Home » Modeling » TMF (Xtext) » Installation of Xtext Complete SDK 2.11 or 2.12 into Eclipse Kepler SR2(Installation of Xtext Complete SDK 2.11 or 2.12 into Eclipse Kepler SR2 is not possible)
Installation of Xtext Complete SDK 2.11 or 2.12 into Eclipse Kepler SR2 [message #1765695] Tue, 13 June 2017 09:28 Go to next message
I'm trying to install the Xtext Complete SDK into Eclipse Kepler SR2 but I get the following error.
Does anybody know the reason for this problem?
It is only possible to install Xtext Version 2.10.0.v201605250459.
Adrian
Steps I performed in Eclipse:
Help -> Install New Software...
Work with: http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/
Select: Xtext Complete SDK 2.12.0.v20170519-1412
Message apperas while installation: Cannot perform operations. Computing alternate solutions,...
"Install Remediation Page" appers
Select: "Show original error and build my own solution"
Details:
Cannot complete the install because one or more required items could not be found.
Software being installed: Xtext Complete SDK 2.12.0.v20170519-1412 (org.eclipse.xtext.sdk.feature.group 2.12.0.v20170519-1412)
Missing requirement: Xtext Testing Infrastructure 2.12.0.v20170518-0959 (org.eclipse.xtext.testing 2.12.0.v20170518-0959) requires 'bundle org.junit 4.12.0' but it could not be found
Cannot satisfy dependency:
From: Xtend IDE 2.12.0.v20170519-1412 (org.eclipse.xtend.sdk.feature.group 2.12.0.v20170519-1412)
To: org.eclipse.xtext.testing [2.12.0.v20170518-0959]
From: Xtext Complete SDK 2.12.0.v20170519-1412 (org.eclipse.xtext.sdk.feature.group 2.12.0.v20170519-1412)
To: org.eclipse.xtend.sdk.feature.group [2.12.0.v20170519-1412]
There are similar problems with the Version 2.11.0.v20170201-0242
Details:
Software being installed: Xtext Complete SDK 2.11.0.v20170201-0242 (org.eclipse.xtext.sdk.feature.group 2.11.0.v20170201-0242)
Missing requirement: Xtext Testing Infrastructure 2.11.0.v20170130-0808 (org.eclipse.xtext.testing 2.11.0.v20170130-0808) requires 'bundle org.junit 4.12.0' but it could not be found
From: Xtext Complete SDK 2.11.0.v20170201-0242 (org.eclipse.xtext.sdk.feature.group 2.11.0.v20170201-0242)
To: org.eclipse.xtext.testing [2.11.0.v20170130-0808]
[Updated on: Tue, 13 June 2017 09:37] by Moderator
Re: Installation of Xtext Complete SDK 2.11 or 2.12 into Eclipse Kepler SR2 [message #1765699 is a reply to message #1765695] Tue, 13 June 2017 09:55 Go to previous messageGo to next message
xtext target platform requires luna. ntl
might be the issue
kepler has 4.11 only
=> maybe you need to install 4.12 separately from orion
Re: Installation of Xtext Complete SDK 2.11 or 2.12 into Eclipse Kepler SR2 [message #1765703 is a reply to message #1765699] Tue, 13 June 2017 10:24 Go to previous messageGo to next message
I tried it with Eclipse Mars. There were no problems.
Finally, I will use Neon.
Thank you for your help!
Re: Installation of Xtext Complete SDK 2.11 or 2.12 into Eclipse Kepler SR2 [message #1765708 is a reply to message #1765703] Tue, 13 June 2017 11:48 Go to previous messageGo to next message
You know oxygen is about to release ...
Re: Installation of Xtext Complete SDK 2.11 or 2.12 into Eclipse Kepler SR2 [message #1765869 is a reply to message #1765708] Wed, 14 June 2017 02:14 Go to previous messageGo to next message
Yes, it will be available on the 28th.
By the way, I get the following error by installing Xtext 2.12. in Neon.
After Eclipse restart and a reinstall it worked then.
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact not found: http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.12.0/plugins/org.eclipse.xtend.core.source_2.12.0.v20170519-0902.jar.
Artifact not found: http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.12.0/plugins/org.eclipse.xtext.doc_2.12.0.v20170519-0809.jar.pack.gz.
Artifact not found: http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.12.0/plugins/org.eclipse.xtext.xbase_2.12.0.v20170519-0752.jar.pack.gz.
Re: Installation of Xtext Complete SDK 2.11 or 2.12 into Eclipse Kepler SR2 [message #1765871 is a reply to message #1765869] Wed, 14 June 2017 02:42 Go to previous message
hi it might happen that the damn eclipse server hickup from time to time. you may comment on https://bugs.eclipse.org/bugs/show_bug.cgi?id=515596
Previous Topic:Preferences -> Templates shows contexts for Xtext, not my DSL
Next Topic:Return to the line
Current Time: Sun Jul 27 16:30:58 EDT 2025
Powered by FUDForum. Page generated in 0.04986 seconds
