Home » Modeling » TMF (Xtext) » Setting GeneratorConfig JavaSourceVersion
Setting GeneratorConfig JavaSourceVersion [message #1766217] Sat, 17 June 2017 23:39 Go to next message
I am using Xbase to write a small DSL. I am trying to use XBlockExpression and with the block trying to initialize a ' val Map<String, String> some = new HashMap<>()';
However, this is generating an error when trying to compile it in to java code.
"ERROR:<> cannot be resolved."
I am suspecting that the DSL is compiled with Java 5.
How can i set the version to Java 8. I am using a standalone setup to compile this DSL.
Thank You
Re: Setting GeneratorConfig JavaSourceVersion [message #1766245 is a reply to message #1766217] Mon, 19 June 2017 05:06 Go to previous messageGo to next message
I worked around this problem by creating a new instance of OnTheFlyJavaCompiler2 and passing in JavaVersion.JAVA8. You can then use that compiler to compile the generated code.
If others have a better way, I would be interested to find out.
@Inject extension ParseHelper<YourModel>
OnTheFlyJavaCompiler2 compiler = new OnTheFlyJavaCompiler2(this.class.classLoader, JavaVersion.JAVA8)
def compileJava8(CharSequence model) {
    // returns Map<String,String>
    val sourceCode = generateCodeAndLoadFromFileSystem(model)
    compiler.compileToClasses(sourceCode)
Re: Setting GeneratorConfig JavaSourceVersion [message #1766248 is a reply to message #1766245] Mon, 19 June 2017 06:09 Go to previous messageGo to next message
Hi Jim
if you don't want to use the OnTheFlyJavaCompiler2 directly in your test (and simply use CompilationTestHelper) you could define a custom injector provider, (see, e.g., https://github.com/LorenzoBettini/jbase/blob/master/jbase.tests/src/jbase/tests/util/Java7JbaseTestlanguageInjectorProvider.java) and use this in your compiler test :
package jbase.tests.util;
import org.eclipse.xtext.util.JavaVersion;
import org.eclipse.xtext.xbase.testing.OnTheFlyJavaCompiler2;
import com.google.inject.Inject;
import com.google.inject.Singleton;
import jbase.testlanguage.JbaseTestlanguageRuntimeModule;
import jbase.testlanguage.tests.JbaseTestlanguageInjectorProvider;
public class Java7JbaseTestlanguageInjectorProvider extends JbaseTestlanguageInjectorProvider {
	@Singleton
	private static class Java7OnTheFlyJavaCompiler2 extends OnTheFlyJavaCompiler2 {
		@Inject
		public Java7OnTheFlyJavaCompiler2(ClassLoader scope) {
			super(scope, JavaVersion.JAVA7);
	protected JbaseTestlanguageRuntimeModule createRuntimeModule() {
		return new JbaseTestlanguageRuntimeModule() {
			public ClassLoader bindClassLoaderToInstance() {
				// in order to access example annotations in maven build
				return JbaseTestlanguageInjectorProvider.class.getClassLoader();
			@SuppressWarnings("unused")
			public Class<? extends OnTheFlyJavaCompiler2> bindOnTheFlyJavaCompiler2() {
				return Java7OnTheFlyJavaCompiler2.class;
Re: Setting GeneratorConfig JavaSourceVersion [message #1766262 is a reply to message #1766248] Mon, 19 June 2017 11:21 Go to previous messageGo to next message
Since I a using JvmModelInferrer and XBase compiler, I can not use OnTheFlyCompiler2. Is there no simply way to pass this information in MWE2 file ?
Re: Setting GeneratorConfig JavaSourceVersion [message #1766367 is a reply to message #1766248] Tue, 20 June 2017 11:25 Go to previous messageGo to next message
@Lorenzo Very helpful indeed, thank you. I will give this a try.
[Updated on: Tue, 20 June 2017 11:27] by Moderator
Re: Setting GeneratorConfig JavaSourceVersion [message #1766526 is a reply to message #1766367] Thu, 22 June 2017 12:11 Go to previous messageGo to next message
I am still hoping that someone would now how to enable using Java8 within the DSL.
Re: Setting GeneratorConfig JavaSourceVersion [message #1766546 is a reply to message #1766526] Thu, 22 June 2017 18:05 Go to previous messageGo to next message
what do you mean by "However, this is generating an error when trying to compile it in to java code."
can you share a few lines e.g. based on the domain model example that let me reproduce that easily
Re: Setting GeneratorConfig JavaSourceVersion [message #1766623 is a reply to message #1766546] Fri, 23 June 2017 10:51 Go to previous messageGo to next message
Had a look at the codebase and it seems like diamond operator
Is not supported in xbase. Leaving out the <> does the same
Can you please file a ticket on github.com/eclipse/xtext-extras
Re: Setting GeneratorConfig JavaSourceVersion [message #1766628 is a reply to message #1766623] Fri, 23 June 2017 11:33 Go to previous message
here is a potential workaround
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
import "http://www.eclipse.org/xtext/common/JavaVMTypes" as types
XConstructorCall returns xbase::XExpression:
	{xbase::XConstructorCall}
	'new' constructor=[types::JvmConstructor|QualifiedName]
	(=>'<>'| =>'<' (typeArguments+=JvmArgumentTypeReference (',' typeArguments+=JvmArgumentTypeReference)*)? '>')?
	(=>explicitConstructorCall?='('
		    arguments+=XShortClosure
		  | arguments+=XExpression (',' arguments+=XExpression)*
	arguments+=XClosure?;
but it may break existing code that makes use of the "operator diamond" operator like this one:
class Dully {
	def xxx() {
		val xxxx = new Dully<>
		1
	def operator_diamond(Dully a, int b) {
		return a
Previous Topic:xtext and xcore with gradle
Next Topic:syntax highlighting for different groups of keywords
Current Time: Wed Jul 23 20:39:30 EDT 2025
Powered by FUDForum. Page generated in 0.12102 seconds
