Not able to read data over bluethooth [message #1765877] |
Wed, 14 June 2017 03:10  |
I am running a sample service on Kura which will just print the data by an arduino board over bluetooth through an HC05.
My code seems to work fine if I run it as a standalone java project. But it fails if I execute it through Kura.
The issue I face is, it is just stuck on read. [I'm using Bluecove 2.1.1] library.
Here is my code,
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.io.OutputStream;
import java.sql.SQLException;
import java.util.Map;
import javax.bluetooth.BluetoothStateException;
import javax.bluetooth.DeviceClass;
import javax.bluetooth.DiscoveryAgent;
import javax.bluetooth.DiscoveryListener;
import javax.bluetooth.LocalDevice;
import javax.bluetooth.RemoteDevice;
import javax.bluetooth.ServiceRecord;
import javax.bluetooth.UUID;
import javax.microedition.io.Connector;
import javax.microedition.io.StreamConnection;
import org.eclipse.kura.configuration.ConfigurableComponent;
import org.osgi.framework.BundleContext;
import org.osgi.service.component.ComponentContext;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class GatewayConfigurator implements ConfigurableComponent {
private static final Logger logger = LoggerFactory.getLogger(GatewayConfigurator.class);
private static final String APP_ID = "com.x.gateway.GatewayConfigurator";
private BundleContext context;
public Object lock = new Object();
RemoteDevice hc05device;
String hc05Url;
boolean inq;
protected void activate(ComponentContext componentContext) {
logger.info("Bundle " + APP_ID + " has started! <==================");
activate(componentContext, null);
protected void activate(ComponentContext componentContext, Map<String, Object> properties) {
try {
inq = LocalDevice.getLocalDevice().getDiscoveryAgent().startInquiry(DiscoveryAgent.GIAC, new DiscoveryListener() {
public void deviceDiscovered(RemoteDevice btDevice, DeviceClass cod) {
logger.debug("deviceDiscovered1.. started");
try {
String name = btDevice.getFriendlyName(false);
System.out.format("%s (%s)\n", name, btDevice.getBluetoothAddress());
if (name.matches("HC.*")) {
hc05device = btDevice;
logger.info("got it!");
} catch (IOException e) {
e.printStackTrace();
public void inquiryCompleted(int discType) {
logger.info("inquiryCompleted1.. started");
try {
synchronized (lock) {
lock.notify();
} catch (Exception e) {
logger.info("Notify1 complete....");
public void serviceSearchCompleted(int transID, int respCode) {
logger.info("serviceSearchCompleted1.. started");
public void servicesDiscovered(int transID, ServiceRecord[] servRecord) {
logger.info("servicesDiscovered1.. started");
} catch (BluetoothStateException e) {
// TODO: handle exception
logger.info("exception::" + e.getCause());
logger.info("Inquiry started: " + inq);
try {
lock.wait();
} catch (InterruptedException e) {
logger.info("Scan complete....");
UUID uuid = new UUID(0x1101); //scan for btspp://... services (as HC-05 offers it)
UUID[] searchUuidSet = new UUID[]{uuid};
int[] attrIDs = new int[]{
0x0100 // service name
try {
LocalDevice.getLocalDevice().getDiscoveryAgent().searchServices(attrIDs, searchUuidSet,
hc05device, new DiscoveryListener() {
logger.info("deviceDiscovered2.. started");
logger.info("inquiryCompleted2.. started");
logger.info("serviceSearchCompleted2.. started");
try {
lock.notify();
logger.info("servicesDiscovered2.. started");
for (int i = 0; i < servRecord.length; i++) {
hc05Url = servRecord[i].getConnectionURL(ServiceRecord.NOAUTHENTICATE_NOENCRYPT, false);
if (hc05Url != null) {
break; //take the first one
try {
lock.wait();
System.out.println(hc05device.getBluetoothAddress());
System.out.println(hc05Url);
if(hc05Url == null) {
hc05Url= "btspp://98D3321046B8:1;authenticate=false;encrypt=false;master=false";
try {
//if you know your hc05Url this is all you need:
StreamConnection streamConnection = (StreamConnection) Connector.open(hc05Url);
OutputStream os = streamConnection.openOutputStream();
InputStream is = streamConnection.openInputStream();
// os.write("Hello Arduino".getBytes()); //just send '1' to the device
BufferedReader br = new BufferedReader(new InputStreamReader(is));
int i = 0;
String line;
// while (i++ <= 10000000) {
logger.info("Starting read write process");
//os.write("Hello Arduino".getBytes());
//os.flush();
line = new String(br.readLine());
/*while(true) {
logger.info("data:" + is.read());
//System.out.println(line);
//os.close();
//is.close();
// streamConnection.close();
protected void deactivate(ComponentContext componentContext) {
public void updated(Map<String, Object> properties) {
logger.info("Bundle " + APP_ID + " has been updated!");
//handleInstruction(properties);
This is my first post, kindly excuse if I have violated any rules.
Vik
FUDForum. Page generated in 0.10587 seconds
