Home » Archived » Jubula » get UnsupportedComponentException on AUT launched from Jubula (jubula extension for nattable)
get UnsupportedComponentException on AUT launched from Jubula [message #1766263] Mon, 19 June 2017 11:26 Go to next message
I coded an toolkit extension for nattable, i have created an jar file for RC fragment and placed in <Installaion Directory>/ite/externaljars Folder.
while excuteing a new test case unable to find the tester class, and i get the following exception:
2017-06-19 16:36:13.191 [Connection.ReaderThread:Socket[addr=APC120048.ivu-ag.com/192.168.51.178,port=56834,localport=56851]] ERROR o.e.j.r.c.AUTServerConfiguration - java.lang.ClassNotFoundException: org.alsweis.nubula.extension.nattable.fragment.NatTableTester cannot be found by org.eclipse.jubula.rc.rcp.common_5.0.0.201705050842
2017-06-19 16:36:13.194 [Connection.ReaderThread:Socket[addr=APC120048.ivu-ag.com/192.168.51.178,port=56834,localport=56851]] ERROR o.e.j.r.c.commands.CapTestCommand - component 'org.eclipse.nebula.widgets.nattable.NatTable' is not supported: implementation class 'org.alsweis.nubula.extension.nattable.fragment.NatTableTester' not found
org.eclipse.jubula.rc.common.exception.UnsupportedComponentException: component 'org.eclipse.nebula.widgets.nattable.NatTable' is not supported: implementation class 'org.alsweis.nubula.extension.nattable.fragment.NatTableTester' not found
at org.eclipse.jubula.rc.common.AUTServerConfiguration.createInstance(AUTServerConfiguration.java:319) ~[org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.rc.common.AUTServerConfiguration.getImplementationClass(AUTServerConfiguration.java:247) ~[org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.rc.common.AUTServerConfiguration.prepareImplementationClass(AUTServerConfiguration.java:397) ~[org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.rc.common.commands.CapTestCommand.getImplClass(CapTestCommand.java:145) [org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.rc.common.commands.CapTestCommand.execute(CapTestCommand.java:337) [org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.communication.internal.Communicator$ConnectionListener.received(Communicator.java:921) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection.fireMessageReceived(Connection.java:402) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection.access$2(Connection.java:391) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection$ReaderThread.run(Connection.java:454) [org.eclipse.jubula.communication.jar:na]
hier find my extension config:
<compSystem xmlns:xsi="*link to shema*">
<configVersion>
<majorVersion>1</majorVersion>
<minorVersion>36</minorVersion>
</configVersion>
<!-- Concrete components -->
<toolkitComponent type="org.eclipse.nebula.widgets.nattable.NatTable" visible="true">
<realizes>guidancer.abstract.Widget</realizes>
<testerClass>org.alsweis.nubula.extension.nattable.fragment.NatTableTester</testerClass>
<componentClass name="org.eclipse.nebula.widgets.nattable.NatTable" />
<action name="CompSystem.VerifyText">
<method>rcVerifyText</method>
<param name="CompSystem.Text">
<type>java.lang.String</type>
</param>
<param name="CompSystem.Operator">
<defaultValue>equals</defaultValue>
<valueSet>
<element name="CompSystem.Equals" value="equals"/>
<element name="CompSystem.NotEquals" value="not equals"/>
<element name="CompSystem.MatchesRegExp" value="matches"/>
<element name="CompSystem.SimpleMatch" value="simple match"/>
</valueSet>
</param>
</action>
</toolkitComponent>
</compSystem>
here find my tester in rc:
package org.alsweis.nubula.extension.fragment;
public class NatTableTester extends WidgetTester {
protected NatTable getNatTable() {
return (NatTable) getRealComponent();
public void rcVerifyText(String text, String operator)
throws StepExecutionException {
final NatTable nattable = getNatTable();
String groupLabelText = getEventThreadQueuer()
.invokeAndWait("getText", new IRunnable<String>() {
public String run() {
return SwtUtils.removeMnemonics(nattable.getDataValueByPosition(1, 1).toString());
Verifier.match(groupLabelText, text, operator);
Please help on this that if i have an issue in path folder? or with class name ?
monssef
[Updated on: Tue, 20 June 2017 03:49] by Moderator
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766306 is a reply to message #1766263] Tue, 20 June 2017 03:44 Go to previous messageGo to next message
while excuteing a new test case unable to find the tester class, and i get the following exception: java.lang.ClassNotFoundException: org.alsweis.nubula.extension.nattable.fragment.NatTableTester cannot be found by org.eclipse.jubula.rc.rcp.common_5.0.0.201705050842
monssef
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766307 is a reply to message #1766263] Tue, 20 June 2017 03:44 Go to previous messageGo to next message
monssef
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766308 is a reply to message #1766263] Tue, 20 June 2017 03:44 Go to previous messageGo to next message
monssef
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766309 is a reply to message #1766263] Tue, 20 June 2017 03:45 Go to previous messageGo to next message
monssef
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766311 is a reply to message #1766263] Tue, 20 June 2017 04:01 Go to previous messageGo to next message
At the first glance the code looks okay, but It seems that the extension is not correctly installed.
Do you use java 8 for the AUT? Because the fragment is written to supprt java8 and newer.
Is the extension "org.alsweis.nubula.extension.nattable.fragment1_1.0.0.201706191559.jar" correctly deployed into the Application to test?
with regards
Marvin Mueller
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766315 is a reply to message #1766311] Tue, 20 June 2017 04:11 Go to previous messageGo to next message
thank you for your reply
ja i use java 8 for AUT.
can you send to me a tutorial about fragment deploying?
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766317 is a reply to message #1766315] Tue, 20 June 2017 04:15 Go to previous messageGo to next message
i have installed the fragment in ite jubula.
https://help.eclipse.org/neon/index.jsp?topic=%2Forg.eclipse.jubula.client.ua.help%2Fcontent%2Fhtml%2FdeveloperManual%2FtoolkitExtension%2FextensionExamples.html
with regards
monssef
[Updated on: Tue, 20 June 2017 04:17] by Moderator
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766331 is a reply to message #1766317] Tue, 20 June 2017 06:32 Go to previous messageGo to next message
Hi Marvin,
Can we make a websession about the problem?
with regards
monssef
Re: get UnsupportedComponentException on AUT launched from Jubula [message #1766344 is a reply to message #1766331] Tue, 20 June 2017 08:16 Go to previous message
Hi Marvin,
I have resolved the problem.
with regards
monssef
Previous Topic:Reflection component : Invoke External method [Execution Error: "java.lang.ClassNotFound]
Next Topic:check for nested Property
Current Time: Wed Sep 17 01:40:52 EDT 2025
Powered by FUDForum. Page generated in 0.05253 seconds
