Home » Eclipse Projects » Papyrus for Real Time » setting * as the message of the trigger does not work properly (v0.9)(setting * as the message of the trigger does not work properly (v0.9))
setting * as the message of the trigger does not work properly (v0.9) [message #1763922] Mon, 22 May 2017 23:34 Go to next message
In the previous version of PapyrusRT, I could set * as the message of a trigger, and it worked correctly (i.e., The transition is taken on every message of the related protocol ).
I version 0.9, when I set * for the message, it consumes the incoming message, but the transition is not taken.
The bug easily can be reproduced using a timer and setting the trigger of a specific transition to * which show in the following figure.
index.php/fa/29428/0/
Mojtaba
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1763940 is a reply to message #1763922] Tue, 23 May 2017 04:55 Go to previous messageGo to next message
I can confirm that this does no longer work as expected. I wrote bug 517116 to track this issue.
/Peter Cigéhn
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1763966 is a reply to message #1763940] Tue, 23 May 2017 08:54 Go to previous messageGo to next message
Thanks a lot.
Mojtaba
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1763977 is a reply to message #1763966] Tue, 23 May 2017 10:27 Go to previous messageGo to next message
Does this happen with any port or just Timing ports?
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1763992 is a reply to message #1763977] Tue, 23 May 2017 13:48 Go to previous messageGo to next message
It happens with any port.
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1763994 is a reply to message #1763992] Tue, 23 May 2017 13:55 Go to previous messageGo to next message
I've merged a fix. It should be available in the nightly update site in around half an hour.
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1765148 is a reply to message #1763994] Wed, 07 June 2017 01:31 Go to previous messageGo to next message
Is this fix available in the test version? I updated my test version but the issue is not resolved, here is my version:
index.php/fa/29575/0/
How can I get this fix on test or user version?
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1765205 is a reply to message #1765148] Wed, 07 June 2017 10:04 Go to previous messageGo to next message
It looks you do not have the latest nightly in your environment. The bundles show version 0.9.0.20170502nnnn. The 20170502 is the date of that build: 2017-May-02, and as my response, where I indicated that the fix was merged is from May 23, then that change is not in your environment.
To confirm, I have just installed a fresh tester environment, ran a test and it generates code correctly for the * event.
If you created the tester environment with "nightly" as the build type, you can run "Help->Perform Setup Tasks...->[Finish]" to ensure that you get the latest updates from the nightly update site (and dependencies).
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1765211 is a reply to message #1765205] Wed, 07 June 2017 10:50 Go to previous messageGo to next message
I have updated my tester version again, but it does not get the new version. My Eclipse is Neon3, Is this update available for Eclipse Neon as well?
I can not update my Eclipse to Oxygen because I have some plugins that are not compatible with that.
As you can see, My Eclipsed updated recently, but I do not see the last version.
index.php/fa/29584/0/
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1765217 is a reply to message #1765211] Wed, 07 June 2017 11:19 Go to previous messageGo to next message
How exactly are you updating? With Help->Perform Setup Tasks? Manually with Help->Check for updates? With the Eclipse Installer? Some other way?
As for Neon v. Oxygen, sorry but we will no longer support Neon. We have moved to Oxygen which is the target for 1.0, and this particular fix was merged after we moved to Oxygen.
What are the plugins/features which are not compatible with Oxygen? If these are from products in the release train, you could probably find milestone update sites for their Oxygen release.
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1765221 is a reply to message #1765217] Wed, 07 June 2017 11:53 Go to previous messageGo to next message
I used "Perform Setup Tasks", but my version is Neon and I think this is the main issue, I will try the Oxygen to see if it fix the issue.
We are using the Epsilon to perform some transformation and based on previous experiments we had some issues with Oxygen even with their Epsilon last version.
Anyway, It seems that we do not have any choice and we have to use Oxygen for Epsilon as well.
Thanks for the help and support.
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1765227 is a reply to message #1765221] Wed, 07 June 2017 12:26 Go to previous messageGo to next message
I'm not sure if Epsilon is in the Eclipse simrel, but they do build on Eclipse servers and have an "interim" update site (http://download.eclipse.org/epsilon/interim/) where they seem to publish bug fixes. Perhaps this includes migration to Oxygen. You could ask in their forum/mailing list if they are releasing Epsilon for Oxygen and if they can get it from that interim update site or somewhere else.
Re: setting * as the message of the trigger does not work properly (v0.9) [message #1765236 is a reply to message #1765227] Wed, 07 June 2017 13:53 Go to previous message
Thanks a lot, We have tested and the Eclipse Oxygen works fine with (new fix and Epsilon).
Previous Topic:Define a trigger which its signal is set to all incoming messages
Next Topic:Not able to create Plug-in Project in Papyrus-RT Tester version
Current Time: Sun Jul 20 22:45:10 EDT 2025
Powered by FUDForum. Page generated in 0.05801 seconds
