Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] Ecore and Genmodel editor issues
[EMF Forms] Ecore and Genmodel editor issues [message #1766246] Mon, 19 June 2017 06:02 Go to next message
I'm using the Ecore and Genmodel editors that are provided by the EMF Forms project, and although they are a great improvement, there are some annoying issues:
- When using the Generate Model menu item in the Ecore Editor, I get an error message stating that it couldn't find a GenModel file referencing the current EPackage, although the genmodel file is in the same folder and is properly loaded by both the default and custom Genmodel editors.
- When using the Genmodel Editor instead, I can generate code using the Generate Model menu item, but the genmodel (or rather the ecore model in the same editor) doesn't update properly when I edit the ecore model in the other editor. Hence, I need to close and open the editor.
I'm using Oxygen RC1
Re: [EMF Forms] Ecore and Genmodel editor issues [message #1766287 is a reply to message #1766246] Mon, 19 June 2017 18:10 Go to previous messageGo to next message
I've updated to Oxygen RC2 and now code generation from the Ecore Editor seems to work. I notice it loads and shows the corresponding genmodel AND another instance of the same ecore (I assume since the genmodel references it). This confuses the editor, at least I get strange error markers. In addition, the second Ecore does not sync with the one I'm editing, so I have the same problem as before, the genmodel does not refresh and generate code based on the latest version of the ecore model.
Re: [EMF Forms] Ecore and Genmodel editor issues [message #1766300 is a reply to message #1766287] Tue, 20 June 2017 02:59 Go to previous messageGo to next message
could you kindly report a Bug, ideally with a test model and the precise steps to reproduce?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=ecp
Thanks!
Jonas
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms] Ecore and Genmodel editor issues [message #1766329 is a reply to message #1766300] Tue, 20 June 2017 05:42 Go to previous messageGo to next message
Here https://bugs.eclipse.org/bugs/show_bug.cgi?id=518503
The essence is that saving does not work if a genmodel (and a second instance of the ecore model) is loaded. When saving, the dirty flag is cleared and the file modification time changes, but not the file's contents. As if the second and unchanged ecore model overwrites the first.
Re: [EMF Forms] Ecore and Genmodel editor issues [message #1766404 is a reply to message #1766329] Wed, 21 June 2017 03:30 Go to previous message
Thank you for the report!
Previous Topic:modeling attribute as enum in ecore
Next Topic:EMF to USE
Current Time: Mon Jul 21 00:31:22 EDT 2025
Powered by FUDForum. Page generated in 0.06407 seconds
