Home » Eclipse Projects » EGit / JGit » Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag on
Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag on [message #1764993] |
Mon, 05 June 2017 11:28  |
To setup EGit development environment, I followed "Automated Developer Setup" instructions on http://wiki.eclipse.org/EGit/Contributor_Guide#Automated_Developer_Setup.
- OS: Ubuntu Linux 16.04 x86_64
- JVM: openjdk version "1.8.0_131", OpenJDK Runtime Environment (build 1.8.0_131-8u131-b11-0ubuntu1.16.04.2-b11)
- Selected "Latest (Oxygen)" for Product Version on Eclipse Installer.
When I finished the instructions, the Problems view on Eclipse showed errors below.
[Project]-[Clean...]-[Clean all projects] did not resolve these errors.
How can I resolve them?
([Window]-[Preferences]-[Java]-[Compiler]-[Javadoc] options are all set to "ignore".)
Description Resource Path Location Type
Invalid @since 4.8 tag on addLinkFile(RepoProject.LinkFile); expecting @since 4.9 RepoProject.java /org.eclipse.jgit/src/org/eclipse/jgit/gitrepo line 398 @since tag problem
Invalid @since 4.8 tag on addLinkFiles(Collection<RepoProject.LinkFile>); expecting @since 4.9 RepoProject.java /org.eclipse.jgit/src/org/eclipse/jgit/gitrepo line 408 @since tag problem
Invalid @since 4.8 tag on BundleWriter(ObjectReader); expecting @since 4.9 BundleWriter.java /org.eclipse.jgit/src/org/eclipse/jgit/transport line 123 @since tag problem
Invalid @since 4.8 tag on Callback; expecting @since 4.9 CloneCommand.java /org.eclipse.jgit/src/org/eclipse/jgit/api line 123 @since tag problem
Invalid @since 4.8 tag on clearLinkFiles(); expecting @since 4.9 RepoProject.java /org.eclipse.jgit/src/org/eclipse/jgit/gitrepo line 417 @since tag problem
Invalid @since 4.8 tag on getLinkFiles(); expecting @since 4.9 RepoProject.java /org.eclipse.jgit/src/org/eclipse/jgit/gitrepo line 302 @since tag problem
Invalid @since 4.8 tag on LinkFile; expecting @since 4.9 RepoProject.java /org.eclipse.jgit/src/org/eclipse/jgit/gitrepo line 155 @since tag problem
Invalid @since 4.8 tag on Merger(ObjectInserter); expecting @since 4.9 Merger.java /org.eclipse.jgit/src/org/eclipse/jgit/merge line 133 @since tag problem
Invalid @since 4.8 tag on newMerger(ObjectInserter, Config); expecting @since 4.9 MergeStrategy.java /org.eclipse.jgit/src/org/eclipse/jgit/merge line 190 @since tag problem
Invalid @since 4.8 tag on newMerger(ObjectInserter, Config); expecting @since 4.9 StrategyResolve.java /org.eclipse.jgit/src/org/eclipse/jgit/merge line 69 @since tag problem
Invalid @since 4.8 tag on newMerger(ObjectInserter, Config); expecting @since 4.9 StrategySimpleTwoWayInCore.java /org.eclipse.jgit/src/org/eclipse/jgit/merge line 97 @since tag problem
Invalid @since 4.8 tag on nonNullRepo(); expecting @since 4.9 Merger.java /org.eclipse.jgit/src/org/eclipse/jgit/merge line 154 @since tag problem
Invalid @since 4.8 tag on parseCommit(AnyObjectId); expecting @since 4.9 Repository.java /org.eclipse.jgit/src/org/eclipse/jgit/lib line 1168 @since tag problem
Invalid @since 4.8 tag on RecursiveMerger(ObjectInserter, Config); expecting @since 4.9 RecursiveMerger.java /org.eclipse.jgit/src/org/eclipse/jgit/merge line 122 @since tag problem
Invalid @since 4.8 tag on ReferenceFile; expecting @since 4.9 RepoProject.java /org.eclipse.jgit/src/org/eclipse/jgit/gitrepo line 83 @since tag problem
Invalid @since 4.8 tag on relativizeGitPath(String, String); expecting @since 4.9 FileUtils.java /org.eclipse.jgit/src/org/eclipse/jgit/util line 527 @since tag problem
Invalid @since 4.8 tag on relativizeNativePath(String, String); expecting @since 4.9 FileUtils.java /org.eclipse.jgit/src/org/eclipse/jgit/util line 510 @since tag problem
Invalid @since 4.8 tag on relativizePath(String, String, String, boolean); expecting @since 4.9 FileUtils.java /org.eclipse.jgit/src/org/eclipse/jgit/util line 564 @since tag problem
Invalid @since 4.8 tag on ResolveMerger(ObjectInserter, Config); expecting @since 4.9 ResolveMerger.java /org.eclipse.jgit/src/org/eclipse/jgit/merge line 314 @since tag problem
Invalid @since 4.8 tag on setCallback(CloneCommand.Callback); expecting @since 4.9 CloneCommand.java /org.eclipse.jgit/src/org/eclipse/jgit/api line 616 @since tag problem
Invalid @since 4.8 tag on setCallback(CloneCommand.Callback); expecting @since 4.9 SubmoduleUpdateCommand.java /org.eclipse.jgit/src/org/eclipse/jgit/api line 245 @since tag problem
Invalid @since 4.8 tag on setTargetURI(String); expecting @since 4.9 RepoCommand.java /org.eclipse.jgit/src/org/eclipse/jgit/gitrepo line 295 @since tag problem
Invalid @since 4.8 tag on shift(int); expecting @since 4.9 Edit.java /org.eclipse.jgit/src/org/eclipse/jgit/diff line 180 @since tag problem
Invalid @since 4.8 tag on ThreeWayMerger(ObjectInserter); expecting @since 4.9 ThreeWayMerger.java /org.eclipse.jgit/src/org/eclipse/jgit/merge line 95 @since tag problem
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765451 is a reply to message #1765353] |
Fri, 09 June 2017 11:43   |
The error "Invalid @since 4.8 tag on ~" had been resolved, but I got another error when right click on the "org.eclipse.egit.ui" project and select Debug As > Eclipse Application.
!SESSION 2017-06-10 00:26:37.282 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_131
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=ja_JP
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data /home/satob/egit-master/ws/../runtime-egit-github -dev file:/home/satob/egit-master/ws/.metadata/.plugins/org.eclipse.pde.core/egit-github/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.compare 4 0 2017-06-10 00:26:41.026
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.compare [16]
Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench.texteditor; bundle-version="[3.5.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.workbench.texteditor; bundle-version="3.10.1.v20160818-1626"; singleton:="true"
org.eclipse.ui.workbench.texteditor [171]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.5.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui; bundle-version="3.108.1.v20160929-1045"; singleton:="true"
org.eclipse.ui [154]
Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.105.0,4.0.0)"; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.ui.workbench; bundle-version="3.108.3.v20170216-1539"; singleton:="true"
org.eclipse.ui.workbench [170]
Unresolved requirement: Import-Package: javax.inject; version="1.0.0"
Unresolved requirement: Require-Bundle: org.eclipse.ui.forms; bundle-version="[3.2.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.forms; bundle-version="3.7.1.v20161220-1635"; singleton:="true"
org.eclipse.ui.forms [160]
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.css.core; bundle-version="0.10.100"
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.105.0,4.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.ui.editors; bundle-version="[3.5.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.editors; bundle-version="3.10.1.v20161106-1856"; singleton:="true"
org.eclipse.ui.editors [158]
Unresolved requirement: Require-Bundle: org.eclipse.ui.ide; bundle-version="[3.5.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.ide; bundle-version="3.12.3.v20170119-0935"; singleton:="true"
org.eclipse.ui.ide [161]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.106.0,4.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.7.0,4.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.ui.views; bundle-version="[3.2.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.views; bundle-version="3.8.102.v20170111-0801"; singleton:="true"
org.eclipse.ui.views [168]
Unresolved requirement: Require-Bundle: org.eclipse.ui.ide; bundle-version="[3.3.0,4.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.debug.ui 4 0 2017-06-10 00:26:41.055
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.debug.ui [34]
Unresolved requirement: Require-Bundle: org.eclipse.ui.console; bundle-version="[3.5.300,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.console; bundle-version="3.6.201.v20161107-0337"; singleton:="true"
org.eclipse.ui.console [157]
Unresolved requirement: Import-Package: org.eclipse.ui.forms.widgets
-> Export-Package: org.eclipse.ui.forms.widgets; bundle-symbolic-name="org.eclipse.ui.forms"; bundle-version="3.7.1.v20161220-1635"; version="0.0.0"
!ENTRY org.eclipse.egit.core 4 0 2017-06-10 00:26:41.061
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.core [42]
Unresolved requirement: Import-Package: org.eclipse.jgit.annotations; version="[4.9.0,4.10.0)"
-> Export-Package: org.eclipse.jgit.annotations; bundle-symbolic-name="org.eclipse.jgit"; bundle-version="4.9.0.qualifier"; version="4.9.0"
org.eclipse.jgit [107]
Unresolved requirement: Import-Package: com.googlecode.javaewah; version="[1.1.6,2.0.0)"
Unresolved requirement: Import-Package: org.eclipse.jgit.api; version="[4.9.0,4.10.0)"
-> Export-Package: org.eclipse.jgit.api; bundle-symbolic-name="org.eclipse.jgit"; bundle-version="4.9.0.qualifier"; version="4.9.0"; uses:="org.eclipse.jgit.revwalk, org.eclipse.jgit.treewalk.filter, org.eclipse.jgit.diff, org.eclipse.jgit.util, org.eclipse.jgit.notes, org.eclipse.jgit.dircache, org.eclipse.jgit.api.errors, org.eclipse.jgit.lib, org.eclipse.jgit.treewalk, org.eclipse.jgit.blame, org.eclipse.jgit.submodule, org.eclipse.jgit.transport, org.eclipse.jgit.merge"
!ENTRY org.eclipse.egit.doc 4 0 2017-06-10 00:26:41.066
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.doc [44]
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.core; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.core.ant; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.mediawiki.core.ant; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.mediawiki.core; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.ui.cheatsheets; bundle-version="[3.3.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.ui.cheatsheets; bundle-version="3.5.0.v20160504-0839"; singleton:="true"
org.eclipse.ui.cheatsheets [156]
Unresolved requirement: Require-Bundle: org.eclipse.help.base; bundle-version="[4.0.0,5.0.0)"; resolution:="optional"
-> Bundle-SymbolicName: org.eclipse.help.base; bundle-version="4.1.2.v20170301-0400"; singleton:="true"
org.eclipse.help.base [101]
Unresolved requirement: Require-Bundle: org.apache.lucene.core; bundle-version="[3.5.0,4.0.0)"
Unresolved requirement: Import-Package: org.eclipse.equinox.http.jetty; resolution:="optional"
-> Export-Package: org.eclipse.equinox.http.jetty; bundle-symbolic-name="org.eclipse.equinox.http.jetty"; bundle-version="3.3.0.v20160324-1850"; version="1.3.0"
org.eclipse.equinox.http.jetty [64]
Unresolved requirement: Import-Package: org.eclipse.jetty.http; version="[9.0.0,10.0.0)"
Unresolved requirement: Require-Bundle: org.apache.lucene.analysis; bundle-version="[3.5.0,4.0.0)"
-> Bundle-SymbolicName: org.apache.lucene.analysis; bundle-version="3.5.0.v20120725-1805"
org.apache.lucene.analysis [14]
Unresolved requirement: Require-Bundle: org.eclipse.help.ui; bundle-version="[4.0.0,5.0.0)"; resolution:="optional"
-> Bundle-SymbolicName: org.eclipse.help.ui; bundle-version="4.0.200.v20160510-0758"; singleton:="true"
org.eclipse.help.ui [102]
Unresolved requirement: Require-Bundle: org.eclipse.help.base; bundle-version="[4.0.0,5.0.0)"; visibility:="reexport"
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.6.0,4.0.0)"
Unresolved requirement: Require-Bundle: org.eclipse.ui.forms; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.egit.gitflow 4 0 2017-06-10 00:26:41.076
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.gitflow [45]
Unresolved requirement: Import-Package: org.eclipse.egit.core.internal.job; version="[4.9.0,4.10.0)"
-> Export-Package: org.eclipse.egit.core.internal.job; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.9.0.qualifier"; version="4.9.0"; x-friends:="org.eclipse.egit.ui,org.eclipse.egit.gitflow.ui,org.eclipse.egit.gitflow"
Unresolved requirement: Import-Package: org.eclipse.egit.core; version="[4.9.0,4.10.0)"
-> Export-Package: org.eclipse.egit.core; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.9.0.qualifier"; version="4.9.0"; x-friends:="org.eclipse.egit.ui, org.eclipse.egit.ui.test, org.eclipse.egit.mylyn.ui, org.eclipse.egit.gitflow.test, org.eclipse.egit.gitflow.ui"
!ENTRY org.eclipse.egit.gitflow.ui 4 0 2017-06-10 00:26:41.078
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.gitflow.ui [47]
Unresolved requirement: Import-Package: org.eclipse.egit.core.internal; version="[4.9.0,4.10.0)"
-> Export-Package: org.eclipse.egit.core.internal; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.9.0.qualifier"; version="4.9.0"; x-friends:="org.eclipse.egit.ui,org.eclipse.egit.import,org.eclipse.egit.gitflow.ui"
!ENTRY org.eclipse.egit.mylyn.ui 4 0 2017-06-10 00:26:41.080
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.mylyn.ui [50]
Unresolved requirement: Import-Package: org.eclipse.egit.core.synchronize; version="[4.9.0,4.10.0)"
-> Export-Package: org.eclipse.egit.core.synchronize; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.9.0.qualifier"; version="4.9.0"; x-friends:="org.eclipse.egit.ui,org.eclipse.egit.ui.test"
!ENTRY org.eclipse.egit.ui 4 0 2017-06-10 00:26:41.081
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.ui [53]
!ENTRY org.eclipse.equinox.http.jetty 4 0 2017-06-10 00:26:41.084
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.http.jetty [64]
!ENTRY org.eclipse.equinox.jsp.jasper 4 0 2017-06-10 00:26:41.084
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.jsp.jasper [67]
Unresolved requirement: Import-Package: org.apache.jasper.servlet; version="[0.0.0,8.0.0)"
Unresolved requirement: Import-Package: javax.servlet.jsp; version="[2.0.0,2.3.0)"
-> Export-Package: javax.servlet.jsp; bundle-symbolic-name="javax.servlet.jsp"; bundle-version="2.2.0.v201112011158"; version="2.2.0"
javax.servlet.jsp [6]
Unresolved requirement: Import-Package: javax.el; version="2.2.0"
!ENTRY org.eclipse.equinox.jsp.jasper.registry 4 0 2017-06-10 00:26:41.086
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.jsp.jasper.registry [68]
Unresolved requirement: Import-Package: org.eclipse.equinox.jsp.jasper
-> Export-Package: org.eclipse.equinox.jsp.jasper; bundle-symbolic-name="org.eclipse.equinox.jsp.jasper"; bundle-version="1.0.500.v20150119-1358"; version="1.0.0"
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 0 2017-06-10 00:26:41.092
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.artifact.repository [70]
Unresolved requirement: Require-Bundle: org.tukaani.xz; bundle-version="1.3.0"
!ENTRY org.eclipse.equinox.p2.console 4 0 2017-06-10 00:26:41.094
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.console [71]
Unresolved requirement: Import-Package: org.eclipse.equinox.p2.engine; version="[2.0.0,3.0.0)"
-> Export-Package: org.eclipse.equinox.p2.engine; bundle-symbolic-name="org.eclipse.equinox.p2.engine"; bundle-version="2.4.100.v20160419-0834"; version="2.2.0"
org.eclipse.equinox.p2.engine [76]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.metadata.repository.io
-> Export-Package: org.eclipse.equinox.internal.p2.metadata.repository.io; bundle-symbolic-name="org.eclipse.equinox.p2.metadata.repository"; bundle-version="1.2.300.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.engine"
org.eclipse.equinox.p2.metadata.repository [81]
Unresolved requirement: Import-Package: org.eclipse.equinox.p2.planner; version="[2.0.0,3.0.0)"
-> Export-Package: org.eclipse.equinox.p2.planner; bundle-symbolic-name="org.eclipse.equinox.p2.director"; bundle-version="2.3.300.v20160504-1450"; version="2.0.0"
org.eclipse.equinox.p2.director [73]
Unresolved requirement: Import-Package: org.eclipse.equinox.p2.engine.query; version="[2.0.0,3.0.0)"
-> Export-Package: org.eclipse.equinox.p2.engine.query; bundle-symbolic-name="org.eclipse.equinox.p2.engine"; bundle-version="2.4.100.v20160419-0834"; version="2.0.0"
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.provisional.p2.director
-> Export-Package: org.eclipse.equinox.internal.provisional.p2.director; bundle-symbolic-name="org.eclipse.equinox.p2.director"; bundle-version="2.3.300.v20160504-1450"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.console, org.eclipse.equinox.p2.director.app, org.eclipse.equinox.p2.operations, org.eclipse.equinox.p2.ui.admin, org.eclipse.equinox.p2.installer"
!ENTRY org.eclipse.equinox.p2.director 4 0 2017-06-10 00:26:41.095
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.director [73]
!ENTRY org.eclipse.equinox.p2.director.app 4 0 2017-06-10 00:26:41.095
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.director.app [74]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.director
-> Export-Package: org.eclipse.equinox.internal.p2.director; bundle-symbolic-name="org.eclipse.equinox.p2.director"; bundle-version="2.3.300.v20160504-1450"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.operations, org.eclipse.equinox.p2.repository.tools, org.eclipse.pde.core, org.eclipse.equinox.p2.reconciler.dropins, org.eclipse.equinox.p2.ui, org.eclipse.equinox.p2.director.app"
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.engine
-> Export-Package: org.eclipse.equinox.internal.p2.engine; bundle-symbolic-name="org.eclipse.equinox.p2.engine"; bundle-version="2.4.100.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.garbagecollector, org.eclipse.equinox.p2.repository.tools, org.eclipse.equinox.p2.touchpoint.eclipse, org.eclipse.equinox.p2.touchpoint.natives, org.eclipse.equinox.p2.ui.sdk.scheduler, org.eclipse.pde.build, org.eclipse.equinox.p2.director.app"
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2017-06-10 00:26:41.098
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.directorywatcher [75]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.update
-> Export-Package: org.eclipse.equinox.internal.p2.update; bundle-symbolic-name="org.eclipse.equinox.p2.touchpoint.eclipse"; bundle-version="2.1.400.v20160419-0834"; version="2.0.0"; x-friends:="org.eclipse.equinox.p2.reconciler.dropins,org.eclipse.equinox.p2.extensionlocation,org.eclipse.equinox.p2.directorywatcher"
org.eclipse.equinox.p2.touchpoint.eclipse [87]
Unresolved requirement: Import-Package: org.eclipse.equinox.p2.publisher.eclipse; resolution:="optional"
Unresolved requirement: Import-Package: org.eclipse.equinox.p2.engine.spi; version="[2.0.0,3.0.0)"
-> Export-Package: org.eclipse.equinox.p2.engine.spi; bundle-symbolic-name="org.eclipse.equinox.p2.engine"; bundle-version="2.4.100.v20160419-0834"; version="2.0.0"
Unresolved requirement: Import-Package: org.eclipse.equinox.p2.publisher; resolution:="optional"
-> Export-Package: org.eclipse.equinox.p2.publisher; bundle-symbolic-name="org.eclipse.equinox.p2.publisher"; bundle-version="1.4.100.v20160504-1450"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.directorywatcher, org.eclipse.equinox.p2.touchpoint.eclipse, org.eclipse.equinox.p2.updatesite, org.eclipse.pde.publishing, org.eclipse.equinox.p2.publisher.eclipse"
org.eclipse.equinox.p2.publisher [83]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.artifact.repository
-> Export-Package: org.eclipse.equinox.internal.p2.artifact.repository; bundle-symbolic-name="org.eclipse.equinox.p2.artifact.repository"; bundle-version="1.1.500.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.publisher, org.eclipse.equinox.p2.reconciler.dropins, org.eclipse.equinox.p2.ui, org.eclipse.equinox.p2.directorywatcher, org.eclipse.equinox.p2.repository.tools, org.eclipse.equinox.p2.publisher.eclipse"
Unresolved requirement: Import-Package: org.eclipse.equinox.p2.planner; version="[2.0.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.garbagecollector
-> Export-Package: org.eclipse.equinox.internal.p2.garbagecollector; bundle-symbolic-name="org.eclipse.equinox.p2.garbagecollector"; bundle-version="1.0.300.v20160504-1450"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.touchpoint.eclipse,org.eclipse.pde.core,org.eclipse.equinox.p2.ui.sdk.scheduler"
org.eclipse.equinox.p2.garbagecollector [78]
Unresolved requirement: Require-Bundle: org.eclipse.equinox.p2.engine
-> Bundle-SymbolicName: org.eclipse.equinox.p2.engine; bundle-version="2.4.100.v20160419-0834"; singleton:="true"
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.artifact.repository.simple
-> Export-Package: org.eclipse.equinox.internal.p2.artifact.repository.simple; bundle-symbolic-name="org.eclipse.equinox.p2.artifact.repository"; bundle-version="1.1.500.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.touchpoint.eclipse, org.eclipse.equinox.p2.tests, org.eclipse.equinox.p2.directorywatcher, org.eclipse.equinox.p2.updatesite, org.eclipse.equinox.p2.publisher, org.eclipse.equinox.p2.extensionlocation, org.eclipse.equinox.p2.repository.tools"
!ENTRY org.eclipse.equinox.p2.engine 4 0 2017-06-10 00:26:41.104
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.engine [76]
!ENTRY org.eclipse.equinox.p2.extensionlocation 4 0 2017-06-10 00:26:41.104
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.extensionlocation [77]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.publisher.eclipse
-> Export-Package: org.eclipse.equinox.internal.p2.metadata.repository; bundle-symbolic-name="org.eclipse.equinox.p2.metadata.repository"; bundle-version="1.2.300.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.engine, org.eclipse.equinox.p2.publisher, org.eclipse.equinox.p2.reconciler.dropins, org.eclipse.equinox.p2.ui, org.eclipse.equinox.p2.updatesite, org.eclipse.equinox.p2.extensionlocation, org.eclipse.equinox.p2.repository.tools, org.eclipse.equinox.p2.publisher.eclipse"
!ENTRY org.eclipse.equinox.p2.garbagecollector 4 0 2017-06-10 00:26:41.118
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.garbagecollector [78]
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 0 2017-06-10 00:26:41.121
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.metadata.repository [81]
!ENTRY org.eclipse.equinox.p2.operations 4 0 2017-06-10 00:26:41.122
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.operations [82]
at org.eclipse.osg
Current Time: Mon Jul 21 06:02:38 EDT 2025
Powered by FUDForum. Page generated in 0.08945 seconds
