Home » Eclipse Projects » GEF » Figures not being Opaque
Figures not being Opaque [message #176269] |
Fri, 08 April 2005 15:58  |
Originally posted by: binti.ksu.edu
Hi all,
I have a problem. I have set the figure as Opaque. But still when I drag a
figure over another figure, I can view the figure in the background. All my
figures are drawn using the paintFigure() method. Can someone please tell
me, what could be the possible problem here?
Binti.
Re: Figures not being Opaque [message #176361 is a reply to message #176316] |
Sat, 09 April 2005 12:32   |
Binti,
Are you talking about the connections? Connections are always above the
other figures because the connection layer is above the layer on which the
figures are drawn.
Also, you cannot drag a figure "over" another figure. The order in which the
figures are drawn (which affects how figures overlap each other) depends on
their index in the list of their siblings.
Search for "z order" in this newsgroup - that thread should give you some
pointers.
Hope this helps,
Brian.
"Binti Sepaha" <binti@ksu.edu> wrote in message
news:d376tv$evi$1@news.eclipse.org...
> Hi Pratik,
> Here is a screen shot. Both these figures are opaque.
> Binti.
> "Pratik Shah" <ppshah@us.ibm.com> wrote in message
> news:d36ph0$ujr$1@news.eclipse.org...
>> Screenshot?
>> news:d36o0m$sls$1@news.eclipse.org...
>>> Hi all,
>>> a
>> my
>>> tell
>>> Thanks,
>>> Binti.
Re: Figures not being Opaque [message #176444 is a reply to message #176361] |
Sun, 10 April 2005 20:14   |
I am not talking about connections. The screenshot I sent had no
connections. I willl try to look into 'z order'. Thanks.
Binti.
"Brian Fernandes" <brian.fernandes@genuitec.com> wrote in message
news:d390av$bch$1@news.eclipse.org...
> Binti,
> figures are drawn.
> the figures are drawn (which affects how figures overlap each other)
> depends on their index in the list of their siblings.
> pointers.
> Hope this helps,
> Brian.
>> Hi Pratik,
>> Thanks,
>> Binti.
>>> Screenshot?
>>>> Hi all,
>>>> drag a
>>>> All
>>> my
>>>> tell
>>>> Thanks,
>>>> Binti.
Re: Figures not being Opaque [message #176579 is a reply to message #176444] |
Sun, 10 April 2005 20:35   |
Are you invoking super.paintFigure() from your paintFigure() method?
news:d3cfrl$vc9$1@news.eclipse.org...
> Binti.
> > Binti,
the
> > figures are drawn.
some
> > pointers.
> > Hope this helps,
> > Brian.
> >> Hi Pratik,
> >> Thanks,
> >> Binti.
> >>> Screenshot?
> >>>> Hi all,
> >>>> drag a
> >>>> All
> >>> my
> >>>> tell
> >>>> Thanks,
> >>>> Binti.
Re: Figures not being Opaque [message #176587 is a reply to message #176579] |
Sun, 10 April 2005 22:20   |
Thanks Pratik,
That helps. But the z-order is another problem. I did not find much thread
on it. Could you explain how and where it is set. And how to change it?
Also, now the connections still show and as Brian explained, they will
always shpw as the connection layer is on the top of other layers...is there
a solution to it?
Binti.
news:d3ch2o$t0$1@news.eclipse.org...
>> Binti.
>> > Binti,
> the
>> > figures are drawn.
>> > which
> some
>> > pointers.
>> > Hope this helps,
>> > Brian.
>> >> Hi Pratik,
>> >> Thanks,
>> >> Binti.
>> >>> Screenshot?
>> >>>> Hi all,
>> >>>> drag a
>> >>>> All
>> >>> my
>> >>>> tell
>> >>>> Thanks,
>> >>>> Binti.
Re: Figures not being Opaque [message #176603 is a reply to message #176587] |
Mon, 11 April 2005 01:32   |
news:d3cn7i$6tj$1@news.eclipse.org...
> Thanks Pratik,
The z-order is simply the order in which the figures are listed in the
parent (which is usually the order in which they were added). A figure will
paint over any of its preceding siblings. That is to say, with two
overlapping figures, the one that was added last will be on top. To change
this order, simply change their order in the parent figure's list.
there
> a solution to it?
Solution to what? Connections appearing over figures? So, you want your
connections to go under the figures? Switch the order in which the
connection layer and the primary layer added to the layered pane in the root
editpart. Same concept that I explained above.
> Binti.
> >> Binti.
> >> > Binti,
the
which
> > the
> >> > figures are drawn.
> >> > which
> > some
> >> > pointers.
> >> > Hope this helps,
> >> > Brian.
> >> >> Hi Pratik,
> >> >> Thanks,
> >> >> Binti.
> >> >>> Screenshot?
> >> >>>> Hi all,
I
> >> >>>> drag a
background.
> >> >>>> All
> >> >>> my
please
> >> >>>> tell
> >> >>>> Thanks,
> >> >>>> Binti.
Re: Figures not being Opaque [message #176938 is a reply to message #176603] |
Tue, 12 April 2005 11:52   |
Hey thanks Pratik,
The problem of adding the children in that order is solved. But I am unable
to figure out how have the layers been added. I guess this is being done
automatically. In my code I have not cretaed any layers. How do I handle
this?
Binti.
news:d3d2fv$im7$1@news.eclipse.org...
>> Thanks Pratik,
>> thread
> will
> change
> there
>> a solution to it?
> root
>> Thanks,
>> Binti.
>> >> Binti.
>> >> > Binti,
> the
> which
>> > the
>> >> > figures are drawn.
>> >> > which
>> > some
>> >> > pointers.
>> >> > Hope this helps,
>> >> > Brian.
>> >> >> Hi Pratik,
>> >> >> Thanks,
>> >> >> Binti.
>> >> >>> Screenshot?
>> >> >>>> Hi all,
> I
>> >> >>>> drag a
> background.
>> >> >>>> All
>> >> >>> my
> please
>> >> >>>> tell
>> >> >>>> Thanks,
>> >> >>>> Binti.
Re: Figures not being Opaque [message #176946 is a reply to message #176938] |
Tue, 12 April 2005 13:00   |
It's in your root editpart. In your editor's configureGraphicalViewer()
method, you must be specifying a root editpart. Subclass that root
editpart's createPrimaryLayers() method or something like that.
news:d3gr6p$pcc$1@news.eclipse.org...
> Hey thanks Pratik,
unable
> this?
> Binti.
> >> Thanks Pratik,
> >> thread
> > will
> > change
> > there
> >> a solution to it?
your
> > root
> >> Thanks,
> >> Binti.
> >> >> Binti.
> >> >> > Binti,
above
> > the
> > which
> >> > the
> >> >> > figures are drawn.
> >> >> > which
other)
you
> >> > some
> >> >> > pointers.
> >> >> > Hope this helps,
> >> >> > Brian.
> >> >> >> Hi Pratik,
> >> >> >> Thanks,
> >> >> >> Binti.
> >> >> >>> Screenshot?
> >> >> >>>> Hi all,
when
> > I
> >> >> >>>> drag a
> > background.
> >> >> >>>> All
> >> >> >>> my
> > please
> >> >> >>>> tell
> >> >> >>>> Thanks,
> >> >> >>>> Binti.
Re: Figures not being Opaque [message #177003 is a reply to message #176638] |
Tue, 12 April 2005 14:05  |
I did what Pratik suggested and now things look good, but the only problem
is my connections are no longer selectable. How do I change this? Also, my
connections have labels attahced to them which do not show initially, but
once i close and reopen the diagram, they appear.
Please guide me though this too :)
Binti.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:d3e4h3$45o$1@news.eclipse.org...
> setting opaque is not magic, it's just a boolean. You still need to call
> super.paint(), or your bounds will not be filled in with the background
> color.
Current Time: Sat Jul 26 08:38:59 EDT 2025
Powered by FUDForum. Page generated in 0.28663 seconds
