Home » Eclipse Projects » Eclipse Scout » Neon: jaxws-maven-plugin error in an Mars.2 IDE
Neon: jaxws-maven-plugin error in an Mars.2 IDE [message #1727273] Mon, 21 March 2016 12:26 Go to next message
I am trying to set up the "Scout Demo App" project using Oomph.
I am using the "Eclipse IDE for Scout Committers" as base installation and I am having trouble with the "jaxws-maven-plugin" (for WSDL Files) if I use the Mars version. In the materialized "org.eclipse.scout.docs.snippets" I get an Error marker at line 111 (see also the screenshot):
Invocation of com.sun.tools.ws.wscompile.WsimportTool failed - check output (org.codehaus.mojo:jaxws-maven-
 plugin:2.4:wsimport:wsimport-1:generate-sources) org.apache.maven.plugin.MojoExecutionException: Invocation
 of com.sun.tools.ws.wscompile.WsimportTool failed - check output at
 org.codehaus.mojo.jaxws.AbstractJaxwsMojo.exec(AbstractJaxwsMojo.java:488) at
 org.codehaus.mojo.jaxws.WsImportMojo.processLocalWsdlFiles(WsImportMojo.java:340) at
 org.codehaus.mojo.jaxws.WsImportMojo.executeJaxws(WsImportMojo.java:289) at
 org.codehaus.mojo.jaxws.MainWsImportMojo.executeJaxws(MainWsImportMojo.java:51) at
 org.codehaus.mojo.jaxws.AbstractJaxwsMojo.execute(AbstractJaxwsMojo.java:389) at
 org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134) at
 org.eclipse.m2e.core.internal.embedder.MavenImpl.execute(MavenImpl.java:331) at
 org.eclipse.m2e.core.internal.embedder.MavenImpl$11.call(MavenImpl.java:1362) at
 org.eclipse.m2e.core.internal.embedder.MavenImpl$11.call(MavenImpl.java:1) at
 org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.executeBare(MavenExecutionContext.java:176) at
 org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:112) at
 org.eclipse.m2e.core.internal.embedder.MavenImpl.execute(MavenImpl.java:1360) at
 org.eclipse.m2e.core.project.configurator.MojoExecutionBuildParticipant.build(MojoExecutionBuildParticipant.java:
 52) at org.eclipse.m2e.core.internal.builder.MavenBuilderImpl.build(MavenBuilderImpl.java:137) at
 org.eclipse.m2e.core.internal.builder.MavenBuilder$1.method(MavenBuilder.java:172) at
 org.eclipse.m2e.core.internal.builder.MavenBuilder$1.method(MavenBuilder.java:1) at
 org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod$1$1.call(MavenBuilder.java:115) at
 org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod$1.call(MavenBuilder.java:105) at
 org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:151) at
 org.eclipse.m2e.core.internal.embedder.MavenExecutionContext.execute(MavenExecutionContext.java:99) at
 org.eclipse.m2e.core.internal.builder.MavenBuilder$BuildMethod.execute(MavenBuilder.java:86) at
 org.eclipse.m2e.core.internal.builder.MavenBuilder.build(MavenBuilder.java:200) at
 org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:734) at
 org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at
 org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:205) at
 org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:245) at
 org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:300) at
 org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:303) at
 org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:359) at
 org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:382) at
 org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144) at
 org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:235) at
 org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Where can I get more information? Logs, Stacktrace...
I cannot reproduce it using the Neon version of the IDE as base version.
Re: Neon: jaxws-maven-plugin error in an Mars.2 IDE [message #1728065 is a reply to message #1727273] Wed, 30 March 2016 13:06 Go to previous messageGo to next message
I got the same error in a Scout EPP, Neon.M6 Version
Re: Neon: jaxws-maven-plugin error in an Mars.2 IDE [message #1728197 is a reply to message #1728065] Thu, 31 March 2016 15:46 Go to previous messageGo to next message
I could not precisely verify it, but I think that the Java version is the problem. I think that I solve this problem by using a newer java version.
(In my case it works with the Java Version 1.8.0_66. I do not know what is the minimal required version).
Re: Neon: jaxws-maven-plugin error in an Mars.2 IDE [message #1754629 is a reply to message #1727273] Tue, 21 February 2017 02:45 Go to previous messageGo to next message
I am running Java1.8.0_121. Still i am facing the same issue. There must be some other problem behind it.
Re: Neon: jaxws-maven-plugin error in an Mars.2 IDE [message #1754802 is a reply to message #1754629] Wed, 22 February 2017 10:01 Go to previous messageGo to next message
I recommend using Neon.2 (or Neon.3 in a few weeks) Version of Eclipse IDE.
Re: Neon: jaxws-maven-plugin error in an Mars.2 IDE [message #1756177 is a reply to message #1754629] Mon, 13 March 2017 10:32 Go to previous messageGo to next message
The problem seems to be that the pom for relies on java.home environment variable to be set correctly. There (slightly) more details in the error log view:
The POM for com.sun.xml.ws:jaxws-rt:jar:2.2.10 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
Starting Eclipse with the JRE of the JDK installation helped for me, see also http://stackoverflow.com/a/27464117/546188
Re: Neon: jaxws-maven-plugin error in an Mars.2 IDE [message #1758839 is a reply to message #1756177] Mon, 03 April 2017 11:47 Go to previous messageGo to next message
I've got the same error in Eclipse Neon. By adding "-consoleLog" to the eclipse.ini I could see the error details happend during the wsimport (btw it was a simple error in my wsdl file).
Re: Neon: jaxws-maven-plugin error in an Mars.2 IDE [message #1766566 is a reply to message #1727273] Fri, 23 June 2017 03:00 Go to previous message
it seems your maven goal of wsimport failed and no stub class files generated
1. click Run as | maven build.. | with goal <groupId>:<artifactId>:<goals>
in your case:
org.codehaus.mojo:jaxws-maven-plugin:wsimport
2. eclipse will download required libraries if needed and generate the files to target/generated-sources/wsimport
3. refresh the said folder in the project to trigger building those files if necessary
hth
Previous Topic:How to create a Dashboard in a TablePage
Next Topic:Set SearchForm-Field from the TablePage-Value
Current Time: Wed Nov 05 04:28:47 EST 2025
Powered by FUDForum. Page generated in 0.07495 seconds
