. The engine automatically schedules the execution of the rules. You are not supposed to know, or better saying, you do/should not assume any ordering of the execution of the rules. This is decided by the engine.
2. A question to be asked is, I also do not know the answer, is the following a valid ETL statement:
Does it trigger the execution of ModelElem2Element rule for each element in pn's list? Or should you write a for loop to iterate each list element individually?
3. If the ModelElem2Element rule is executed for every element in the list before the Statemachine2Petrinet rule, then the engine uses the result of this execution in the code part
, rather than executing the rule again. Otherwise (if the ModelElem2Element rule is not executed yet), then the ModelElem2Element rule is called when needed.
Re: ETL execution engine [message #1765209 is a reply to message #1765200] Wed, 07 June 2017 10:24 Go to previous messageGo to next message
Hi both,
In the absence of lazy rules, ETL runs in 2 passes. In the first pass it creates all target objects and traceability links back to their equivalent source objects and in the second pass, it populates the contents of the target objects by running the bodies of the respective rules.
Multi-valued features are handled using a built-in loop so you wouldn't need to write one.
Dimitris
Re: ETL execution engine [message #1765252 is a reply to message #1765209] Wed, 07 June 2017 16:56 Go to previous messageGo to next message
Thank you very much indeed. It's really helpful.
The traceability links that you mentioned are the same as the post part of OO2DB transformation [1] ?
In OO2DB transformation why do we need to create the traceability links?
[1]. https://www.eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.examples.oo2db
Re: ETL execution engine [message #1765253 is a reply to message #1765252] Wed, 07 June 2017 16:59 Go to previous messageGo to next message
No - I was referring to the internal traceability links that the ETL engine maintains to be able to compute .equivalent[s](). The trace model in OO2DB is there only to demonstrate that an ETL transformation is not limited to one source and one target model but I can now see how it can be more confusing than helpful :/
Dimitris
Re: ETL execution engine [message #1765259 is a reply to message #1765253] Wed, 07 June 2017 17:06 Go to previous messageGo to next message
Ok. Thank you.
In the aspect of functionality, I mean; do they the same work?
Is there any reference that help to know more about ETL execution engine?
Re: ETL execution engine [message #1765261 is a reply to message #1765259] Wed, 07 June 2017 17:08 Go to previous messageGo to next message
No. As far as the execution engine is concerned, the Trace model has no special semantics.
Not really but please feel free to keep asking questions. Perhaps at the end of this discussion you can even put together a relevant article for the Epsilon website ;)
Dimitris
Re: ETL execution engine [message #1766455 is a reply to message #1765261] Wed, 21 June 2017 11:11 Go to previous messageGo to next message
Thanks for your kind help.
1. How the engine distinguish between two classes with the same name?
e.g., In these two rules 4 different Column classes should be created and have their own features:
rule Class2Table
  transform c : OO!Class
  to t : DB!Table, pk : DB!Column {
   if (c.`extends`.isDefined()){
    var childFkCol : new DB!Column;
    var parentFkCol : DB!Column;
rule SingleValuedAttribute2Column
  transform a : OO!Attribute
  to c : DB!Column {
EClass [name=Column, instanceClassName=null, instanceClass=null, defaultValue=null, instanceTypeName=null, abstract=false, interface=false, ] cannot specifies the difference of these classes.
2. When we have an assignment statement that its lhs is a class, what does it do?
parentFkCol = parentTable.primaryKeys.first();
[Updated on: Thu, 22 June 2017 11:35] by Moderator
Re: ETL execution engine [message #1766532 is a reply to message #1766455] Thu, 22 June 2017 13:20 Go to previous messageGo to next message
I'm not sure I understand what you're asking. Could you please elaborate a bit more?
Dimitris
Re: ETL execution engine [message #1766534 is a reply to message #1766532] Thu, 22 June 2017 14:28 Go to previous messageGo to next message
1. Does the execution engine create 4 columns (EClass) for above code?
2. It is another question that is not related to the first question.
In the below assignment statement what happens?
[Updated on: Fri, 23 June 2017 04:56] by Moderator
Re: ETL execution engine [message #1766593 is a reply to message #1766534] Fri, 23 June 2017 07:20 Go to previous messageGo to next message
It creates 4 instances of Column.
> In the below assignment statement what happens? parentFkCol = parentTable.primaryKeys.first();
The value of the parentFkCol variable becomes the result of evaluating "parentTable.primaryKeys.first()"
Dimitris
Re: ETL execution engine [message #1766594 is a reply to message #1766593] Fri, 23 June 2017 07:38 Go to previous messageGo to next message
Dimitris Kolovos wrote on Fri, 23 June 2017 11:20
That means, we have 4 instances of EClass with the same name in the same package. Since they have not id, how can we distinguish between them?
e.g. I want to add an attribute to EClass that is created with "var parentFkCol : DB!Column;". How can I select this specific class?
Since parentFkCol is a class (not feature of a class), what happens in the model?
The class should rename and all its features must remove or not happens in the model? if not happens, why?
[Updated on: Fri, 23 June 2017 07:50] by Moderator
Re: ETL execution engine [message #1766596 is a reply to message #1766594] Fri, 23 June 2017 07:50 Go to previous messageGo to next message
It does not create 4 EClasses - it creates 4 *instances* of the Column EClass. As such, you cannot add "attributes" to parentFkCol as it's a Column, not an EClass.
Dimitris
Re: ETL execution engine [message #1766597 is a reply to message #1766596] Fri, 23 June 2017 07:51 Go to previous messageGo to next message
Ok, How can we distinguish between these instances?
Re: ETL execution engine [message #1766598 is a reply to message #1766597] Fri, 23 June 2017 07:58 Go to previous messageGo to next message
You can 1) access it while the parentFkCol variable is still available, 2) reach it through a navigation path or 3) assign one of its properties and then use that property to look it up.
Dimitris
Re: ETL execution engine [message #1766602 is a reply to message #1766598] Fri, 23 June 2017 08:05 Go to previous messageGo to next message
Thank you very much.
The instance of the class should rename and all its properties must remove or not happens in the model? if not happens, why?
[Updated on: Fri, 23 June 2017 08:07] by Moderator
Re: ETL execution engine [message #1766604 is a reply to message #1766602] Fri, 23 June 2017 08:19 Go to previous messageGo to next message
Nothing happens to the model. It's just a local variable assignment.
Dimitris
Re: ETL execution engine [message #1767133 is a reply to message #1766604] Sat, 01 July 2017 13:37 Go to previous messageGo to next message
Thanks a lot.
I have some more questions:
1.
Dimitris Kolovos wrote on Wed, 07 June 2017 14:24
when we have lazy rules what changes occur?
2. In the "SpecialAssignmentStatements" or "AssignmentStatements" which have equivalent(s) in their rhs, the engine finds TransformationRule which its source has the special type and selects its target. I want to know:
2.1. If the TransformationRule has more than one target, does the engine select all of its target?
2.2. If we have more than one TrasformationRule that matches the condition, do all of them select?
3. In the "parentTable.primaryKeys.first()" expression, how the execution engine find out to which class "primaryKeys" refers?
My own perception is it finds the eType of primarykeys reference. By the way, I have no idea about the metamodel file it belongs to.
Many thanks for your time,
[Updated on: Sat, 01 July 2017 13:45] by Moderator
Re: ETL execution engine [message #1767192 is a reply to message #1767133] Mon, 03 July 2017 07:52 Go to previous messageGo to next message
In the presence of lazy rules, rules are fully executed (element creation + population) in one go when a .equivalent() is encountered.
2.1 and 2.2 are easy to figure out through experimentation.
Regarding 3, EOL uses reflection on the "parentTable" EObject to retrieve the values of its "primaryKeys" reference.
Dimitris
Re: ETL execution engine [message #1795805 is a reply to message #1767192] Sat, 29 September 2018 04:38 Go to previous messageGo to next message
Hi there,
I have got some rules (rules with no annotations). Assuming they have not any guard or their guards are satisfiable and also we have at least one instance of their source pattern element in the input model, I would like to know the ETL transformation engine runs those rules with which order? Do they run in the same order that they have been appeared in the transformation?
[Updated on: Sat, 29 September 2018 12:15] by Moderator
Re: ETL execution engine [message #1795827 is a reply to message #1795805] Sun, 30 September 2018 07:50 Go to previous messageGo to next message
Hi Banafsheh,
Looking at the source code, it appears that this is correct - by default, transformations are run in the order they are declared in the ETL module.
Sina
Re: ETL execution engine [message #1795848 is a reply to message #1795827] Mon, 01 October 2018 06:23 Go to previous messageGo to next message
Thank you
Re: ETL execution engine [message #1801913 is a reply to message #1795848] Tue, 29 January 2019 08:58 Go to previous messageGo to next message
Hi there,
When does ETL check whether or not an instance of target of the equivalents exists in the input model, in both absence and presence of lazy rules? When it arrives at the equivalent statement or in the matching phase of called rules?
Banafsheh
[Updated on: Tue, 29 January 2019 09:20] by Moderator
Re: ETL execution engine [message #1807582 is a reply to message #1801913] Tue, 04 June 2019 04:59 Go to previous messageGo to next message
Hi there,
I have tested the below code. Surprisingly, It does not have any error.
var s = "1";
switch(s){
	case "1": var a = 6;
	case "3": var i=0;
	i.println();
a.println;
In ETL, switch blocks are not distinct scope? I mean to say the variables defined in the case of the switch do not popped from the symbol table after the execution of switch?
Best Regards,
Banafsheh
[Updated on: Tue, 04 June 2019 05:00] by Moderator
Re: ETL execution engine [message #1820552 is a reply to message #1807582] Wed, 22 January 2020 11:03 Go to previous message
Hi Banafsheh,
Sorry for the late reply, I only just noticed this. Thank you for reporting it. I suspect this is unintentional. I have raised a bug in https://bugs.eclipse.org/bugs/show_bug.cgi?id=559423.
Previous Topic:EuGENia and QVTo, dependency hell.
Next Topic:Linking EVL script with metamodels
Current Time: Thu Jul 24 23:04:32 EDT 2025
Powered by FUDForum. Page generated in 0.29375 seconds
