Home » Language IDEs » C / C++ IDE (CDT) » JDT kit for C/C++ IDE -Erorrs(not expected errors with JDK tool kit)
JDT kit for C/C++ IDE -Erorrs [message #1765535] Mon, 12 June 2017 05:00 Go to next message
Hi Anyone tried to install JDK tool kit for C/C++ IDE?
I am receiving bunch of errors?
I am new to forum and IDE , anyone help is appreciated!
  • Attachment: elog.txt
    (Size: 2.34KB, Downloaded 150 times)
Re: JDT kit for C/C++ IDE -Erorrs [message #1765581 is a reply to message #1765535] Mon, 12 June 2017 11:00 Go to previous messageGo to next message
To me it looks like you tried an install with "Contact all update sites during install to find required software" unchecked. index.php/fa/29615/0/
Alternatively, you don't have "http://download.eclipse.org/releases/neon" (where neon is the version of Eclipse you have) in the Work With software list. But this should only happen if you have obtained your Eclipse install from somewhere other than eclipse.org/downloads
If neither of the above describes your situation, please expand on how you arrived at the error. What exactly (URL/name) are you installing into which version of Eclipse?
  • Attachment: contact.png
    (Size: 25.56KB, Downloaded 384 times)
Re: JDT kit for C/C++ IDE -Erorrs [message #1766390 is a reply to message #1765581] Tue, 20 June 2017 20:12 Go to previous messageGo to next message
Please find the snapshots and software I am trying to install.
I still having no repository available issue.
  • Attachment: error.PNG
    (Size: 277.00KB, Downloaded 141 times)
  • Attachment: version.PNG
    (Size: 330.13KB, Downloaded 142 times)
  • Attachment: website.PNG
    (Size: 165.15KB, Downloaded 144 times)
Re: JDT kit for C/C++ IDE -Erorrs [message #1766413 is a reply to message #1766390] Wed, 21 June 2017 04:52 Go to previous messageGo to next message
Hi Jagan,
Please follow previous post and check "Contact all update sites ...". In your screenshot website.PNG, it is unchecked.
Re: JDT kit for C/C++ IDE -Erorrs [message #1766480 is a reply to message #1766413] Wed, 21 June 2017 20:11 Go to previous messageGo to next message
I checked "Contact all sites....", now more errors.
I am using corporate machine ,will it be an issue?
  • Attachment: error new.PNG
    (Size: 99.71KB, Downloaded 148 times)
  • Attachment: website1.PNG
    (Size: 84.48KB, Downloaded 153 times)
Re: JDT kit for C/C++ IDE -Erorrs [message #1766494 is a reply to message #1766480] Thu, 22 June 2017 04:20 Go to previous message
Hi Jagan,
That is bizarre. If you are on a corporate network you may need to set-up proxies/etc.
However as I don't know what is going wrong, I can give you a workaround:
1) Download Eclipse IDE for Java Developers (https://www.eclipse.org/downloads/eclipse-packages/) - in addition to the Eclipse IDE for C/C++ Developers you already have
2) Unzip/untar both packages into different directories
3) Start the C/C++ version
4) From the File menu -> Import, Choose Install -> From Existing Installation, press Next
index.php/fa/29755/0/
5) Select the Java installation location to import from, press Select All and then finish the wizard.
index.php/fa/29757/0/
6) You should now have Eclipse with Java and C/C++ Dev environments.
  • Attachment: step1.png
    (Size: 36.08KB, Downloaded 701 times)
  • Attachment: step2.png
    (Size: 126.53KB, Downloaded 283 times)
Previous Topic:Include paths not reflected in makefile
Next Topic:Remote debugging not starting properly
Current Time: Tue May 13 19:22:10 EDT 2025
Powered by FUDForum. Page generated in 0.03924 seconds
