import and scope provider [message #1764935] |
Sun, 04 June 2017 07:43  |
Hi everybody,
I have this EMF metamodel
I create an Xtext project by importing this existing metamodel.
The Xtext grammar is
// automatically generated by Xtext
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model returns Model:
{Model}
name=ID
( 'import' (^imports+=[Model|STRING])+)?
greetings+=Greeting*
persons+=Person*
Greeting returns Greeting:
{Greeting}
'Greeting'
name=ID
('applies' '(' applies+=[Person|QualifiedID] ( "," applies+=[Person|QualifiedID])* ')' )?
Person returns Person:
{Person}
'Person'
name=ID;
QualifiedID : (ID | QUALIFIED_ID) ;
terminal QUALIFIED_ID :
'^'?('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* '.' ('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* ( '.' ('a'..'z'|'A'..'Z'|'_')('a'..'z'|'A'..'Z'|'_'|'0'..'9')* )*;
Accordingly to my previous resolved topic https://www.eclipse.org/forums/index.php/t/1086559/
my models are saved as xmi by customizing MyDslUiModule class
class MyDslUiModule extends AbstractMyDslUiModule {
def Class<? extends XtextDocumentProvider> bindXtextDocumentProvider() {
MyDslDocumentProvider
override Class<? extends IResourceForEditorInputFactory> bindIResourceForEditorInputFactory() {
return MyDslResourceForEditorInputFactory
I customize the scope provider mechanism to manage the imports clause by adding the following code
class MyDslScopeProvider extends AbstractMyDslScopeProvider {
override getScope(EObject object, EReference ref) {
if (object instanceof Model) {
scope_Model_imports(object as Model, ref)
} else
super.getScope(object, ref)
def IScope scope_Model_imports(Model model, EReference ref) {
return scopeForModel(model.getImports());
def IScope scopeForModel(EList<Model> models) {
var ArrayList<IEObjectDescription> result = new ArrayList<IEObjectDescription>
for (model : models) {
result.add(EObjectDescription.create(QualifiedName.create(model.name), model))
new SimpleScope(IScope.NULLSCOPE, result)
Now, let's consider this model
<myDsl:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:myDsl="http://www.xtext.org/example/mydsl/MyDsl" name="model1">
<greetings name="toto" applies="//@persons.0"/>
<imports href="My2.mydsl#/"/>
<persons name="titi"/>
</myDsl:Model>
I can be opened with the emf editor, but when I try to open it with the textual editor I obtain this error
java.lang.IllegalArgumentException: Segment cannot be null
at org.eclipse.xtext.naming.QualifiedName.create(QualifiedName.java:203)
at org.xtext.example.mydsl.scoping.MyDslScopeProvider.scopeForExtensions(MyDslScopeProvider.java:46)
at org.xtext.example.mydsl.scoping.MyDslScopeProvider.scope_Model_imports(MyDslScopeProvider.java:38)
at org.xtext.example.mydsl.scoping.MyDslScopeProvider.getScope(MyDslScopeProvider.java:30)
at org.eclipse.xtext.serializer.tokens.CrossReferenceSerializer.serializeCrossRef(CrossReferenceSerializer.java:90)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.getToken(SequenceFeeder.java:481)
at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:262)
at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:434)
at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:501)
at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence_Model(MyDslSemanticSequencer.java:71)
at org.xtext.example.mydsl.serializer.MyDslSemanticSequencer.sequence(MyDslSemanticSequencer.java:41)
at org.eclipse.xtext.serializer.sequencer.AbstractSemanticSequencer.createSequence(AbstractSemanticSequencer.java:67)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:115)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:128)
at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:192)
at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:386)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1430)
at org.xtext.example.mydsl.ui.MyDslDocumentProvider.setDocumentContent(MyDslDocumentProvider.java:55)
at org.eclipse.ui.editors.text.FileDocumentProvider.setDocumentContent(FileDocumentProvider.java:425)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:183)
at org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:227)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createDocument(XtextDocumentProvider.java:141)
at org.eclipse.ui.editors.text.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:721)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createElementInfo(XtextDocumentProvider.java:262)
at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:392)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4178)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:229)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1466)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:150)
at org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEditor.java:247)
at org.eclipse.ui.texteditor.AbstractTextEditor$5.run(AbstractTextEditor.java:3154)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.ui.internal.WorkbenchWindow$14.run(WorkbenchWindow.java:2184)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2180)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3172)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3197)
at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:288)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:318)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1324)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4814)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:324)
at org.eclipse.ui.actions.OpenWithMenu.lambda$0(OpenWithMenu.java:180)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1313)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
The error comes from this line in the scope provider
When I debug model variable, it shows myDsl.impl.ModelImpl@3a4f4ec9 (eProxyURI: My2.mydsl#/)
and model.name returns null while the name value is not null as shown in the following model My2.mydsl
<myDsl:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:myDsl="http://www.xtext.org/example/mydsl/MyDsl" name="model2">
<greetings name="dodo" applies="//@persons.0"/>
<persons name="didi"/>
</myDsl:Model>
How can I resolve this issue, please?
Attachment: MyDsl.jpg
(Size: 29.96KB, Downloaded 1355 times)
FUDForum. Page generated in 0.06437 seconds
