Home » Modeling » TMF (Xtext) » import and scope provider
import and scope provider [message #1764935] Sun, 04 June 2017 07:43 Go to next message
Hi everybody,
I have this EMF metamodel
index.php/fa/29555/0/
I create an Xtext project by importing this existing metamodel.
The Xtext grammar is
// automatically generated by Xtext
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model returns Model:
	{Model}
	name=ID
	( 'import' (^imports+=[Model|STRING])+)?
	greetings+=Greeting*
	persons+=Person*
Greeting returns Greeting:
	{Greeting}
	'Greeting'
	name=ID
		('applies' '(' applies+=[Person|QualifiedID] ( "," applies+=[Person|QualifiedID])* ')' )?
Person returns Person:
	{Person}
	'Person'
	name=ID;
QualifiedID : (ID | QUALIFIED_ID) ;
terminal QUALIFIED_ID :
  '^'?('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')*  '.' ('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* ( '.' ('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* )*;
Accordingly to my previous resolved topic https://www.eclipse.org/forums/index.php/t/1086559/
my models are saved as xmi by customizing MyDslUiModule class
class MyDslUiModule extends AbstractMyDslUiModule {
	def Class<? extends XtextDocumentProvider> bindXtextDocumentProvider() {
		MyDslDocumentProvider
	override Class<? extends IResourceForEditorInputFactory> bindIResourceForEditorInputFactory() {
		return MyDslResourceForEditorInputFactory
I customize the scope provider mechanism to manage the imports clause by adding the following code
class MyDslScopeProvider extends AbstractMyDslScopeProvider {
	override getScope(EObject object, EReference ref) {
		if (object instanceof Model) {
			scope_Model_imports(object as Model, ref)
		} else
			super.getScope(object, ref)
	def IScope scope_Model_imports(Model model, EReference ref) {
		return scopeForModel(model.getImports());
	def IScope scopeForModel(EList<Model> models) {
		var ArrayList<IEObjectDescription> result = new ArrayList<IEObjectDescription>
		for (model : models) {
			result.add(EObjectDescription.create(QualifiedName.create(model.name), model))
		new SimpleScope(IScope.NULLSCOPE, result)
Now, let's consider this model
<myDsl:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:myDsl="http://www.xtext.org/example/mydsl/MyDsl" name="model1">
  <greetings name="toto" applies="//@persons.0"/>
  <imports href="My2.mydsl#/"/>
  <persons name="titi"/>
</myDsl:Model>
I can be opened with the emf editor, but when I try to open it with the textual editor I obtain this error
java.lang.IllegalArgumentException: Segment cannot be null
	at org.eclipse.xtext.naming.QualifiedName.create(QualifiedName.java:203)
	at org.xtext.example.mydsl.scoping.MyDslScopeProvider.scopeForExtensions(MyDslScopeProvider.java:46)
	at org.xtext.example.mydsl.scoping.MyDslScopeProvider.scope_Model_imports(MyDslScopeProvider.java:38)
	at org.xtext.example.mydsl.scoping.MyDslScopeProvider.getScope(MyDslScopeProvider.java:30)
	at org.eclipse.xtext.serializer.tokens.CrossReferenceSerializer.serializeCrossRef(CrossReferenceSerializer.java:90)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.getToken(SequenceFeeder.java:481)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:262)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:434)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:501)
	at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence_Model(MyDslSemanticSequencer.java:71)
	at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence(MyDslSemanticSequencer.java:41)
	at org.eclipse.xtext.serializer.sequencer.AbstractSemanticSequencer.createSequence(AbstractSemanticSequencer.java:67)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:115)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:128)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:192)
	at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:386)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
	at org.xtext.example.mydsl.ui.MyDslDocumentProvider.setDocumentContent(MyDslDocumentProvider.java:55)
	at org.eclipse.ui.editors.text.FileDocumentProvider.setDocumentContent(FileDocumentProvider.java:425)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:183)
	at org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:227)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createDocument(XtextDocumentProvider.java:141)
	at org.eclipse.ui.editors.text.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:721)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createElementInfo(XtextDocumentProvider.java:262)
	at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:392)
	at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4178)
	at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:229)
	at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1466)
	at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:150)
	at org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEditor.java:247)
	at org.eclipse.ui.texteditor.AbstractTextEditor$5.run(AbstractTextEditor.java:3154)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
	at org.eclipse.ui.internal.WorkbenchWindow$14.run(WorkbenchWindow.java:2184)
	at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2180)
	at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3172)
	at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3197)
	at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:288)
	at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:318)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1324)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4814)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
	at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
	at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:324)
	at org.eclipse.ui.actions.OpenWithMenu.lambda$0(OpenWithMenu.java:180)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1313)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4080)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3706)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
The error comes from this line in the scope provider
When I debug model variable, it shows myDsl.impl.ModelImpl@3a4f4ec9 (eProxyURI: My2.mydsl#/)
and model.name returns null while the name value is not null as shown in the following model My2.mydsl
<myDsl:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:myDsl="http://www.xtext.org/example/mydsl/MyDsl" name="model2">
  <greetings name="dodo" applies="//@persons.0"/>
  <persons name="didi"/>
</myDsl:Model>
How can I resolve this issue, please?
  • Attachment: MyDsl.jpg
    (Size: 29.96KB, Downloaded 1353 times)
Re: import and scope provider [message #1764936 is a reply to message #1764935] Sun, 04 June 2017 07:49 Go to previous messageGo to next message
When I debug imported model ("model" variable) in the scope, all features are null.
It is strange !
index.php/fa/29556/0/
Re: import and scope provider [message #1764937 is a reply to message #1764935] Sun, 04 June 2017 07:50 Go to previous messageGo to next message
=> i assume name is null here
=> you need to look why
i assume you loading the xmi is broken regarding the models
and they are proxys that cannot be resolved
[Updated on: Sun, 04 June 2017 07:52] by Moderator
Re: import and scope provider [message #1764938 is a reply to message #1764937] Sun, 04 June 2017 08:18 Go to previous messageGo to next message
Yes Christian.
name is null.
Any idea/suggestion please?
Re: import and scope provider [message #1764939 is a reply to message #1764937] Sun, 04 June 2017 08:21 Go to previous messageGo to next message
Yes it's clearly an unresolved proxy. I see <imports href="My2.mydsl#/"/> in the example. The most common reason a proxy fails to resolve when really it shouldn't is that you didn't load the resource containing that proxy reference with an absolute URI. In an Eclipse environment, use URI.createPlatformResourceURI to reference the resource in the workspace. To reference something in the file system, use URI.createFileURI(file.getAbsolutePath()).
Re: import and scope provider [message #1764940 is a reply to message #1764939] Sun, 04 June 2017 08:31 Go to previous messageGo to next message
Make sure you first load all xmi and resolve all proxies
(EcoreUtil.resolveAll ....) before you start involving Xtext
Re: import and scope provider [message #1764941 is a reply to message #1764940] Sun, 04 June 2017 09:03 Go to previous messageGo to next message
(and the same before writing)
Re: import and scope provider [message #1764942 is a reply to message #1764941] Sun, 04 June 2017 09:13 Go to previous messageGo to next message
ps. i am still wondering if your way i the right way to go or if using a embedded xtext editor inside the emf editor would be easier
(have never done this - nor your way though)
Re: import and scope provider [message #1764948 is a reply to message #1764942] Sun, 04 June 2017 13:31 Go to previous messageGo to next message
when I edit manually this model
<myDsl:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:myDsl="http://www.xtext.org/example/mydsl/MyDsl" name="model11">
</myDsl:Model>
by changing <imports href="My2.mydsl#/"/> with <imports href="platform:/resource/MyDslExamples/My2.mydsl#/"/>,
the model becomes openable with the textual editor and shows the content
model1 import "model2" Greeting toto { applies ( titi ) } Person titi
So the problem is how to save the uri with "platform:/resource/MyDslExamples/".
I override the method doSave of MyDslResourceImpl by resolveAll
	public void doSave(OutputStream outputStream, Map<?, ?> options) throws IOException {
		EcoreUtil.resolveAll(resourceSet);
		super.doSave(outputStream, options);
but nothing happens!
How can I resolve this issue and save path in EMF models with "platform:/resource/"?
Re: import and scope provider [message #1764949 is a reply to message #1764948] Sun, 04 June 2017 13:52 Go to previous messageGo to next message
I am not sure how you created the model in the first place.
It might be a problem of how you create the xtext stuff and co
(You don't create platform resource Uris )
And I have doubts if the complete way you go is a good idea or not
For a multi file approach
So the question is: that is the Uri of the model before saving as xmi
Re: import and scope provider [message #1764972 is a reply to message #1764949] Mon, 05 June 2017 05:17 Go to previous messageGo to next message
As I mentioned in the EMF forum, rather than force the serialization content to use absolute URIs, use an absolute URI to load the serialization in the first place.
Re: import and scope provider [message #1765162 is a reply to message #1764972] Wed, 07 June 2017 03:45 Go to previous message
Thanks Christian and Ed for your messages.
The issue is resolved by customizing the CrossReferenceSerializer.
Faiez
Previous Topic:NPE in IntelliJ plugin tryting to convert PSIElement to EObject
Next Topic:manage eopposite references coming from imported metamodel
Current Time: Sun Aug 31 00:23:40 EDT 2025
Powered by FUDForum. Page generated in 0.04014 seconds
