Home » Modeling » GMF (Graphical Modeling Framework) » How do we use o.e.gmf.r.common.ui.services.editorProviders ?
How do we use o.e.gmf.r.common.ui.services.editorProviders ? [message #111617] Tue, 13 March 2007 14:45 Go to next message
Originally posted by: NOSPAM.xyz.com
Has anybody ever used it?
Why doesn't the generated editor use it?
I couldn't find any trace of info about it apart the
ext.point description, but it seems inconsistent to me.
So I put together the following snippets myself:
<extension
point="org.eclipse.gmf.runtime.common.ui.services.editorProviders ">
<EditorProvider
class="exp.diagram.custom.providers.MyLEditorProvider">
<Priority name="Highest"/>
<Policy class="exp.diagram.custom.providers.MyEditorProvider"/>
</EditorProvider>
</extension>
import org.eclipse.gmf.runtime.common.core.service.IProviderPolicy;
import
org.eclipse.gmf.runtime.common.ui.services.editor.AbstractEd itorProvider;
public class MyEditorProvider extends AbstractEditorProvider implements
IProviderPolicy {
.... and so on...
Unfortunately none of the methods of AbstractEditorProvider and / or
IProviderPolicy
ever gets called !?
Any comment from somebody more experienced than me?
Re: How do we use o.e.gmf.r.common.ui.services.editorProviders ? [message #112696 is a reply to message #111617] Sun, 18 March 2007 18:10 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
I've used it to open diagram nodes in a separate window:
<extension
<EditorProvider class=" ca.uwaterloo.watform.bluenose2.diagram.part.Bluenose2Diagram EditorProvider ">
<Priority name="Lowest"/>
</EditorProvider>
</extension>
package ca.uwaterloo.watform.bluenose2.diagram.part;
import org.eclipse.gmf.runtime.common.ui.services.editor.AbstractEd itorProvider;
public class Bluenose2DiagramEditorProvider extends AbstractEditorProvider {
protected boolean canOpen(IEditorInput editorInput) {
if (editorInput instanceof IDiagramEditorInput) {
IDiagramEditorInput diagramInput = (IDiagramEditorInput) editorInput;
Diagram diagram = diagramInput.getDiagram();
if (diagram != null/* && diagram.getType().equals("Bluenose2")*/) {
return true;
return false;
protected String getEditorId(IEditorInput editorInput) {
return " ca.uwaterloo.watform.bluenose2.diagram.part.Bluenose2Diagram EditorID ";
vlad
> <extension
> <EditorProvider
> </EditorProvider>
> </extension>
> import
> IProviderPolicy {
> ... and so on...
> IProviderPolicy
> ever gets called !?
Re: How do we use o.e.gmf.r.common.ui.services.editorProviders ? [message #113873 is a reply to message #112696] Thu, 22 March 2007 19:44 Go to previous messageGo to next message
Thanks Vlad,
the only difference between yours and mine snippets is that
I was too punctual and payed attention to the Policy about
which the ext .pnt. description says:
<!ELEMENT Policy EMPTY>
<!ATTLIST Policy
class CDATA #REQUIRED>
I'll try it your way
"Vlad Ciubotariu" <vcciubot@uwaterloo.ca> wrote in message
news:pan.2007.03.18.22.10.05.604288@uwaterloo.ca...
> <extension
> <EditorProvider
> </EditorProvider>
> </extension>
> import
> @Override
> return true;
> return false;
> @Override
> return
> vlad
>> <extension
>> <EditorProvider
>> </EditorProvider>
>> </extension>
>> import
>> IProviderPolicy {
>> ... and so on...
>> IProviderPolicy
>> ever gets called !?
Re: How do we use o.e.gmf.r.common.ui.services.editorProviders ? [message #176523 is a reply to message #113873] Mon, 10 March 2008 04:52 Go to previous message
I'm having the same problem: I registered an EditorProvider (exactly as
Vlad did), but the provider would never be called. I've overwritten the
provider's constructor and set a breakpoint, but it's not even instantiated.
What am I doing wrong? Do I have to provide a policy (Vlad didn't)? Are
there any examples on how to use this extension point?
Chris
Marian schrieb:
> Thanks Vlad,
> <!ATTLIST Policy
>> <extension
>> <EditorProvider
>> </EditorProvider>
>> </extension>
>> import
>> @Override
>> return true;
>> return false;
>> @Override
>> return
>> vlad
>>> <extension
>>> <EditorProvider
>>> </EditorProvider>
>>> </extension>
>>> import
>>> IProviderPolicy {
>>> ... and so on...
>>> IProviderPolicy
>>> ever gets called !?
Previous Topic:how to store ListenerFilters persistent
Next Topic:Showing non-containment features readonly
Current Time: Tue Jul 22 08:30:51 EDT 2025
Powered by FUDForum. Page generated in 1.14175 seconds
