Home » Modeling » TMF (Xtext) » Adding a genmodl to the workflow(How to add a genmodl to the mwe2 workflow)
Adding a genmodl to the workflow [message #1765631] Mon, 12 June 2017 17:46 Go to next message
I have the following workflow:
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "de.mdsd.xtext.support.name.provider.model"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "de.mdsd.xtext.support.name.provider.model.NameProviderModel"
			fileExtensions = "npm"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
Where and how to add a genmodel for an imported grammar?
Re: Adding a genmodl to the workflow [message #1765632 is a reply to message #1765631] Mon, 12 June 2017 18:00 Go to previous messageGo to next message
It is part of the language configuration XtextGeneratorLanguage#addReferencedResource.
language = {
   referencedResource = "platform:/resource/......genmodel"
Re: Adding a genmodl to the workflow [message #1765639 is a reply to message #1765632] Mon, 12 June 2017 20:30 Go to previous message
Thank you for the quick answer. That does the trick.
Previous Topic:Grammar mixin
Next Topic:Using an Xbase subset
Current Time: Sun Aug 31 23:14:07 EDT 2025
Powered by FUDForum. Page generated in 0.03393 seconds
